Old 12-12-2005, 09:33 AM   #4621
BTW, does anyone have any pictures their RDX with a fan over the esc. I am using a Hara twister. I just got a novak fan to use.
slow is offline   Reply With Quote
Old 12-12-2005, 09:37 AM   #4622
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Just use one of these for your ESC and put a fan on your motor.
http://www.speedtechrc.com/store/ebp...nid=57&id=5738
It is for the KO VFS1 Pro Comp or the same as the Hara Twister 2 or 2.1 fits them both.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-12-2005, 10:00 AM   #4623
raffaelli's Avatar
I had a hard time with the car this weekend. The car handles great in all cases except left hand turns, regardless of speed. The car is fairly well balanced, droop is even, ride height is equal side to side, tweak is good, none of the tires are rubbing and all are equal size.
When last I ran it, I did not have this problem. I don't remember any big crashes last time I ran it but it is possible. What do you think it the problem? Someone mentioned to me that it may be a bent hinge pin.
24ITA
raffaelli is offline   Reply With Quote
Old 12-12-2005, 10:08 AM   #4624
koabich's Avatar
Send a message via Yahoo to koabich
Check your radio. Maybe a setting got moved or messed with. If that's not it, take the body off your car, and use the radio to turn the wheels left and right. See if there is any binding, anything blocking wheel travel or if something is broken!
koabich is offline   Reply With Quote
Old 12-12-2005, 10:32 AM   #4625
I also notice this happening when my steering linkage/ackerman were not even on both sides of the car. If one is even a little longer your car will get to that wheel to the end point quicker than the other causing it to have oversteer on that side. Check that and then if that is good check that your center steering link is also making the two steering post are perfectly ever. If that is good re-check tweak...Those are the things I check if that accures...
-Shookie <><
Old 12-12-2005, 10:41 AM   #4626
TheCoolCanFanMan's Avatar
-Shookie <><
Hi TCCFM here
We had developed a Triple-Cool-Can-Fan for the XXX-S for the very reason, as my VFS-1 had blown twice. It did help to keep the speedo cool and did not blow after that, but peeps were saying it was a bit over the top (but it worked just like all the other CCF's we produce) so we did not persue it any further as there would of been many ways to lay the electrics within the RC cars, even though some cars, ie, the RDX can on layout the elecs out one way apparently. I personally run the JRX-S and have run a Twister in the car with NO heat probs, but it has given me some glitching probs so maybe its time to revive the 'Triple' CCF Please let me know if anyones interested and I will investigate.
Cheers TCCFM
ARC 2013 model ZEN Racing, MM-UK, HW 3.1, Rich Paints, MM UK Rug Racers win13.5 2007/8
2nd in 2008/9/10 Win Ansman GP 2010 Schumacher GP. 17.5 blinky Winner of STCC 2009/10 13.5 WLRC 2010 Summer series. Winner of EWS Winter. 17.5 Blinky Winner of 2012/13/14 Rug Racers. 17.5 Blinky 2013 WLRC summer series. Newbury RCC GP 2014 17.5 Blinky 2015 3rd in 17.5 Rug Racers
TheCoolCanFanMan is offline   Reply With Quote
Old 12-12-2005, 10:45 AM   #4627
Mission_carbon's Avatar
Heya Guys i was out on my RDX and i had the same problem with the steering and ill do what shookie said to do to see if the steering links are the same size. But my question is i was putting my cells and they are rubbing against the belt any one get any tips?
Thanks,
Wills
Mission_carbon is offline   Reply With Quote
Old 12-12-2005, 10:56 AM   #4628
raffaelli's Avatar
Nothing seems to be binding. I cant find anything broken. The radio is unchanged. Strange. Looks like a tear down to check all the parts for bending.
24ITA
Old 12-12-2005, 10:57 AM   #4629
raffaelli's Avatar
-Shookie <><
Thanks. I did check all of that and it is good. The spin out is drastic - even with a small amount of wheel turn.
24ITA
Old 12-12-2005, 01:01 PM   #4630
RCFREAK's Avatar
Trader Rating: 17 (100%+)
check tires.... if foams.. for peeling.. if questionable.. swap left and right to see if the same..drive it and recheck. Make sure you are running the proper compounds front or rear.. a buddy mistakenly did it last race.. swapped compounds front to back only one side.. thought it was a heavy tweak.. but it was just installing the wrong tires..
check diffs... make sure the adjustment didnt back out.mine started hooking one night.. found front diffs very loose..
let us know what you find...
RCFREAK
RCFREAK is offline   Reply With Quote
Old 12-12-2005, 01:13 PM   #4631
stiltskin's Avatar
Trader Rating: 102 (100%+)
You didn't say what your car is doing when you turn left. When I had the FK05 it would spin out on right hand turns. After all of the usual checks, it turned out to be a blown out rear shock.
stiltskin is offline   Reply With Quote
Old 12-12-2005, 01:59 PM   #4632
raffaelli's Avatar
Sorry, thought I mentioned it. At any speed with any amount of turning input to the left, it will hook and rotate 180 degrees about the left front tire.
24ITA
Old 12-12-2005, 02:03 PM   #4633
stiltskin's Avatar
Check to see if one of your CVD's is bent. If it is, it may be locking that wheel when you turn.
Old 12-12-2005, 05:48 PM   #4634
Fatboy Joe's Avatar
check your CVD pins, all of your bearings, your shocks (if any of them have leaked), diffs in the rear, your oneway bearings in front. i had the same experience before but with a different car, a cvd pin was loose and was intermitently popping out as i turn so it binds and causes it to spin out. also, seized bearings can cause it too, they may feel ok but once some forces act up during cornering, they bind too. i hope this helps. im getting my RDX soon, cant wait to build it
Fatboy Joe is offline   Reply With Quote
Old 12-12-2005, 06:35 PM   #4635
Big Rigg's Avatar
The same thing happens to my car all the time... spins when turning one direction but is super dialed the other... 99.8235721% of the time it is because of a small hairline stress fracture on the tip of the A-arm outside of the small hinge pin... the castor block or rear hub will twist in an impact and break the arm in the same spot every time (I have about 8 or so arms that all broke that way) it is usually hard to see the break... try taking all the castor or hub off the arm then twist the end of the arm if you're not sure...
Hope this helps, good luck
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
