Old 12-07-2005, 03:44 AM   #4576
Fatboy Joe's Avatar
Default Internal Drive ratio
Hi, what is the internal drive ratio of the RDX? thanks
Fatboy Joe is offline   Reply With Quote
Old 12-07-2005, 03:53 AM   #4577
alb
Trader Rating: 19 (100%+)
2.0
alb is offline   Reply With Quote
Old 12-07-2005, 03:58 AM   #4578
Fatboy Joe's Avatar
Hi guys, what does this mean in the setup sheet? what setting does it signify? Sorry for the newbie question. Please see attached pic. Thank you.
Old 12-07-2005, 04:35 AM   #4579
Hi Joe.
That mean at you can change your front kickup and anti-dive. Read that in your manual, page 27.
Cruisaaja is offline   Reply With Quote
Old 12-07-2005, 06:59 AM   #4580
RCFREAK's Avatar
Trader Rating: 17 (100%+)
its the side view of the front bulkheads...1- ultra low roll center(optional pieces) 2- normal roll center 3- kickup 4- more kickup..
hope that helps.
rcfreak
RCFREAK is offline   Reply With Quote
Old 12-07-2005, 08:13 AM   #4581
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
hey jeff,
is position 2 on the roll centers just turning them over and not moving to a different hole ?
wallstreet is offline   Reply With Quote
Old 12-07-2005, 08:16 AM   #4582
yes
Mike Dobbs
barnacle is offline   Reply With Quote
Old 12-07-2005, 08:18 AM   #4583
Company Representative
CorallyUSA's Avatar
hope that helps.
rcfreak
0 - low roll centers (79121)
1 - stock roll center
2 - stock flipped over
3 - stock moved to upper hole
4 - stock flipped and in upper hole
NOTE: the front does not have an upper location in the rear of the bulkhead. The highest you could run is position 2, unless you used the Low Roll and flipped it.
CorallyUSA is offline   Reply With Quote
Old 12-07-2005, 08:20 AM   #4584
wallstreet's Avatar
alright thanks guys ,,, just trying to figure out how to keep from traction rollin on those rubber tires
Old 12-07-2005, 12:05 PM   #4585
raffaelli's Avatar
[QUOTE=syndr0me]The inside diameter of GQ foams is smaller than Jaco by about 1-1.5mm. Oddly enough, this seems to be a large enough difference to cause binding when applying power with the wheels turned, and only on the track with weight transfered to the front corner of the car. This only seems to happen when I run brushless, which has significantly more torque.
I realize putting orange wheels on an RDX is like some kind of bad joke in the eyes of most people, but I really like the way they look, and the way they wear (doing a lot of practicing with the brushless). The binding was a real pain to figure out since it was so inconsistent, and happened at such odd times. So, something to keep in mind I guess. I'm curious if anybody else has experienced this.
QUOTE]
I use GQ tires on my RDX. When I dial in maximum steering I hear some rubbing. But, since I donít use maximum steering it really isn't an issue for me.
24ITA
raffaelli is offline   Reply With Quote
Old 12-07-2005, 01:06 PM   #4586
syndr0me's Avatar
Trader Rating: 32 (100%+)
The inside of the wheel seems to bind on the end of the arm as weight is transferred to that side, and the suspension compresses. The wheels hitting the shocks under full lock isn't any different than other brands of tires, which is obviously dialed out with EPA.
I dunno, maybe it really does have something to do with torque. My brushed motors (only tried stock and 19) have never caused this to happen. Or maybe it's all that drinking...
syndr0me is offline   Reply With Quote
Old 12-07-2005, 01:30 PM   #4587
koabich's Avatar
Send a message via Yahoo to koabich
It's not the diameter of the tire that causes the rubbing it's the width of the tire. Not sure about GQ tires but upon my last check with Jaco against TRC, Parma and Speedmind, Jaco had the largest inside diameter wheel but they were also the widest...by over 1.5mm in some cases.
I rcurrently run Jacoon my RDX and when mounting the shocks all the way out on the arm, the wheels rub on the shock spring retainer when turning.
As another poster said, dial out some steering. I also use 1 degree or toe out. That will help.
koabich is offline   Reply With Quote
Old 12-07-2005, 04:57 PM   #4588
hello all i just put on the associated spring perches and they seem to big my shock eye bolts are to small do i need to buy some tc3 eye bolts to make them work or are they suppose to fit that sloppy
miamifanatic is offline   Reply With Quote
Old 12-07-2005, 05:16 PM   #4589
koabich's Avatar
Not 100% sure what you are asking as the spring perches have nothing to do with bolts or screws. The spring perch gets sliped on the shock shaft and finally rests on the ball end that you screwed to the end of the shock shaft. I have the Associated on mine and they fit perfect.
If you are confused, go look at your manual where the building of the shocks is discussed. The spring perch that everyone is talking about is called a "Spring Collar" in the Corally manual. This is the only aftermarket part that is needed when building the shocks. But this mod is only used when you are running foam tires!! If you run rubber, use the stock spring perches.
Hope this helps.
Old 12-07-2005, 05:22 PM   #4590
sorry what i meant was the ball end when i slide the perches over the ball end it doesnt fit snug it wobbles on it that isnt right is it and yes i am running foam stock
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
