Old 12-01-2005, 08:24 AM   #4486
Company Representative
CorallyUSA's Avatar
Originally Posted by aoizip
hey jeff..
all the stuff is all sold out???? I just call this morning
no more lower shock tower? brass bushing????? diff bolts???
~Ming
Everything is in stock.
CorallyUSA is offline   Reply With Quote
Old 12-01-2005, 01:46 PM   #4487
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
jeff or corally usa ,,, what do you guys suggest for lubing the rdx one way?
its brand new and just wondering if you guys suggest anything at all
wallstreet is offline   Reply With Quote
Old 12-01-2005, 02:57 PM   #4488
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
serpent makes a great bearing lube, i cant find mine right now, but i will look again....
MAtt
Team Losi Racing-Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 12-01-2005, 05:01 PM   #4489
EricO3's Avatar
Send a message via AIM to EricO3 Send a message via MSN to EricO3
Originally Posted by Jeff Brown
UPRIGHTS = rear hubs...... they are 0 deg standard and 2 deg optional
MID = one and one on the clips
DOWNSTOPS = the set screws to adjust droop in the arms
ANTISQUAT = angling of the rear hinge pins. the front of the pins is angled upward. The result is more straightline accleration and stability. You will also get more initial steering. Taking away from mid to exit steering.
HOLES = extensions are used on the rear which would be the other "magic 4th hole"
FRONT = referring to the front end direction of the car. You can adjust the hinge pin angles independently to achieve "anti" or "pro" squat on the front and rear.
90* ANGLE = Showing the angle of the kingpin ballstud. Not sure why this is there as it cannot be adjusted. It is on the C-hub.
Jeff
Wow, thanks a lot. For the droop screws, I noticed on the set-up sheets it's saying around 4.5mm?? Are they running 4.5mm of droop, the droop screws are that long, that's how much screw is visisble above the arm, under? Thanks!
EricO3 is offline   Reply With Quote
Old 12-01-2005, 05:21 PM   #4490
Mr. Shookie's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
I believe this is a better understanding...
If you place your car flat on a setup board or something perfectly flat without wheels on the arms should sit off the setup board 4.5mm....use a ride height gauge...That is a good starting point...
Hope that helps.
-Shookie <><
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 12-01-2005, 06:01 PM   #4491
EricO3's Avatar
Hope that helps.
-Shookie <><
Oic, is that how you guy set your droop? I ussually set mine buy measuring ride height, and then adjusting the droop by lifting the front end up until the tires just come off and measure the difference. Same for the rear.
Measuring the height of the arms off the table, do you measure at the very end of the arm? Thanks!
-Eric
Old 12-01-2005, 06:14 PM   #4492
Jeff Brown's Avatar
-Eric
I do it the way you described. To each his own. This way refers to "uptravel".
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 12-01-2005, 07:58 PM   #4493
subman's Avatar
Originally Posted by subman
What brand of tires does everyone use for foams on carpet. I have always used Jaco but I find the rims fragile (I know don't hit stuff and they won't break ) I was just looking to change it up. Thanks
Anyone?
subman is offline   Reply With Quote
Old 12-01-2005, 08:07 PM   #4494
Korey Harbke's Avatar
Parma, TRC, and Speedmind are also good choices.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 12-01-2005, 08:31 PM   #4495
JACO has changed there rims lately havn't they ? Making them more durable.
Chris Reilly is offline   Reply With Quote
Old 12-01-2005, 09:44 PM   #4496
squarehead's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Random thought: Gee, no less than 15 FK05s for sale on the first 5 pages of Classifieds. I wonder why?
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 12-01-2005, 09:54 PM   #4497
Trader Rating: 21 (100%+)
The Jaco rims seem to be stronger now. Also can try BSR. They get their foam from Jaco, so basically the same stuff. Just don't have the 2 stages.
Thanks to pops
TLR, Fantom, Horizon, Spektrum, Trackside
Brian L is offline   Reply With Quote
Old 12-01-2005, 09:56 PM   #4498
Send a message via AIM to R/C Anonymous
Brian L. you are just a madman with that Corally!!!
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 12-01-2005, 09:57 PM   #4499
subman's Avatar
Thanks everyone I think I might order some bsr's and try them and give Jaco another try maybe I'm just still getting old stock.
Old 12-01-2005, 11:06 PM   #4500
-Eric
Yea at the very outside edge cause the knuckle screw sits below the arm.
I use to use that way to set droop, but I found that it wasn't as consistant as doing it to each arm.
Plus I so use to doing it that way.
Same result cause I compaired...MAHAHAHAHA sorry....Besides I take off my tires after every run anyhow to clean them out and make sure they aren't damaged..Don't want to say how many times I forgot to check the rim and it snapped on the next run...
Ok enough you get my point..
-Shookie <><
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
