Old 11-14-2005, 10:53 PM   #4276
Still Bill's Avatar
Originally Posted by Jeff Brown
I like the "Mr. Losi" nick to go with the RDX setup help.
Jeff
Jeff,
Then, you are going to love me!
Just picked up an RDX carpet version kit.
Is there a Numan setup posted for the RDX???
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Old 11-14-2005, 11:03 PM   #4277
Picked up the Corally RDX today. Is there any initiation into the RDX Fraternity?
ravex is offline   Reply With Quote
Old 11-14-2005, 11:06 PM   #4278
Originally Posted by BadBoyRC
Ravex.. you got to get the RDX.. the car is awesome not its not fragile.. you can smack any car into a no movable barrier and something's bound to break. don't matter if its brand A or an rdx.
THE RDX has the same parts front and rear arm, shock, hinge pins, shock towers and more. so parts that you need to have are limited. but this is the top of the line car.. its light super fast, agile and best of all its easy to work on, The quality of the materials is top notch and the fit and finish.. is perfect.
To avoid breaking stuff get the RDX Rubberneck bumper and the kydex under bumper. Like a real car I choose to allow something to break off and its the front steering block I get those in plastic.. easy to change and you don;'t end up breaking an arm or hinge pin .
go fast = RDX!!!
Thanks for the tips. Can;t wait to put this kit together. You guys have any building / carpet setup tips to help me along the way...
Old 11-14-2005, 11:09 PM   #4279
Still Bill's Avatar
Nope...Just don't get lapped too many times by Aaron Young with his RDX...
Tip...Get the BRP TC3 Kydex bumper and trim to the shape provided on the Corally website.
Old 11-14-2005, 11:12 PM   #4280
Jeff Brown's Avatar
You can also order SRC1005 which has the Rubberneck Thin Hardfoam bumper and Kydex bumper plate included with extended body post screws. All this for $19.95 + S/H!!!! Don't Delay!! ORDER NOW!!!
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 11-14-2005, 11:19 PM   #4281
Still Bill's Avatar
Kewl!
Old 11-15-2005, 12:41 AM   #4282
syndr0me's Avatar
Trader Rating: 32 (100%+)
Best... hopup... ever.
Glancing blows in the front don't break arms or knuckles. Hard front impacts might bend the center bumper screw. If you hit real hard, you might break a bumper brace, but any car would break if you hit hard enough for that.
syndr0me is offline   Reply With Quote
Old 11-15-2005, 01:36 AM   #4283
Roger's Avatar
The BEST hop-up ever....................PRACTICE !
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 11-15-2005, 05:26 AM   #4284
RCFREAK's Avatar
Trader Rating: 17 (100%+)
thanks Jeff for your detailed responses.. it sums up alot of answers.. i guess i havent tried enough of the car..meaning not going more on the front oils..less droop and such.excellent feedbak!! nice to read something more than "OH HOW MUCH THE CAR BREAKS!" or "I CANT GET MY RIDE LOW!"
will let you know..
RCFREAK
RCFREAK is offline   Reply With Quote
Old 11-15-2005, 05:49 AM   #4285
stegger's Avatar
Default Diff locknut, holder & bolt......
Can anybody tell me if you can get these part's on there own.. Or are there any plans to produce them separately......
As 15/$25 for the short outdrive is a bit steep
stegger is offline   Reply With Quote
Old 11-15-2005, 09:53 AM   #4286
Brad_C's Avatar
Default Dom
Dom,
Tiffany is running stock and 19T rubber. I hope this weekend to get her to run some mod rubber.
Brad_C is offline   Reply With Quote
Old 11-15-2005, 10:18 AM   #4287
syndr0me's Avatar
Thanks for the enlightenment, that had never occurred to me during my numerous practice sessions.
Old 11-15-2005, 11:15 AM   #4288
Default Battery STraps
With the RDX carpet spec chasis:
Is there any filing required to fit the 3800 batteries. Also, do most of you use the included battery strap or tape to keep the battery pack secure. Just checking to see if the battery stays put without issues using the standard battery strap.
Old 11-15-2005, 11:17 AM   #4289
rayhuang's Avatar
With the RDX carpet spec chasis, is there any filing required to fit teh 3800 batteries. Also, do most of you use the included battery strap or tape to keep the battery pack secure. Just checking to se ei fteh battery stays put without issues using teh standard battery straps.
The new chassis are cut to fit the IB and GP3700's. YOu just need to round the edges just a touch to not cut the shrink wrap on the batteries. Too much and batteries will go below the chassis. As for the battery strap-Never had an issue with the factory battery strap. Furthermore-the RDX is lighter on the battery side than the electronic side-so no need to lose the strap.
Ray
Old 11-15-2005, 11:19 AM   #4290
Jeff Brown's Avatar
The standard battery strap works fine. No issues. I would recommend beveling the slots to get the pack to sit lower. Otherwise you will notice the strap flexes down a bit since the cells are bigger around.
Jeff
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
