Old 11-07-2005, 11:54 PM   #4111
imprsme's Avatar
Trader Rating: 74 (99%+)
Originally Posted by slow
Its not real clear in the manual but for foam carpet racing do you want the front diff bearing holders up or down? In the manual it shows the bearing holders down in the rear. Is this wear I should keep it for foam tires?
The only time I have moved the bearing holder up is on asphalt with a spool. It gets the cvds level and helps with some of the "chatter" of a spool and that is only in the front.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 11-08-2005, 06:30 AM   #4112
Superfly1967's Avatar
How about the front bearing holders, does the bearing ride low there too.
Superfly1967 is offline   Reply With Quote
Old 11-08-2005, 06:31 AM   #4113
Strike that last question
Old 11-08-2005, 07:33 AM   #4114
From from original question I really need to know if the FRONT bearing holder should be up or down?
slow is offline   Reply With Quote
Old 11-08-2005, 07:48 AM   #4115
Administrator
Matt M.'s Avatar
Trader Rating: 26 (100%+)
slow
call Kock....
or wait till jeff gets on...
Matt
Team Losi Racing-Team Tekin-Proline Racing-Motiv-92zero Designs-Jim Neubert Paint Design-LiveRC.com-TFR-Team Dirt Heaven-Gravity RC-Trackside
UNLESS someone like you cares a whole awful lot,nothing is going to get better. It's not. Dr. Seuss
Matt M. is offline   Reply With Quote
Old 11-08-2005, 10:07 AM   #4116
Run them in the down position.
Mike Dobbs
barnacle is offline   Reply With Quote
Old 11-08-2005, 10:28 AM   #4117
What are the effects of running the front one up and the back one down? I recently put my carpet spec together that way it seems to have great steering but a little loose in the back would this cause the problem?
miamifanatic is offline   Reply With Quote
Old 11-08-2005, 10:37 AM   #4118
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Supposly from what I know (and I know very little) is when haveing the diff's up you loose traction .
Roberto Falcon is offline   Reply With Quote
Old 11-08-2005, 10:40 AM   #4119
if you run the rear diff higher than the front...it will give you more steering(and front bite), while accelerating...
Dhartman03 is offline   Reply With Quote
Old 11-08-2005, 12:06 PM   #4120
what about the front diff up and rear one down?
Old 11-08-2005, 12:28 PM   #4121
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
Default Replacemnt CVD's..and other stuff
Replacemnt CVD's..
Has anyone found a replacement MIP cvd. I run at tracks that don't carry RDX parts and wanted to know if anyone know what cvd fits as a temp replacement>? I end up supplying other rdxers from my stash.
I also found that the one way out drives can be replaced with the Mugen ones from the mtx3..
BadBoyRC is offline   Reply With Quote
Old 11-08-2005, 12:35 PM   #4122
koabich's Avatar
Send a message via Yahoo to koabich
I asked that same question several weeks ago and Jeff Brown answered it. I tried it and he was right...of course he was.
A rasied diff will offer less traction on that end. So if you raise the front diff, you have less front traction...etc.
koabich is offline   Reply With Quote
Old 11-08-2005, 01:13 PM   #4123
Roger's Avatar
Originally Posted by BadBoyRC
Replacemnt CVD's..
BadBoy: Im looking as well. The length of the CVD bones are 50.20mm. If anybody has tried other MIP CVD's for other cars, let us all know. Thanks
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 11-08-2005, 02:06 PM   #4124
BadBoyRC's Avatar
Boy I just got off the phone with MIP.. they are the most unhelpful people.. I asked if there was any other dogbone that was 50mm they said they couldn't tell me I'de have to go to a local hobby shop that carried their stuff and measure each one.
They had no chart that showed the sizes and even if they did I'de have to go through corraly or be a manufacter to see it.
MIP Sucks on top of that theres no toll free number so it was on my nickle.. If that person worked for me they'de be fired.. only problems no soltuions.. they call the customer service!?
Old 11-08-2005, 02:20 PM   #4125
rc_bam226's Avatar
Okay, just checking around, the TC3 bones, are measured at something around 50mm. Good luck Roger and Badboy.
rc_bam226 is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
