Old 11-07-2005, 02:28 PM   #4096
litespeed-dom's Avatar
Originally Posted by Turbonium
i used the white RPM's on my carpet car.... matches the white pulleys real nice!
Wes
Yeah yeah Wes, I have old ugly black pulleys!!!
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 11-07-2005, 02:35 PM   #4097
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'll probably get laughed at, but in the holes where the bearings go into the knuckles, I used a piece of paper towel to take up the slack. I wrapped the bearings (or washers, which I use now) and then jammed them in there. Then, I trimmed excess. It's a little tight at first, but it loosens up quick and seems to last quite a while. It also has the advantage of filling only the existing space, and being simple to remove.
I suppose that's not elegant enough for the demanding RDX crowd, but it's been fine for my mediocre club racing skills. :-D
syndr0me is offline   Reply With Quote
Old 11-07-2005, 02:37 PM   #4098
No, I actually think it's a smart idea! I would not want to mess with CA and wait for it to try when I'm racing and in a hurry to put the car back together! People will ask what the heck I'm doing in the toilet? I'll just tell them, "Getting parts!"
Dom
Old 11-07-2005, 03:50 PM   #4099
Korey Harbke's Avatar
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-07-2005, 04:00 PM   #4100
Company Representative
CorallyUSA's Avatar
ONLINE SHOPPING FIXED
Some of you may have tried to place orders over the weekend and noticed that everything appeared to be "No Longer Available". Well we upgraded our software last week and they did not inform us of any code changes so we made the code changes today. Everything should be fine now again. If you find any broken links let us know. Thanks!
CorallyUSA is offline   Reply With Quote
Old 11-07-2005, 04:04 PM   #4101
Call me an infidel if ya want, but it looks like JRXS and TC4 C blocks and steering knuckles can easily be made to fit the front RDX A arms. Only a little bit of shaving from the sides of the block where the hinge pin goes thru is needed. The outer hinge pins are almost exactly the same diameter. AE or Losi CVD axles and bearings would need to be used, of course. The C blocks are very very close to the same height, so roll center shouldn't change. Haven't actually tried this yet, so I dont know about differences in steering ackerman/geometry. A quick first look shows that AE TC4 steering knuckles will probably be the closest to the original RDX, as far as ackerman/ geometry.
Why do this, you ask? Cost and durability, really. Aluminum C blocks can bend, without you even knowing it, throwing off your caster angles and handling. And they are expensive to replace. RDX plastic steering knuckles break out around the kingpins, since the pins to not extend far enough into the knuckle, and they are only plastic afterall, not a graphite composite. And aluminum RDX steering knuckles are really expensive, and can still bend or break. AE and Losi C blocks and steering knuckles are a bit more durable than RDX plastic ones, and far more readily available than the RDX parts. Especially for ppl who have run AE/Losi in the past and probably already have a handful of parts laying around (like me!)
Stealth_RT is offline   Reply With Quote
Old 11-07-2005, 05:29 PM   #4102
stiltskin's Avatar
Trader Rating: 102 (100%+)
Thanks for the advice. Since my wife won't let me work on the dining room
table anymore, I'll just move my stuff to the bathroom floor where my parts are. I just swapped out my cvd's (worn pin holes) and put the plastic knuckles on. It took away about 90% of the slop. I'm going to alter the aluminum ones though for durability reasons. I've run the shoe-cracker ball cups before and they are sweet. I've had them on order now for about a month at the LHS. Should have them this week.
Now since Corally has continued to update the kits with the improved parts, I'll put my two cents in on another subject. What's up with the aluminum turnbuckles (spaghetti noodles)? Great car, just wondering why they skimped on the TB's.
Sushi Boy, welcome back. I guess you've got a balance between school and racing figured out by now.
stiltskin is offline   Reply With Quote
Old 11-07-2005, 07:00 PM   #4103
Registered User
Well actually i've fitted Losi XXX-S diff puleys to my RDX they are much lighter and the same count for number of teeth.
3/32 carbide diff balls are lighter also compared to 3.5 mm diff balls.
pipih2000 is offline   Reply With Quote
Old 11-07-2005, 07:07 PM   #4104
Hi Pipi,
it s pace...i try to do that but i was not able to build the diff....it s seem that the bearing in the pulley and the one who goes in the outdrive are too wide and i was not able to thighten my diff!!
can you say what you are doing to be able to do it??
Pace
Pace72 is offline   Reply With Quote
Old 11-07-2005, 07:18 PM   #4105
Registered User
i put the bearing half and half on the puley and its stay there cause the bearing is fairly tight. and you got to file or grind the outdrive that has the nut in.grind the bearing suport by 1.5 mm and then use X-ray spacer to re-shim your diff in the bulkhead(shims 10x12 i think) One other thing you got to Dremel of the lip in the puley right by the diff balls.
Then all you got to do is use 3/32 carbide diff balls and ceramic thrust bearing and it's the smoothes dif ever seen!!!
Old 11-07-2005, 07:21 PM   #4106
Registered User
i only use one bearing and when i say file the outdrive i mean in lenght.
Old 11-07-2005, 11:13 PM   #4107
Jeff Brown's Avatar
I didn't know companies were including Titantium Turnbuckles.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 11-07-2005, 11:23 PM   #4108
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
I dont know but I kinda like Corally's turnbuckles
Roberto Falcon is offline   Reply With Quote
Old 11-07-2005, 11:34 PM   #4109
Default Diff Bearing Holders
Its not real clear in the manual but for foam carpet racing do you want the front diff bearing holders up or down? In the manual it shows the bearing holders down in the rear. Is this wear I should keep it for foam tires?
slow is offline   Reply With Quote
Old 11-07-2005, 11:50 PM   #4110
Thats where I've always left it.
-Korey
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
