Old 11-04-2005, 12:36 PM   #4081
koabich's Avatar
Send a message via Yahoo to koabich
Originally Posted by miamifanatic
hello all looking for a set up i have the corally rdx carpet spec. we are running on ozite carpet. the track size is 30 by 45. just wondering if anyone has any suggestions or if someone is running the same size track what there set up is thanks
The Corally USA website has all the set-up you'll ever need! Try there.
koabich is offline   Reply With Quote
Old 11-05-2005, 10:55 AM   #4082
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default Shocks
Has anybody swapped out there RDX skocks out and willing to sell?
RED-LINE M03 is offline   Reply With Quote
Old 11-06-2005, 02:01 PM   #4083
Superfly1967's Avatar
When setting ride height on the RDX, do I have to true the foams down to 57mm-58mm from New to get to a 4.5mm to 5mm ride height when the rear shock is monted at 2nd hole from outside on the shock tower and 1st hole on inside toward hinge on rear arm like on Jeff Cuffs Las Vegas IIC setup?
Just wondering, I have a friend who used that set-up and only trued his tires to 62mm so he just layed down the shock a little more. I would like to use the set-up in it's entirety when I get my car 11-07-05.
Any info on this would be greatly appreciated.
Superfly1967 is offline   Reply With Quote
Old 11-06-2005, 02:17 PM   #4084
Korey Harbke's Avatar
you normally adjust your ride height with your preload collars on the shocks. If you are running foam tires you will most likely need to use soem different spring perches from AE or xray. They make the spring sit lower on the shock, so it's easier to get ride height with bigger tires.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 11-06-2005, 02:34 PM   #4085
Roger's Avatar
I start my tire diameters at 58-59mm. If I start them at 59mm, I usually will run about 2-3 battery packs before the first qualifier. By this time, the tires should've weared down to 57.5-58.0mm. Don't forget to rotate your foams after each battery pack. This will ensure even tire wear on all four corners.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 11-06-2005, 03:25 PM   #4086
Thanks for the info. Any part numbers for the spring perches?
Old 11-06-2005, 07:56 PM   #4087
CandyMan's Avatar
associated 6475 and xray 308310
CandyMan is offline   Reply With Quote
Old 11-06-2005, 08:14 PM   #4088
Jeff Brown's Avatar
62mm tires are huge. If possible I would recommend starting more around 58 or 59mm like Roger mentioned. When the tires are over 60mm you get a lot of sidewall movement and leads to traction roll and possible funny handling characteristics.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 11-06-2005, 10:02 PM   #4089
Thanks again.
Old 11-07-2005, 07:25 AM   #4090
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 11-07-2005, 11:07 AM   #4091
syndr0me's Avatar
Trader Rating: 32 (100%+)
Are there any options available for a motor guard?
syndr0me is offline   Reply With Quote
Old 11-07-2005, 01:09 PM   #4092
stiltskin's Avatar
Trader Rating: 102 (100%+)
Anyone have any ideas how to get rid of some front end slop? It looks like a combination of aluminum knuckle bearing slop, cvd slop and ball cup slop all rolled into one. I was just curious if anyone has dealt with this before I spend my allowance on a bunch of worthless crap that doesn't fix my problem.
stiltskin is offline   Reply With Quote
Old 11-07-2005, 01:16 PM   #4093
litespeed-dom's Avatar
I found that to be a problem as I put more miles on the car, so I de-slopped the car last night....
First, the bearings on the alu knuckles... I put a light coat of CA inside the knuckles so the bearings fit in there snug.
I put a very thin shim between the knuckles and c-hubs, slop gone.
Now just about the only thing sloppy is the ASC-like ball ends. I hear Schumacher ends are the ones to use. So will be searching for some of those.
I'm thinking about using Losi ballends, wonder if that would work.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 11-07-2005, 02:10 PM   #4094
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
you can use the RPM cups for AE/Losi, as they have the right size ball, 4.3mm? matches nice, and less slack. they are pretty snug on the turnbuckle, as the 3mm on the RDX is slightly larger than the 3/32 of the RPM's..
i used the white RPM's on my carpet car.... matches the white pulleys real nice!
Wes
oh yeah, on the rear, if you use the lower holes on the shock tower, some material may have to be shaved, as it will bind on the bulkhead. still plenty strong.
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 11-07-2005, 02:17 PM   #4095
RC_Woody's Avatar
Dom,
I heard the Schumacher grippa ball cups are the way to go as well.
Let me know if you find any... every time I call Tammies I'm put on hold for 10mins and I finally give up!
Woody
RC_Woody is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
