Old 11-02-2005, 01:54 PM   #4051
Big Rigg's Avatar
Default Can you hear that?!?!
Make sure you lube the blades too, they can bind up mid corner and if they're already worn could possibly click??? Also the inside of the tire rim could be rubbing against the arm when the wheel is 100% turned, I usually shave down the inside rim edge... Good luck
[url=http://www.corallyusa.com/][color=Red]- Corraly USA -[/color][/url]
[url=http://www.corallyusa.com/specializedrc/index.htm/][color=Red]- Specialized R/C -[/color][/url]
[url=http://www.thunderrc.com/eshop/][color=DarkRed]- Team Thunder RC -[/color][/url]
[url=http://www.cfxpaintworks.com/][color=DarkOrange]- CFX Paintworks -[/color][/url]
[COLOR=DarkSlateGray]- Team Ertrachter Factor - [/COLOR]
If my last name were Oxlong, I would name my kid Mike... yup Mike Oxlong
-Heywood Jablome
I don't want to pay for my sig, so yawl figure it out...
Big Rigg is offline   Reply With Quote
Old 11-02-2005, 02:48 PM   #4052
Trader Rating: 15 (100%+)
Default Roger is dialed!!!!!!!!!
And who are you going to thank when you dominate ?
AARON YOUNG is offline   Reply With Quote
Old 11-02-2005, 02:58 PM   #4053
Trader Rating: 14 (100%+)
Roger, Try setting the car up on blocks and running it about 1/4 throttle. then turn the wheels lock to lock while keeping the throttle constant and see if you get that chatter noise. My car does this on blocks but I have yet to hear it do it on the track. Has anyone else expirenced this noise in the drive train while turning the wheels? It seems like it's coming from the front end but I haven't been able to pinpoint where it's coming from. It only does it at low to mid throttle and while turning. Once i get it to start chattering it will do it until i lift off the gas. Other than that I love the car. After adjusting my setup technique to a nose heavy car it feels very good on the track and is fast.
Mike C
crisis641 is offline   Reply With Quote
Old 11-02-2005, 03:10 PM   #4054
Company Representative
CorallyUSA's Avatar
REPLACEMENT SET SCREWS FOR SPECIALIZED CVD BONES
Now available from SRC are replacement set screws for our Machined Steel and Aluminum CVD Bones used with the Steel Blades. Do not be without spare of these if you are to drop one at the track. There are 4 set screws to a bag.
PART NO. - SRC79179 - RETAIL $2.50
CorallyUSA is offline   Reply With Quote
Old 11-02-2005, 03:23 PM   #4055
imprsme's Avatar
Trader Rating: 74 (99%+)
Mike C
I have heard/seen this on a few cars. The only thing we were able to come up with is while the car has no load on the wheels and the wheels are turning the CVD is "maxxed" out The chatter/vibration you are hearing and seeing is the axle in the bone "maxxing" itself out as it rotates.
Not sure if this makes since but it is what we noticed. On the track you will not notice it.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 11-02-2005, 03:28 PM   #4056
CorallyUSA's Avatar
Correct. It is even more apparent with a Spool in the front end. You think the car is broken when you do it with a Spool.
Old 11-02-2005, 03:37 PM   #4057
Roger's Avatar
of course, Aaron Young of Team Corally . This guy is definately an asset to Team Corally. He's fast and very helpful to all racers and hobbiest alike. Im not sure if he's got the full factory ride he deserves. Im sure the sales of Corally RDX kits and parts in Northern California have increased in demand for the past 3 months. There are alot of racers converting over to the Corally RDX not because of the superior craftsmanship of the corally kits, but rather for technical and support by sponsored drivers such as Aaron Young. I don't think i'l dominate like Aaron, but I can say this; I will put up a good fight for position in my qualifiers and mains.
Another big shout goes to John Hicks of HobbyTown USA. Him and I will be working on several set-ups for different applications and we wil be supporting Corally at club races and other big events.
I almost forgot Steve Turada for the help and letting me try his car for the first time on carpet before the regionals.
Thanks alot guys.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 11-02-2005, 04:07 PM   #4058
Hebiki's Avatar
Trader Rating: 26 (100%+)
Thanks alot guys.
roger.. YGPM sir
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 11-02-2005, 05:38 PM   #4059
HarshGuy's Avatar
Thanks alot guys.
Yep ...I'm guilty of buying 2 complete setups ...double diff kits, all kinds of spare parts, 4 mm chasi (is that the plural of chassis?) , spring sets for both carpet and asphalt, castor blocks, etc, etc, etc ....due to A-Yo ...especially after he let me drive one of his cars last month.
http://www.arroyoc.com
http://www.gearchart.com
http://www.weracemountainbikes.com
HarshGuy is offline   Reply With Quote
Old 11-02-2005, 09:31 PM   #4060
Roger's Avatar
Originally Posted by Hebiki
roger.. YGPM sir
brotha Hebiki: YGPM
Old 11-02-2005, 10:00 PM   #4061
dal bains's Avatar
Trader Rating: 35 (100%+)
ahhh...group hug
RCAMERICA-XRAY-HUDY
dal bains is offline   Reply With Quote
Old 11-02-2005, 11:09 PM   #4062
Jeff Brown's Avatar
Mike C
I found this explaination as well......... from Adrian at Schumacher.
The chatter comes from the fact that no R/C cars use true CVD's (Constant Velocity Drive). MIP and TiR CVD are actually just fancy rebuild-able UJ's (Universal Joints). The are no problems when the wheels are straight. However, as the wheels turn the UJ causes the axle to accelerate up to 7 deg ahead of the dog bone for 180 deg then decelerate 7 degrees behind the dog bone for the remaining 180. This 360deg cycle of acceleration and deceleration of the axle causes the chattering. Note that the car will not chatter with the wheels and tires off the car. The inertia of the rotating wheel resisting the axles acceleration and deceleration causes the chattering.
As the the drive system wears with use the chattering gradually gets better them pretty much disappears. The tiny amount of play that develops in a CVD with use allows the system to because less sensitive to and eventually can absorb the inherent oscillation.
This is why all the new guys have a problem with this but not the guys with older cars.
The chatter is only noticeable with spools. Diffs and one ways can absorb the oscillation.
All sedans chatter. The JRXS is the first car with a sort-of real CVD. It uses a very old articulating joint design to function as a CVD. It works and is very clever. Their ads say patent pending but I doubt they will be able to patent it as it has been around since the 1800's.
Others are working on real CVD's but the problem is that the materials available do not allow us to make true CVD's within the space and weight limitations required by our cars with acceptable durability....for now.
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 11-02-2005, 11:10 PM   #4063
Roger's Avatar
Originally Posted by dal bains
ahhh...group hug
Dal: I know you want a A&W rootbeer float
Old 11-03-2005, 12:09 AM   #4064
syndr0me's Avatar
Trader Rating: 32 (100%+)
Would someone mind reposting the best way to adjust the diff when using 6 washers? I'm running dual diffs, foam tires on carpet. I finally grabbed some ceramic thrusts (have the balls already) and new rings, so I want to get it right. Also, the washers go like this ()()(), right?
Also, when looking at the different setups, like Cuffs' IIC for example, what brand shock oil are you guys using? I've just recently learned that not all brands are created equal. :-D Still a n00b I guess.
syndr0me is offline   Reply With Quote
Old 11-03-2005, 07:17 AM   #4065
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
In my fears of breaking more arms and knuckles off of the right side, I have removed 2 of the 6 thrust cone washers (as a prevent defense) from my front, and have shimmed my arms 1mm away from the bulkhead. Hopefully, this will stop the CVD from crashing into the diff screw head on impact. Time will tell, but all indications say it is the solution to my problem.
For adjustments, I get the screw to close in on the diff assembly, the gradually tighten it up, using quarter turn increments, then 1/8th turns at a time. I don't compress the diff completely, but keep checking the tension on the center pulley. With the front end completely assembled, you can stick a small flat head screw driver into the screw head, and turn the left front wheel to tighten the diff. Be warned though, VERY little turn of the wheel is needed to make small steps with the tension of the diff. Keep getting tighter until the center pully doesn't slip when you are holding both front tires.
With ceramic diff balls and a fly crap of diff lube in each ball race hole, the diff is gonna feel super smooth. After one pack, you won't believe how silky it is. After one pack, re-check the tightness of the pulley. Once it's set, you shouldn't need to adjust the diff again.
Remember, don't over tighten these diffs. It isn't necessary to crank them down and stretch the diff screw. These screws have shown to be fairly soft, and they don't like to be stretched. This is how people are breaking them, when the diff seems to "feel" looser, they re-tighten the diff, and stretch the screw some more until it finally snaps off in your left diff half.
Patience will reward you here with silky smooth diffs that will need ZERO maintenance.
doug
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
