Old 10-25-2005, 07:42 PM   #3901
Superfly1967's Avatar
Default Which one
So, is the only difference between the 3 Corally kits, the upper deck thickness and the diff and one way. If I were switching to 64 pitch spurs, will any spur work, and recommendations?
Superfly1967 is offline   Reply With Quote
Old 10-25-2005, 07:45 PM   #3902
imprsme's Avatar
Trader Rating: 74 (99%+)
Castor Blocks are different also
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 10-25-2005, 07:49 PM   #3903
RCknight's Avatar
Originally Posted by imprsme
NONE are "weak designed" if they were they wouldn't have put them in the kit!
Now if you are asking which parts tend to break...same as all the other cars. Arms, Steering knuckles and shock towers are things I have broken. But only after a GOOD LICK! But other than those I haven't broken anything else.
I was just wondering what extra things you would want on a race day, things like extra arms or a front belt. What else breaks easy?
RCknight is offline   Reply With Quote
Old 10-25-2005, 07:56 PM   #3904
imprsme's Avatar
On race days I like to have Arms, towers, Knuckles (if you don't get the Alu. ones), a belt Front belt would be nice also. Spring kit. and pistons. Toes spacers. A small parts bag assortment. Other than those I can't think of anything else that I have needed.
AwesomatixUSA
eXpress Motorsports
Old 10-25-2005, 08:30 PM   #3905
RCknight's Avatar
Default dang...
shock towers? How do you break those?
Old 10-25-2005, 08:39 PM   #3906
Jeff Brown's Avatar
SRC1000 - Rubberneck Hard Foam bumper
That is the number one option part to purchase.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 10-25-2005, 08:48 PM   #3907
SpeedDesignz's Avatar
Send a message via AIM to SpeedDesignz
Hi Jeff
how are my goodies coming along ?
NYC Hobbies / Eurotek motorsports / SpeedDesignz / BackBreaker Racing !!
SpeedDesignz is offline   Reply With Quote
Old 10-25-2005, 08:55 PM   #3908
rayhuang's Avatar
Not any SPur gear.
KImbrough work great as do PRS, but in the PRS line you have to order OVAL Spur Gears.
Old 10-25-2005, 09:49 PM   #3909
imprsme's Avatar
Jeff
Yeah I forgot about that! It was a "Goodie" that came with my kit
As for Towers The only way I have broken those is by running the outer most camber hole. But like I said you got to take a good shot to break it!
AwesomatixUSA
eXpress Motorsports
Old 10-25-2005, 10:59 PM   #3910
syndr0me's Avatar
Trader Rating: 32 (100%+)
I'm starting to wonder when I'll break my last arm. The novice class with 19T and all different cars don't break a thing, and the slightest brush against the wall and I'm replacing an $8 arm. I know better driving will help, and I'm practicing for hours EVERY week, but this is really starting to wear me down. Is there anything that will help? I'll run softer arms or aluminum arms or whatever it takes. I've got the strong bumper and the other plastic thing. It's really wearing me down.
syndr0me is offline   Reply With Quote
Old 10-25-2005, 11:15 PM   #3911
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
If you're breaking front arms make sure you have your arms spaced out an extra 1 mm from the bulkheads. Several others and myself have noticed that when this is done nearly all front-end breakages go away. Are you running aluminum steering blocks? If you space out the front you don't have to.
Side note: Running the front wider will give the car a touch more steering, also.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 10-25-2005, 11:19 PM   #3912
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Originally Posted by rayhuang
Not any SPur gear.
Actually you have to order Pro-Lite oval spur gears for the RDX. In stock at EAMotorsports.com by the way
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 10-25-2005, 11:39 PM   #3913
syndr0me's Avatar
Right now, I've got two 1mm spacers in there, and wide hexes. Should I go to three 1mm spacers and narrow hexes? I've got the aluminum knuckles too. I'm completely obliterating the arms... all three I broke tonight were in three pieces when I came off the track. I'm not kidding about these being minor incidents either. I swear, I'm being very patient, but ordering a bag of arms every week gets old. Thanks for the help.
Old 10-25-2005, 11:52 PM   #3914
syndr0me's Avatar
Just an FYI about something I discovered with the car tonight.
I had some bearings go bad (they were old, we race on carpet) so I decided to replace them all with a ceramic kit from ACER. Everything worked great, and it did a great job of reducing the friction in the drive train. I can't say I noticed much on the track, but that's a different debate.
Anyway, with the ceramic bearings in there, the front pulley seems to seize up at weird intervals. I noticed that the real pulley has a slight amount of play between the bulkheads (maybe 1mm on each side) but the front pulley is completely jammed with NO play at all. It looks like that lack of play in the front was putting pressure on the larger seals of the ceramic bearings, and causing them to bind. Replacing them with the stock bearings fixed the problem.
So, I'm not sure what that means, exactly. It's not immediately apparent what design benefit is given by having the front pulley have no wiggle room, but it does seem to cause issues with ceramic bearings that don't use metal shields. If there's no benefit, an extra tiny bit of play in the front would be a nice change for the RDX2. :-)
Old 10-26-2005, 12:45 AM   #3915
Roger's Avatar
Brian: Im in the process of building my car. Can you show a pix of this ? Thanks.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
