Team Corally RDX Touring Car >
Old 10-20-2005, 05:53 PM
  #3826
UCHEATULOSE's Avatar
Thumbs up
full set of ceramic bearings for the rdx 85.00 can be found here.
http://www.kgbracing.com/redstarbearings.php
i know josh and he is a good guy..price will be hard to beat also.
UCHEATULOSE is offline
Old 10-20-2005, 06:32 PM
  #3827
why does the diff screw break????? Carpet spec means foam tire and 19 turn is nothing special to rip the screw in half. Maybe this was posted before, but I just got mine and after 10 runs the front diff just went see-ya and broke in half.
burm is offline
Old 10-20-2005, 06:46 PM
  #3828
EricO3's Avatar
You probably wrenched that sucker down a little too tight. Did you tighten it just until it wont slip?
EricO3 is offline
Old 10-20-2005, 06:54 PM
  #3829
imprsme's Avatar
Trader Rating: 76 (99%+)
I have been running the car for almost a year and have had not screws break. I too would think that it is from over tightening.
The Corally diffs in my opinion, take alittle more care when building, but when done right.....SWEET! I didn't rebuild mine for almost 4 months and they didn't need it then I just "freshened" them up for the nats.
Try using 6 cone washers the next rebuild. That will allow you to run the diff alittle on the tight side. It also allows for a finer adjustment.
imprsme is offline
Old 10-20-2005, 10:35 PM
  #3830
litespeed-dom's Avatar
Well, I broke one last weekend and whether or not some point in time I cranked it too much with my kungfu grip, that's another story.
Regarding getting the busted diff screw out.... I was on the phone ordering replacements parts for that with Jeff Brown the other day, I told him how I got the black plastic piece out.... and I'll let you guys know now.
If you are smoker, you are set... If not, go find a smoker buddy, borrow his lighter. Put a wrench across the diff 1/2, so you don't burn yourself, use the lighter to heat up the aluminum diff 1/2, the aluminum will expand faster then the plastic, and the black plastic "nut" should pop out fairly easily with some help after a minute or so of "cooking up". Then just spray the hot diff 1/2 with your trusty motor spray to cool off. That's what I did on Saturday when I had to get the busted screw out of the black plastic "nut".
Dom
litespeed-dom is offline
Old 10-21-2005, 08:31 AM
  #3831
Mr. Shookie's Avatar
Dom
Ok what is the part number for the black plastic nut??????????????
Cause I have three diff halfs with broken screws in them....And I could use them again.........
Don't ask how I broke three...ugly story and it was all about my mudd grubbers tightening too much in a hurry....while the diff was self loosening...
Those C clips need to be seated perfectly or that will happen....Expencive problem solving but now it is done...
-Shookie <><
Mr. Shookie is offline
Old 10-21-2005, 08:37 AM
  #3832
Turbonium's Avatar
Trader Rating: 27 (100%+)
i dont think you can buy it by itself.... in the manual, it is listed with the short diff half. unless there is a secret #, (cough) Jeff B. (cough)....
Turbonium is offline
Old 10-21-2005, 09:01 AM
  #3833
yeah, unfortunately you can't just buy that black plastic piece by itself....
Dom
Old 10-21-2005, 09:21 AM
  #3834
Just got off the phone...they are working on it...Or at least trying to find out if they can get them from Holland.
Lets all pray and hope that that happens and the new diff screw that shoudl be around soon...
Then everything will be right and good in the world....
-Shookie <><
Dom
Old 10-21-2005, 09:22 AM
  #3835
-Shookie <><
Excellent news Shookie!!!
Dom
Old 10-21-2005, 09:24 AM
  #3836
In deed....Excellent....
Now if I can get rid of those pesky gremlins that mess with my setup while I am watching the heats before mine...I tell you they really do some silly things...Hehehehehhehe
-Shookie <><
Dom
Old 10-21-2005, 10:34 AM
  #3837
rayhuang's Avatar
Hey guys,
What size or number Torx bit is used on this car? Is it a 10?
Thanks,
Ray
rayhuang is offline
Old 10-21-2005, 10:50 AM
  #3838
Jeff Brown's Avatar
Originally Posted by rayhuang
Hey guys,
Thanks,
Ray
Yes it is.
Jeff
Jeff Brown is offline
Old 10-21-2005, 10:52 AM
  #3839
squarehead's Avatar
Trader Rating: 75 (100%+)
Yup, T10.
[edit: too many windows open, too slow to respond. ]
squarehead is offline
Old 10-21-2005, 10:55 AM
  #3840
wallstreet's Avatar
Trader Rating: 20 (92%+)
any hopes for the iic setup jeff?
wallstreet is offline
