Old 10-05-2005, 02:50 PM   #3586
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i think i kept my last broken one... and i know a buddy here broke one as well.. ill see if he still has his.
Wes
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 10-05-2005, 03:02 PM   #3587
litespeed-dom's Avatar
Wes
Thanks Wes! Let me know.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 10-05-2005, 04:55 PM   #3588
stegger's Avatar
Does anybody know Jeff Cuffs stock setup for the Vegas IIC, what foams,gearing,motor car setup.... Thanks guy's
stegger is offline   Reply With Quote
Old 10-05-2005, 05:53 PM   #3589
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Stegger, you got PM.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 10-05-2005, 06:02 PM   #3590
T1Raycer's Avatar
me too i want the setup of Jeff Cuffs hehe!!
Later!
T1Raycer is offline   Reply With Quote
Old 10-05-2005, 07:40 PM   #3591
syndr0me's Avatar
Trader Rating: 32 (100%+)
Dang, first a super secret top deck* and chassis, then withholding the setup. You guys are hardcore.
*It said Corally USA on it, so I'm not buying the "something he's trying on his own" line. :-D
syndr0me is offline   Reply With Quote
Old 10-05-2005, 08:16 PM   #3592
syndrome, I guess that means you want the setup ey?
BTW, think what you want about the carbon fiber stuff, it is just things he's trying out.
USVTA Member #211
Old 10-05-2005, 09:49 PM   #3593
allright heres the low down on the chassis, top deck and towers. The chassis is something i wanted to try. it has the the batts not cut all the way thru to provide a more consistant flex to the chassis. I played around with batt location. The top deck is a thicker top deck that i had made up with the corally usa logo in it. The towers have diff arch to the shock location and acouple other things. My setup was teh same as the birds thats on the site except i ran the option piston, 30 in the front and 24 in the rear. any other questions feel free to ask. lata guys
jeff
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 10-06-2005, 12:00 AM   #3594
syndr0me's Avatar
Hahaha, I'm just giving you guys a hard time. Thanks for the info Jeff, you pretty much ruined my conspiracy theory. :-D I've been having a lot of luck recently with your Snowbirds setup.
Old 10-06-2005, 04:26 AM   #3595
stegger's Avatar
Default Cuff's setup
Brian you have pm
Old 10-06-2005, 10:17 AM   #3596
Brad_C's Avatar
Default ???
What size is the bearing used for the aluminum stearing knuckle?
The rear hub bearing fell out when I was taking the axle out but the outer race is still in the hub. Has anyone had this problem? Does anyone know how to get the race out of the hub?
Brad_C is offline   Reply With Quote
Old 10-06-2005, 10:37 AM   #3597
Hey Brad,
If you can't tap the race out from the other side, here is a method.... one we use to take the bearing out of a crankcase....
Since the rear hub is aluminum, the race of the bearing is steel....
Take all the setscrew, ball and nut off the hub, put it in your oven at 400 degree (don't let Tiff knows), put it in there for about 12-15 mins, since the aluminum will expand quicker then the steel, the bearing race should fall right out, if not then give it a little help by tapping it on your wooden cutting board (again, don't let Tiff knows). If you need to use too much tapping force to get it out, then put it back in the oven for a bit longer....
Key thing is it should be able to fall out very easily. If not, that means it isn't hot enough. 400 degree isn't going to hurt it either.
But if anyone else has a better idea, I'll love to hear it too.
Dom
Old 10-06-2005, 12:15 PM   #3598
Brad_C's Avatar
Default Will Do
I will give that a try. Do you happen to know what size bearing goes into the aluminum stearing block?
Old 10-06-2005, 12:19 PM   #3599
5 x 9
DOTMAN is offline   Reply With Quote
Old 10-06-2005, 12:20 PM   #3600
If you are talking about the little ones where your "king pin" goes into, I believe they are 3x6mm
Dom
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
