Old 09-27-2005, 01:06 PM   #3511
stiltskin's Avatar
Trader Rating: 102 (100%+)
Sorry if this has been asked before. I've heard that the 1.3 pistons are "smoother". If I'm running 60/40 weight oil f/b with the standard pistons, what oil is similar with the 1.3?
stiltskin is offline   Reply With Quote
Old 09-27-2005, 01:43 PM   #3512
Jeff Brown's Avatar
I would say it is AT LEAST 70/50, perhaps even 80/60 to compare to the 0.9mm holes. I think you should stick with what you have or perhaps drill the 0.9mm holes to a No. 56.
If you have a newer kit you may already have the 1.3mm pistons as in the last month or so the kits have had them included.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 09-27-2005, 01:47 PM   #3513
rayhuang's Avatar
For what its worth-I tested front shocks with 1.3mm pistons and 60 wt oil on med/high bite ozite foam tires. I thought I could gain some corner speed via 60 wt oil and stk pistons. I made the chnage and indeed the car would not dig. It also pushed. But I went with it and took the CA off the front tires, sauced more and even wetn as far as going down from a 33lb spring to a 30 lb spring.
I found that with the shocks packed up-your right on the limit of a push and tire size became big. When the tires were 2.25" the car seemed better with the stk pistons/60. But when they got down to 2.17"-there was no recovering from the push. I then went to 50 wt oil and stk pistons and it feels good now.
But-I am pretty sure tht in all but the highest grip-that going back to 1.3 pistons and 60 wt oil is the right choice.
Ray
Old 09-27-2005, 04:08 PM   #3514
Keith Billanti's Avatar
Trader Rating: 15 (100%+)
Jeff
60/50 seemed good when the traction was low at vegas.. once it came up, the car was just obsorbing all of the speed in the turns. 70/50 was better... and if i had another qualifier I would have liked to have tried 80/60..
running the 1.3 pistons. w/57.5 mm tires.
Rick M made the show, he was running .9's w/ 60/40... 56mm tires...
Keith
OUT
Keith Billanti is offline   Reply With Quote
Old 09-27-2005, 04:17 PM   #3515
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
60/40 with 1.3's has been very good from low to high grip. Just ask your Vegas winner
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 09-27-2005, 07:58 PM   #3516
yup 60/40 option pistons, no sway bars4 degrees of castor. no kickup. ultra lows all around the car
Team Associated, Reedy, Tekin, Futaba, Putnam, Protoform, BSR, SXT, Reflex Racing, McPappy Racing, TQ Wire, Swifty Designs
Jeff Cuffs is offline   Reply With Quote
Old 09-27-2005, 09:23 PM   #3517
Jeff or Jeff, what's the best way for setting droop for carpet and can you explain in detail cuase I don't catch on fast. Like...how much do I thight the set screws in the arms. THANKS!
gc2005 is offline   Reply With Quote
Old 09-27-2005, 09:25 PM   #3518
Oh yeah...one more...did you run a fan for the motor?
Old 09-27-2005, 09:37 PM   #3519
no i didnt run a fan. i usally run 1mil in front and 2mil in rear of up travel.
Old 09-27-2005, 11:20 PM   #3520
TLRacing
Todd Hodge's Avatar
Great Job at IIC!!
Todd Hodge
Category Development Manager for Losi and Team Losi Racing
Losi and Team Losi Racing, brands of Horizon Hobby
Team Losi Racing, Orion, Nitrotane, Spektrum, Imagine It Graphics, Bradley Fine Line Designs, and Lunsford.
Todd Hodge is offline   Reply With Quote
Old 09-28-2005, 06:25 AM   #3521
stiltskin's Avatar
Set your ride height first. Then lift the front/back of the car until the tires come off of the table. Measure this "ride height". The difference will be the amount of droop that you have. I run 1mm front and 2mm back.
Old 09-28-2005, 06:27 AM   #3522
stiltskin's Avatar
Thanks. Do you offer any skill with this setup, or am I on my own?
Old 09-28-2005, 06:29 AM   #3523
Andrew_Carter's Avatar
Send a message via MSN to Andrew_Carter
Hi guys
Wonderd if you lot could help me out.
Im on the edge of purchasing a RDX for the new season .I live in the UK so will be buying the UK spec kit.Do you get any roll bars in the kit? also will i get the white pulleys and the newer chassis to allow me to use 3700s?
What extras will i need? Currently my list is-
Black spring set
Spool and pulley
0 degree castor blocks
2 degree castor blocks
6 degree castor blocks
1,3mm roll bar Front and rear
1.9mm roll bar fron and rear
Can any of you suggest anyfing else i will need? Soory about all the questions.
All help is much appreciated!
ToniSport | Yokomo | GavGraphix | MHP
Andrew_Carter is offline   Reply With Quote
Old 09-28-2005, 06:49 AM   #3524
alb
Trader Rating: 19 (100%+)
Will you be running rubber or foam, carpet or asphalt?
My experience with the kit foam/carpet would be the spring kits and the 3.4mm top plate.
alb is offline   Reply With Quote
Old 09-28-2005, 06:53 AM   #3525
alb
The newer kits include the updated chassis, 1.3 pistons, and white pulleys. The swaybars are also included.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
