Old 09-26-2005, 07:54 AM   #3436
rayhuang's Avatar
Apex speed-on my RDX-the electronic side is heavier than the battery side. Heres my tips:
Run IB3800 as they are heavier than GP3300's.
Put more of the weight on the battery side. Usually near the back.
RUn a pack with the rest of the weight in the front then a pack with no other changes with the weight in the back.
Put more stickers on the body or run a custom painted body.
YOu cannot go wrong by putting the weight right down the middle.
The cars so sensitive to set-p changes-this would be a killer test.
Old 09-26-2005, 07:59 AM   #3437
rayhuang's Avatar
More thoughts.
Use lead wheel weights. Right down the middle.
Put a bigger cap on the esc and run dbl schottky's.
Put a fan and ducted mount on.
Old 09-26-2005, 08:40 AM   #3438
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Great tips, Ray.
I will be running 3800s, so the 3300s in there are definitely light. Does anyone know off hand what the weight difference is from one cell to the other? I run a Tekin G10+Pro with Spektrum, so there is no need for diodes and caps at all. I took this opportunity to run a single color, bland body for the first time in my 23-years of racing RC. Good move, huh?
I'm going to go to the auto parts store to get a few packs of lead wheel weights for the center of the chassis. It will be interesting to see how the car balances out with all of that weight on it. I might figure out a mounting setup for a fan for the stock motor, too. That should get me close.
18 quarters... lol.
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 09-26-2005, 08:58 AM   #3439
Send a message via Yahoo to Doug Gaut
Corally does have 8g weights available as well. My rubber tire car was 54g too light for roar rules with 3300s. Cant wait to see how light my carpet car is. I plan on ordering a pallet of weights soon. Corally thought well ahead on weight placement for the milling to be done on the chassis plates and the weights fit perfectly.
Doug Gaut is offline   Reply With Quote
Old 09-26-2005, 09:04 AM   #3440
squarehead's Avatar
That's 13 weights. LOL. Corally thought about it, for sure. They made the car super light, then made weights to sell for a buck a gram. Are there even 13 places for their weights on the chassis?
Everything depends.
Nothing is always.
Old 09-26-2005, 10:06 AM   #3441
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Doug, the thick chassis and upperdeck help with the weight situation a little bit!
With the stock 3 mm pieces I remember having to add a full ounce to be at legal weight for foams
The battery weight helps quite a bit, so weigh it with your 3800's. Other than that, do what Ray said and put some behind the battery and the rest down the centerline of the chassis---there's room.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 09-26-2005, 10:11 AM   #3442
squarehead's Avatar
Yeah, I'm FOUR ounces underweight! LOL. The stack of quarters on my scale made me laugh. I'm going to see what I can do with the lead weights, and I had talked to EA about getting a thick chassis last week, so we'll see how much closer I can get with the 3800s when they come in.
Everything depends.
Nothing is always.
Old 09-26-2005, 10:50 AM   #3443
Yes the carpet car has the 4mill chassis and the thicker upper deck so it will help. I like the fact I can put the weight where I want it.
Old 09-26-2005, 10:55 AM   #3444
squarehead's Avatar
Anyone know the weights of the stock top deck and 2.9 chassis, as well as the 3.9mm and thick top deck?
[edit] I thought the carpet car has the stock 2.9 lower chassis with the 3.4mm upper deck?
Everything depends.
Nothing is always.
Old 09-26-2005, 11:02 AM   #3445
I hope that Corally posts the setups used this past weekend on the site soon. I have been racing at a track in Oklahoma that has more grip than any carpet I have seen. There is absolutely NO slip. Your shoes stick to the track. LOL I have been using one of Simo's mod rubber tire setups for carpet and had great success with it. I would really like to see what the guys used this weekend for mod rubber let alone if anything new came out for stock/19t foam setups.
Old 09-26-2005, 11:29 AM   #3446
Jeff Werner's Avatar
Trader Rating: 15 (100%+)
Send a message via Yahoo to Jeff Werner
I am in the market for a carpet spec Corally.....cannot seem to locate any....and guidence would be great.
Doug- Trying to join you on the Corally crew....lol
Jeff Werner is offline   Reply With Quote
Old 09-26-2005, 11:32 AM   #3447
Doug, Cuffs won stock with the same setup he and I had been running with only 2 small changes to suit the track! You're already good to roll for foam!
USVTA Member #211
Old 09-26-2005, 11:34 AM   #3448
Looking at the pic of Toso's pits....who made his pitboard....it did not look like a Mc$....
THanks
Jeff
Old 09-26-2005, 11:36 AM   #3449
forty6's Avatar
Is Cuffs running a plain jane carpet spec?
forty6 is offline   Reply With Quote
Old 09-26-2005, 11:39 AM   #3450
We're running the carpet spec with the carpet chassis and low roll blocks.
USVTA Member #211
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
