Old 09-25-2005, 08:19 AM   #3421
squarehead's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Hey, cool avatar!
Something of note, guys. In the kit I am currently building, I disassembled the shocks in order to hand drill the piston holes to 1.3 mm, and guess what I found? The shocks already had the 1.3 pistons in there to begin with. I thought I may have mis-measured my drill bits, but when I opened the 4th shock in the kit, I found it to have the .9 mm hole piston in it.
Also, my UK-spec kit had the 75% extra stiff arms in it, too, making the silver spring kit and 3.4 mm upper deck the only real differences between the UK kit and the carpet kit. Anyone not planning on racing foam tires would be best off buying the $50 cheaper UK kit instead, and then the black spring kit ($17). I took my extra cash and put it into a Corally tool kit.
Nice running changes on the Corally RDX. Very cool.
So far, I am utterly impressed with just about everything, with few exceptions.
doug
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 09-25-2005, 09:57 AM   #3422
forty6's Avatar
Apex, where did you get the UK spec? Is it readily available in the US?
forty6 is offline   Reply With Quote
Old 09-25-2005, 10:30 AM   #3423
squarehead's Avatar
I believe that both the UK and the US-spec base kits are readily available in the US as far as I could tell. I got mine from Superior Hobbies in Florida, but I know Stormer and EA Motorsports both had them. It was $400, even. The Carpet kit was sold out everywhere I tried to find it, and after looking at the real differences in all of the kits, I realized that I still needed the black spring kit for rubber tires (the Carpet kit comes with the silver firm spring kit) anyway. I couldn't use the silver springs, and the 3.4mm upper deck is only $24. I had heard rumors that all of the kits had the 75% arms so I rolled the dice on that one. They were in my kit, too.
I'll save my pennies for the 3.4 mm top deck and 3.9 mm chassis should I ever decide that I need them, but to tell you the truth, this car is mucho-stiff as it is with the stock configuration. The only thing I could see the 3.9 chassis really changing is lowering the roll center more (another 1 mm lower). Still, it's an awfully pretty piece of jewelry.
Everything depends.
Nothing is always.
Old 09-25-2005, 07:46 PM   #3424
rayhuang's Avatar
The more i run tis car the more I like it. It works in mysterious ways a times, but its fast.
But I am having a problem and i need help. I canNOT build these shocks to save my life. Everytime I build them - I see oil leaking out of the cap and when I work the shock shaft-the bladder gets sucked into the body or when I take off the cap-the top of the bladder is filled with oil. or-out of the blue a shock that has been fine for 1000 laps all of a sudden is covered in oil.
I will let evereyone assume I am a newbie-so fire away-I need help. I am pissed at myself for not beiing able to solve it on my own and at the darn shocks too. What am I missing?
Ray
Old 09-25-2005, 07:56 PM   #3425
Send a message via Yahoo to Doug Gaut
Not only does the RDX work great on carpet it also works great on super high bite concrete. It now holds the current stock and 19t lap records at Enid R/C Speedway on the current layout. Thanks Corally!
Doug Gaut is offline   Reply With Quote
Old 09-25-2005, 07:56 PM   #3426
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
OK...here's how I build mine:
1. Pull the shock shaft all the way out
2. Fill the body with oil until you can just see it level with the top of the body
3. Work the shock shaft up and down a few times to get rid of air bubbles---the big ones will come up immediately and the small ones will gradually work their way up
4. Put the bladder on, a little oil may bleed over, but not much
5. Screw the cap on
6. The shock should have a small amount of rebound and should come out slowly
7. Done!
If it rebounds too fast, unscrew the cap a bit and compress the shock so that some oil comes out, then try again.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 09-25-2005, 07:58 PM   #3427
Default BIG PUNN
big pimpin for team corally usa chris tossolini puts the smack down with top ten finishes in all classes...the E man pulls out all the stops going the extra lap in stock rubber to TQ and win ...WORD homie....big game in 19 rubber getting fourth got skills on the rug dude ...next stop florida team corally full hit ......
lickrim is offline   Reply With Quote
Old 09-25-2005, 08:02 PM   #3428
rayhuang's Avatar
5. Screw the cap on
7. Done!
Brian-I swear thats what I am doing I am going nuts.
Old 09-25-2005, 08:26 PM   #3429
Trader Rating: 14 (100%+)
Ray:
Hi,
Check the bladders for any slight misformations around the sealing edges.
"BURP" your bladders (like you did with the plastic Xray shocks)then follow Brian's instructions. (mine leaked until I burbed them) also check the shock caps.........mine seem to loosen up......but I really dont crank on them either.
Brain:
I'm liking the car to a point. it's still dumping on me in the corners. but then again I drive hard into the corners. I haven't picked up the thick chassis/top deck yet either. I'll run it some more thinking about a sway- bar........ but really don't want too. (old skool kicking in)
Team Tekin, KoPropo, Power Push Batteries, Tempgun.com
PROTECT ME FROM THE THINGS I WANT.
THAT WHICH FEEDS ME DESTROYS ME.
Life is short - live it! Your only old when your dreams are replaced by regrets.
TimXLB is offline   Reply With Quote
Old 09-25-2005, 09:40 PM   #3430
Tim, do you have the low roll blocks yet?
USVTA Member #211
Old 09-25-2005, 10:30 PM   #3431
imprsme's Avatar
Trader Rating: 74 (99%+)
I too had a problem with oil over fill! LOL
Just a little trick someone showed me... When you fill the body with oil and them place the bladder on top, use your pinkie to push down in the middle of the bladder. it may take a couple of times to get it to "SEAT" really well.
After I started doing this I have had NO problems with my shocks. Heck I just rebuilt them for the first time on over two months. I wouldn't have done them then...but I was rebuilding the car for the nats.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 09-25-2005, 10:46 PM   #3432
Brian:
Hi,
No not yet. I did borrow a set for a couple or weeks though. worked good... but I think I need a bigger track to work on as the one now is a sub 8 second lap in stock with a purple endbell from Cleveland last year. I really haven't done any tuning on it. besides we only get 4 hrs to race for 15 bucks leaving no time to test.
so I'm waiting for Lansing to open up. where we can race and test all day. I feel I'm not giving the car a fair chance now. I'll get the low roll blocks and go from there......you'll be hearing from me...........alot
Old 09-25-2005, 10:57 PM   #3433
Just do what Tosso, Seemu and Sakke do...run Tamiya shocks...
Carbuncle is offline   Reply With Quote
Old 09-26-2005, 07:31 AM   #3434
squarehead's Avatar
Hey guys, quick question for all of you.
I just scaled my finished and race-ready car, and it came in at 1435 grams or just about 50.6 oz, with transponder. I'm 100 grams or ~3.4 oz. too light for the All Star Carpet series rules.
I measured out 100g of lead and I am shocked the car is THAT light. Where are all of you guys stashing weight in this car? Do the Corally weights come in anything larger than the 5g weights? I'd need 20 of those things in the car!
Everything depends.
Nothing is always.
Old 09-26-2005, 07:48 AM   #3435
squarehead's Avatar
For reference, 100 grams is about 18 quarters. Where the hell am I gonna put $4.50 in quarters?
Everything depends.
Nothing is always.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
