Old 09-13-2005, 10:18 AM   #3346
DougC's Avatar
R/C Tech Charter Subscriber
Thank you very much Jeff. Guess it's time to get that RDX. Thanks again.
DougC is offline   Reply With Quote
Old 09-13-2005, 11:10 AM   #3347
RDX_Charade's Avatar
Originally Posted by Slingblade
I have the carpet spec car and have bben to corally's website. I have searched this forum a bit and i see everyone being refered to use tosolini's setup. My question is......which setup of his is the best for 19 turn? Or does someone have a good one to start with? THANKS IN ADVANCE...BRAD
I always setup my car with faster motor. When your setup is so stable, consistant and fast with for example a 12T. Then it's even better with 19T stock motor for me. On the other hand, if my setup is good for a 19T, it's not always good to drive a 12T. That's my experience. In that way I can understand, why most people use TOSO setup. But mostly the RDX is always fast and easy to drive.
RDX_Charade is offline   Reply With Quote
Old 09-13-2005, 04:16 PM   #3348
Glowster21's Avatar
Trader Rating: 116 (100%+)
Just mounted the new Novak GTB Brushless with the Velociti 5.5 motor...Wow is that a tight fit!! Am I going to run into any strange problems with the receiver on top of the servo? The ESC is about 2x the size of my VFS1 Pro and I couldnt make it fit even with the receiver on it's side. Any other suggestions? Servo is a Hiec HS 5925 MG woth an M8 stock 27mhz FM receiver.
Thanks,
Joe
Glowster21 is offline   Reply With Quote
Old 09-13-2005, 04:17 PM   #3349
rayhuang's Avatar
Thanks,
Joe
There should be no problem at all with running the receiver on top of the servo.
Theres really no other solution than what youve got for installation.
Old 09-13-2005, 04:22 PM   #3350
Glowster21's Avatar
Cool
Thanks Ray!! I'll let everyone know how the setup runs after Thursday night. I'm going from a Putnam Ti 7x2 Brushed to the Velociti...Should be interesting.
Old 09-13-2005, 04:27 PM   #3351
rayhuang's Avatar
I got to race against the prototype system a few months ago, but in 12th scale. A brushed motor won the race, but it was fast. Acually too whicked for a 12th scale. I am assuming or best guessing it was about the equivalent to the 5.5.
So anyways-laptimes between the brushless and brushed were very close. SO that says a lot for the GTB system. HAVE FUN!!!
Old 09-13-2005, 06:41 PM   #3352
forty6's Avatar
so the US carpet spec has thicker upper and lower plates already?
forty6 is offline   Reply With Quote
Old 09-13-2005, 07:02 PM   #3353
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
No, the Carpet Spec car comes with a 3.4 mm upperdeck as opposed to the UK/US kits' 2.9 mm.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 09-13-2005, 07:31 PM   #3354
CandyMan's Avatar
The lower plates are the same on all RDX kits.
CandyMan is offline   Reply With Quote
Old 09-13-2005, 07:46 PM   #3355
rcgen's Avatar
Thanks,
Joe
I just received mine and was wondering where everything going to go. I'm going from the gtx to the gtb should be real fun. Can you post a pic of your setup? I really don't want to mount the receiver on top the servo....
rcgen is offline   Reply With Quote
Old 09-13-2005, 07:54 PM   #3356
rcgen's Avatar
Never mind about the pic...I saw it at gtb side...
Old 09-14-2005, 06:58 AM   #3357
Glowster21's Avatar
rcgen: I tried everything possible to not put it on top of the servo...It was the only option I was happy enough with. I have seen the receivers on the top deck but that looks even more hack than with it on the servo. I'm going from the super small VFS1 Pro Comp to the GTB so it was system shock for me as I had everything very neatly laid out on the 4mm chassis with all the wiring hidden. I guess if it runs as well as they say it will then I can live with the way it looks under the hood and not cutting a comm every run!
Old 09-14-2005, 12:53 PM   #3358
DougC's Avatar
Ordered my RDX last night. It should be here tomorrow or Friday. Well, I've now decided to sell this car. http://www.rctech.net/forum/showthread.php?t=86341
Old 09-14-2005, 04:12 PM   #3359
squarehead's Avatar
Trader Rating: 75 (100%+)
Send a message via AIM to squarehead Send a message via MSN to squarehead Send a message via Yahoo to squarehead Send a message via Skype™ to squarehead
Ditto. Mine has been ordered, too. It's just a matter of time now. :-D
<happy dance>
Everything depends.
Nothing is always.
Everything is sometimes.
squarehead is offline   Reply With Quote
Old 09-14-2005, 06:12 PM   #3360
Send a message via AIM to aoizip
finally got my carpet kit...
now... anyway i can get rid of those torx screw....
yeah..~ very nice build quality!!!
~Ming
Thanks you Jeff Brown.....
now... Cuff..... you are my part support now....
~Ming
aoizip is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
