Old 09-02-2005, 02:22 PM   #3241
Jeff Brown's Avatar
Yes, bulkheads can bend in crashes. All cars are at risk for that. Easiest thing would be to take off the bulkhead and check it on a flatboard to see if it is bent and wobbles when you tap on it.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 09-02-2005, 03:38 PM   #3242
T1Raycer's Avatar
My first race is september 11th i am nervous dont know why!! it will be my real first race whit my RDX and i will be the only one there whit this car oufff lol whit all those Xray Driver!! i have to do something good to represent RDX hehe!! Wish me luck guys!!
and can someone tell me what droop do to your car?? i would like a simple explanation not something whit specialez word
Later
T1Raycer is offline   Reply With Quote
Old 09-02-2005, 03:49 PM   #3243
syndr0me's Avatar
Trader Rating: 32 (100%+)
Thanks Jeff, guess I'll see if I can shim it out before buying a new one. It has a slight wobble on a flat surface, so I guess it's bent. I checked the holes on the bottom, and they're equally drilled, so that pretty much rules out a manufacturing defect.
syndr0me is offline   Reply With Quote
Old 09-02-2005, 04:22 PM   #3244
T1Raycer's Avatar
really need help here!! i check my diff today and i dont see whats the problme but the diff feel like it have a spring in it!! when i turn it its hard to turn it a moment and after that moment the diff turn itself its hard to explained but i know its not normal because it never did this to me!!
can it be the trust bearing that is broke or something else need help!!
Later!!!
Old 09-02-2005, 04:56 PM   #3245
syndr0me's Avatar
All the times my diff felt like that, the thrust bearing came out in several more pieces than when it went in. I replaced the thrust bearing with one that was properly lubed, and used the ceramic diff balls, and the diffs have been great ever since, which is about 4 months now. I haven't tried ceramic thrust bearings yet, but I may do so down the road when I need to replace the current ones.
Old 09-02-2005, 06:23 PM   #3246
Jeff Brown's Avatar
Later!!!
Check the thrust bearings and make sure they are packed with black grease. But before you remove anything on that diff hub, check to make sure the "snap ring" is fully into the groove. I know this is sometimes over looked and gives people some puzzling diff problems.
Jeff
Old 09-02-2005, 06:24 PM   #3247
Jeff Brown's Avatar
Yeah, shimming it for now should be fine as long as the diff or pulleys are not binded at all.
Jeff
Old 09-02-2005, 07:26 PM   #3248
T1Raycer's Avatar
i clean it whit break clenaner , put some diff grease and i check the ring that tigth the trust bearing there and the ring was not in the litlte crack on one side!!! so everything is fine thanks a lot!!!
Later!!!
Old 09-03-2005, 10:33 AM   #3249
Mission_carbon's Avatar
Guy what will the diffrence make if i make the diff more loose or tight?
Mission_carbon is offline   Reply With Quote
Old 09-03-2005, 12:27 PM   #3250
Jeff Brown's Avatar
Well, I recommend running the diffs so they don't slip. Running a tighter front diff will act more like a spool and take away some steering. Basically which ever end is tighter has less traction due to less diff action.
Jeff
Old 09-04-2005, 09:50 AM   #3251
Ive got another question ive had my RDX for one race meet and it just doesnt seem silent as the other cars all the cars sound the same in stock group B but in A they sound real smooth, i dont think its the bearings because off the motor its really smooth. Ive got a monster stock if that helps, should i get a titanuim pinoin?
Old 09-04-2005, 12:06 PM   #3252
Korey Harbke's Avatar
Motor could just be out of balance and making the noise. My car is dead silent, it's really cool lol.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 09-04-2005, 12:07 PM   #3253
how do i change the balance then?
Old 09-04-2005, 12:22 PM   #3254
You cant really. I guess you could send it to a tuner where they balance motors, and they can recheck it for you. Sometimes motors can come out of balance just by cutting the comm, or dropping the motor (oops!), or even just a really hard impact. It's weird...........
-Korey
Old 09-04-2005, 05:40 PM   #3255
syndr0me's Avatar
What's the right combination of spacers and hexes to get the front of the car to 190MM when using foams? Is it three 1 degree spacers under each coupler and the regular hexes?
Also, I was experimenting with the front sway bar, and I noticed that it obstructs the action of the suspension if the wheels are turned past about the half-way point. Is this normal, or have I done something wrong? I used the shorter bar for the front.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
