Old 08-31-2005, 08:37 AM   #3226
ALL APPROVED's Avatar
Send a message via AIM to ALL APPROVED
thanks jeff for all of your help.... Ben also
For all of your Florida mortgage needs.
www.allapprovedmortgage.com
ALL APPROVED is offline   Reply With Quote
Old 08-31-2005, 10:23 AM   #3227
Korey Harbke's Avatar
The number the setup sheets have for droop is the ride height of the car when the suspension arms are at their full extension. So basically just lift up on the car untill the tires or juuuuuuust touching the setup board, then take ride height while holding the car in that position.
Some of the setup sheets like mine and Jeffs use a slightly different number. We figure out our droop the same way as I just described but we subtract our ride height from it. So lets say we have 7.0mm and our ride height is 5mm. So we do 7.0-5.0 = 2.0mm. This is called 2.0mm over ride height, or "droop". I hope I explained this well enough, I think I confused myself halfway through that lol.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 08-31-2005, 10:50 AM   #3228
Jeff Brown's Avatar
-Korey
AKA 2mm "up travel"
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 08-31-2005, 11:07 AM   #3229
AdrianM's Avatar
Jeff - Are you coming to Speedline this weekend or are you on Summer Sizzler duty?
Adrian Martinez
Old 08-31-2005, 11:24 AM   #3230
Jeff Brown's Avatar
I'm not sure........ I have to work on Rob today to get the final word. I want to come down there obviously.
Jeff
Old 08-31-2005, 02:30 PM   #3231
Rob Phillips's Avatar
I have a LCG I'm looking to trade for a FK05 or preferably a RDX. The car was only ran on carpet for a few packs and is in excellent condition. Included are a fare amount of spares and hop ups. It also comes with everything to convert it to a cmg or sd ssg. If any one is interested please PM or Email me. I have pics. Later, Rob
Team Durango | TrakPower | DE Racing | Futaba | Restricted Paint Worx
Velocity R/C Magazine - vrcmag.com
Rob Phillips is offline   Reply With Quote
Old 09-01-2005, 10:03 AM   #3232
stiltskin's Avatar
Trader Rating: 102 (100%+)
Talking
Don't be a chump. Skip the FK05 and roll the RDX. You wouldn't be on this thread if you wanted an Xray.
stiltskin is offline   Reply With Quote
Old 09-01-2005, 11:12 AM   #3233
AdrianM's Avatar
Jeff
Cool...Todd Hodge just called and said Billy Easton is coming in tonight. Ralph Burch and Jared Scott are coming too. Sedan Mod is going to be hardcore.
Adrian Martinez
Old 09-01-2005, 11:51 AM   #3234
Jeff Brown's Avatar
It doesn't look good for me. I'll be there on Monday though I guess.
Jeff
Old 09-01-2005, 12:09 PM   #3235
hey jeff should I change spur gear or just use stock....
Old 09-01-2005, 12:46 PM   #3236
Jeff Brown's Avatar
You can switch to 64 pitch if you want. The stock gear is fine, i use them. You will want a 75 tooth option from Kimbrough.
Jeff
Old 09-02-2005, 06:49 AM   #3237
stegger's Avatar
Can you give me a start ratio for a monster stock pro,carpet
short to medium size with tight infield,78 spur 48dp?
Thanks for your help....
stegger is offline   Reply With Quote
Old 09-02-2005, 08:56 AM   #3238
Jeff Brown's Avatar
Well, I am assuming foam tires........ I would start at a 22 tooth as this will give you a 1.0 inch rollout which should be pretty good with the Monster.
But yer in the UK and probably Rubber Tires. I would still start around a 22 tooth, perhaps a 21.
Jeff
Old 09-02-2005, 09:42 AM   #3239
stegger's Avatar
Cool
Thanks Jeff, using the RDX in anger on sunday for the first time thanks again
Old 09-02-2005, 01:30 PM   #3240
syndr0me's Avatar
Trader Rating: 32 (100%+)
A few months ago, when I got my Hudy setup station, I noticed the rear toe wasn't equal on my car, even though I had 2MM worth of spacers on both sides. I thought perhaps it was a problem with the holes in the chassis, but when I got the 4mm chassis, it did the same thing. It's off by about .5 degrees from one side to the other, even though the spacers are the same. It's different enough that it's evident when you look at the spaces between the control arm and the shocks in the rear from side to side. I have very little clearance there since I'm running the RPM ballcups, and noticed that one side hits while the other clears the shock just fine. When I look at the chassis from the rear, the one side has the bulkhead snug against the part of the chassis where the milling stops and the chassis is at its full thickness, while on the other side there's a tiny gap. I was able to loosen the side with the gap and retighten it to close it some, but it's still off a little bit from one side to another.
So, all I can figure, is that my right rear bulkhead (the one without the motor mount) is bent or warped. Is that something that actually happens to these cars during a wreck, or could it have been a manufacturing defect? I can balance out the two sides in terms of rear toe, but it would mean using a different number of spacers from side to side, which seems kind of goofy. Should I just replace it and hope the next one is better, or is this within normal manufacturing tolerances?
The holes seem to be drilled evenly (checked with calipers) but it rocks every so slightly on a flat surface. :-(
syndr0me is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
