Team Corally RDX Touring Car >
Old 08-18-2005, 04:50 PM
  #3091
danjoy25's Avatar
Trader Rating: 37 (100%+)
So whats the deal with this?
danjoy25 is offline
Old 08-18-2005, 05:31 PM
  #3092
According to www.tq-racing.com, this car was used a few days ago by Corally's new top driver (Niels) from Holland. He tested a new upper deck and rear bulk head. The two parts featured new symmetrical design (left /right part). you can check the link to the picture in the website showing the difference between the new & older parts
speedart is offline
Old 08-18-2005, 05:37 PM
  #3093
raffaelli's Avatar
So I should wait till we are closer to the carpet season to but the car?
raffaelli is offline
Old 08-18-2005, 05:53 PM
  #3094
litespeed-dom's Avatar
Makes sense, shorter top deck probably yield less flex. However, I'm not sure about the "modified" left bulkhead on the right side with the what looks to be the support cut. But then the idea is obviously still in prototype stage.
Dom
litespeed-dom is offline
Old 08-18-2005, 06:28 PM
  #3095
Jeff Brown's Avatar
If you are waiting for whatever that picture is then you'll be waiting a while. It is pretty easy to do that yourself to a car kit but we have not heard anything about that.
Jeff
Jeff Brown is offline
Old 08-19-2005, 07:08 AM
  #3096
When racing on carpet how much does the ultra low roll center mounts free the car up compared to the stock mounts in the full low position?
Doug Gaut is offline
Old 08-19-2005, 09:39 AM
  #3097
Thraex's Avatar
Dom
The reason that the right (modified) bulkhead is round and doesn't have any support, is because it should act like an absorber in big crashes or large stress moments. That's why it's round, not straight, so it can bent (and bent back in it's orginal shape).
The RDX is a stiff car, and when you have a big crash it will be tweaked or maybe even broken at some point. With this design your car can hanlde the stress moments better. It's exactly like Hot Bodies did with there Cyclone.
Thraex is offline
Old 08-19-2005, 09:47 AM
  #3098
actually, I think more than anything it's because if you don't cut the front support, you can't clear the batteries, for testing sake, they probably don't want to spend the money to completely design and manufacture a brand new bulkhead. Like Jeff said, it's a pretty to do DIY, but then the motor bulkhead isn't necessary cheap.
Dom
Old 08-19-2005, 11:04 AM
  #3099
Victor A's Avatar
The chassis is little bit different to and there is a new upperdeck and you have to tape your batteries like the xray's and tamiya's. The shocktowers are different to. www.rctouring.nl is my website
Victor A is offline
Old 08-19-2005, 11:14 AM
  #3100
rayhuang's Avatar
Two questions!!
#1 SXT on rubber tires and carpet?? Anyone tested it? I am trying to get a rubber tire class at the Gate started. I am not too big on mixing in TQ products on our mostly Paragon infused carpet. I used Jack the Gripper with good results at the TCS race on Ozite-but it didnt seem to soak in that well if that makes sense.
#2 How does the Parma Alfa do on rubber tires on carpet? Which body did Rob run at the Novak this year?
THANKS,
Ray
rayhuang is offline
Old 08-19-2005, 11:17 AM
  #3101
Turbonium's Avatar
Trader Rating: 27 (100%+)
hey Ray... at the Novak on rubber tires, he was running a Mazda6 i think...
i typically run either the Stratus 2.0 or the 3.0 All-Purpose. lately.... rubber tires.
Turbonium is offline
Old 08-19-2005, 11:18 AM
  #3102
rayhuang's Avatar
Thanks. I take it you need more turn in with rubber tires-but less on-power steering?
rayhuang is offline
Old 08-19-2005, 11:35 AM
  #3103
prototype parts... if it will be in production I dont know....
Geforcy is offline
Old 08-19-2005, 12:02 PM
  #3104
Korey Harbke's Avatar
Originally Posted by rayhuang
Two questions!!
THANKS,
Ray
#1) I'll be trying that this weekend. I'll let everyone know how it works out. Paragon anf TQ purple are the compounds that I normally start with. I also clean my tires with WD-40, and let the residue air dry, then apply traction compound 5-8 min before.
#2) Parma alfa doesnt have enough overall downforce for rubber tires IMO. The standard seems to be the mazda 6. If you want something with a bit more steering and a bit freer mid-exit, try the Yokomo Stratus Type E. I know Andrew Cartwright uses the Ride TSX on his 415 here, so that might be something to try as well.
-Korey
Korey Harbke is offline
Old 08-19-2005, 12:55 PM
  #3105
YANMAN's Avatar
Trader Rating: 41 (100%+)
Default Shock Pistons
I am building my new kit and the shock pistons are different. I have 3 with 2 1.3 holes and 1 with 2 .09 holes. Does anyone know if a different piston will work in the shocks. IE. Losi, HPI.... I really want to run it this weekend. Oh, my hobby shops do not have 1.3mm drill bits. Please help.
Thanks,
Tim
YANMAN is offline
