Old 06-21-2005, 02:14 PM   #2566
Jeff Brown's Avatar
Originally Posted by vi3tishduy
Ok, sorry to bother you guys, but, I'm thinkin about getting the RDX, is it durable and a good asphault car? I've heard that the car is very brittle. Please pm me back on you input thank you!
Car isn't any more brittle than any other car in my opinion. The RDX seemed to do pretty good at the Reedy Race with 6 cars in the 19T A-main. It is certainly turning heads on Carpet and Asphalt everywhere it goes.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 06-21-2005, 02:21 PM   #2567
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Does the car tweak easy? And does it come with aluminum steering knuckles?
vi3tishduy is offline   Reply With Quote
Old 06-21-2005, 02:39 PM   #2568
vi3tishduy's Avatar
Also, do bodies really matter that much for the cars performance?
Old 06-21-2005, 02:59 PM   #2569
speedxl's Avatar
R/C Tech Charter Subscriber
The car comes with aluminum C hubs but the steering knuckle is composite. And its quite durable. As far as working on asphalt Jeff Brown said put it right. The car is working and winning everywhere.
As far as bodies yes it does matter what you choose as each model type has different charasteristics (spell?) handling wise. To give you a Idea A mazda six is great for asphalt and the parma alpha is a great carpet body.
Hector.
Pemberton / R1 / All out motorsports / Team Power Push
speedxl is offline   Reply With Quote
Old 06-21-2005, 03:12 PM   #2570
T1Raycer's Avatar
i setup my rdx like the setup from Rob Micheal for carpet racing!! and i want to know which the best betwen short or long link on carpet and wich the best betwen angled or parallel???
T1Raycer is offline   Reply With Quote
Old 06-21-2005, 05:13 PM   #2571
vi3tishduy's Avatar
Whats the spell for the NSX?
Old 06-21-2005, 06:16 PM   #2572
rcgen's Avatar
Sushi -
camber links bottom row 3rd hole going inward
arm mounts both are on the lower one with the front turned up for kickup
I had the shock mounted on the 2nd hole but couldn't dive into the turns like I wanted.
Jeff -
not sure about the hardest but you sold it to me LOL Oh I did tell you I bought the car back in December and you pulled "standard" arms...
Are the 1.3 pistons larger or smaller than the standard ones? I think I'll try the 40/60 oil and see what happens
rcgen is offline   Reply With Quote
Old 06-21-2005, 06:44 PM   #2573
JayBee's Avatar
Trader Rating: 31 (100%+)
Thumbs up
Originally Posted by danjoy25
pics
Thanx for that. How do you attack the problem of the bodypost nuts hitting the wing mounts? -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-21-2005, 08:54 PM   #2574
danjoy25's Avatar
Trader Rating: 37 (100%+)
I always screw the body post nut the other way (flat surface on top) and it just clears the mounts.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-21-2005, 10:04 PM   #2575
Korey Harbke's Avatar
Honestly, I would try moving the front camber links to the upper hole. I think your setup is so soft to the point where it is dumping over and just not working properly. Sounds like you are just tryign to develop more steering. Where in the corner do you need the steering? Off power or on power?
-Korey
Originally Posted by rcgen
Sushi -
Jeff -
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-22-2005, 12:01 AM   #2576
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
i kinda had a q.....
what are most running for oil/spring/swaybar for carpet, foam tires? i dont get to run very much carpet, and i am planning on going to the Vegas race. gonna make a few attemps to get some more rugtime practice, but its at least a 3+ hour drive...
a couple weeks ago, i ran 42lb front, 26 rear, with 45/35 oil, but im guessing the oil is too light? had the 1.9 bar on front, none rear.
car kind of seemed to dive in a little hard on entry, and push on throttle a little...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 06-22-2005, 12:09 AM   #2577
Brian McGreevy's Avatar
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Wes, you got PM.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 06-22-2005, 05:20 AM   #2578
Jeff, and all;
I have been looking at the Reedy race setup posted at Corally.com. Is 20# front and 12# rear springs correct? I have never tried this big of a delta.
Jim D.
ukeejim is offline   Reply With Quote
Old 06-22-2005, 10:18 AM   #2579
Company Representative
CorallyUSA's Avatar
Standard and Narrow Hexes
Regarding our hexes. We have heard of some people breaking the hexes under impact and the only thing we can assume is that the hexes are cranked down on. Our hexes are not like other manufacturers hexes. They are not designed to clamp together completely, there should be about a 1mm opening where the screw clamps.
Simply slide the hex on and snug the screw. Check to make sure it isn't coming off and then tighten perhaps another 1/4 turn at the very most. Hopefully this might fix some of the problems we have heard about.
Carpet Setups
Chris Tosolini's setup is available on the corallyusa.com website from the ROAR Nationals. Recently added was Jeff Dayger's setup from the ROAR Nationals as well where he used a box stock UK Edition kit.
If the car is diving too much then run longer camber links to keep the car more flat.
Reedy Race Setup
Jim,
I am not sure which setup sheet you are looking at, but any information posted on www.corallyusa.com is straight from team drivers. Anything posted on www.corally.com is not posted by us.
CorallyUSA is offline   Reply With Quote
Old 06-22-2005, 11:12 AM   #2580
litespeed-dom's Avatar
Default Narrow Hex
Well, My original ones I admit that I tigthened them too much. My second sets, I took Korey's advice and just barely snug, when I say barely, I mean BARELY. And that has not solved the issue, they still break on impacts. Even Korey told me he broke his. I think there should be a revised design on those, there is just not enough "meat" on the hex. These are cheap either... $19 retail for a pair. I've gone thru 4 pairs. I'm almost to the point to find other manufacturers' hex to use instead, or just go with the regular hex instead of the narrow ones.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
