Old 06-20-2005, 08:59 PM   #2551
JayBee's Avatar
Trader Rating: 31 (100%+)
Talking
What bodies are best suited for the handling characteristics of the RDX? Guys at the track this weekend said the car looked REALLY good out there with the Stratus 3.0-All purpose body. I tend to like aggressive handling so I'm thinking of putting on a Parma Alfa or Rayspeed Accord that I have. I got a Mazda 6 too but been reading how these don't fit too well. I can't think of too many others to try. What can you recommend? BTW, outdoor asphalt-med. to high grip track... -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-20-2005, 09:12 PM   #2552
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I've used Mazda 6 bodies since I first got an RDX and is very happy with it.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-20-2005, 09:13 PM   #2553
Jeff Brown's Avatar
Depends what you are racing.........
For carpet foam tire I would recommend the Parma Alfa or the Protoform Alfa. I have never run the Protoform Stratus 3.0 (carpet version) but it seems like it would work good.
For asphalt I would recommend the Mazda 6, the Stratus 2.0 and maybe the 3.0 all purpose. Again, I haven't run any 3.0 bodies. I wouldn't recommend the Alfa as that is ANYTHING but aggressive. You could also look at the Tamiya Subaru body, the Yokomo Stratus Type E. They are pretty good as well.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 06-20-2005, 09:17 PM   #2554
JayBee's Avatar
Yeah I got a couple of Stratus E's too...so the Parma Alfa isn't aggressive? Okay. I am racing w/rubbers outdoors.
danjoy- Are your rear bodyposts sticking up through the Mazda's wing?
-JB
Old 06-20-2005, 10:35 PM   #2555
Korey Harbke's Avatar
Yeah, Yokomo E is pretty good actually. Mucho steering!!!! The parma alfa was specifically designed with Foam tire carpet racing in mind on ultra high traction surfaces. It doesn't have a whole lot of downforce, but it;s neutral at the same time. It takes the twitchiness out of the car and makes it easier to drive on the super high traction stuff. On asphalt.... I wouldnt; even bother trying it. Just stick with the mainline Mazda 6, Stratus 3.0, and the other bodies you see being run at worlds or the reedy race.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 06-20-2005, 10:42 PM   #2556
danjoy25's Avatar
The always cut the wing for the bodypost screws to not hit the anything. I will post pics when I get home.
Old 06-21-2005, 03:02 AM   #2557
danjoy25's Avatar
pics
Old 06-21-2005, 10:43 AM   #2558
Does anyone have a pictures or ideas on how to mount one or two motor fans on the corally?? I need to do something to cool my motor down it was running real hot this past weekend....
jkeeton is offline   Reply With Quote
Old 06-21-2005, 11:43 AM   #2559
Default Setup on new car
Hi, I am building a 2nd RDX for my go faster son.
On Page 7 for the front bulkhead, does everybody fit the toe in spacers ? This is for Step1 of bag 3 ?
andy
Andyg01 is offline   Reply With Quote
Old 06-21-2005, 12:35 PM   #2560
for the front toe-in spacers, use even amounts so there is no toe on the arm. It is easier to use the steering link to adjust the toe. Also, with the the toe spacers on the arm, i use enough to spacers to change the width of the car to 190mm, i don't know if you wanna get that involved, but wider is better
Dhartman03 is offline   Reply With Quote
Old 06-21-2005, 12:39 PM   #2561
rcgen's Avatar
Default Front End Help
My front end is bottoming out in the turns and the front tire rims are cutting into the front arms.
Here is my current setup from our state race this past weekend.
40wt oil on all 4 shocks
Standard pistons
19lbs springs rear and 24lbs front.
Shocks are mount on the 3rd hole going inward.
Shocks were rebuilt two weeks prior with no rebound.
I race on mostly flat smoothed asphault with C27 rubber tires.
Any help is greatly appreciated.
rcgen is offline   Reply With Quote
Old 06-21-2005, 01:00 PM   #2562
You might try standing up your shocks more if your in the hole I'm thinking. It just sounds to me like the front end of your car is dumping over. Also try running a bit thicker oil in the front as well. I usually have a 20wt split between the front and rear. (Ex: 60/40, 50/30). I would switch to the 1.3mm pistons as well, it wont really help the bottoming out issue, but it makes the car feel a ton better. Also what roll center(arm mount) setting are you using? Where are your front camber links?
-Korey
Old 06-21-2005, 01:09 PM   #2563
Jeff Brown's Avatar
rcgen.....
which hardness of suspension arms are you running? I used to have that problem but I am not sure how I got rid of it.
I ran 50/40 with 1.3mm pistons and didn't have a problem and 17lb/14.5lb springs. Ben Griffin ran 35wt all around with 1.3mm pistons as well.
I'll talk with Rob and see if he knows anything about it.
Jeff
Old 06-21-2005, 01:23 PM   #2564
vi3tishduy's Avatar
Send a message via AIM to vi3tishduy
Ok, sorry to bother you guys, but, I'm thinkin about getting the RDX, is it durable and a good asphault car? I've heard that the car is very brittle. Please pm me back on you input thank you!
vi3tishduy is offline   Reply With Quote
Old 06-21-2005, 02:03 PM   #2565
Really? I thinkt he car is pretty solid. It works great on rubber tires too, very neutral and balanced. Has alot of hop ups that most cars dotn normally have right off the bat as well.
Jeff- I actutally never thought abotut he suspension arms..... I've only run 75% arms.
-Korey
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
