Old 06-11-2005, 12:05 AM   #2431
syndr0me's Avatar
Trader Rating: 32 (100%+)
Thanks for verifying the part numbers for me, guys. Got the chassis ordered, along with all the other crap to optimize the car for carpet. Now, if only I could drive... :-)
syndr0me is offline   Reply With Quote
Old 06-11-2005, 12:08 AM   #2432
JayBee's Avatar
Trader Rating: 31 (100%+)
Post
syndr0me-
Can you give a break down on everything you ordered? I'm trying to set up a carpet car order. -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 06-11-2005, 09:01 AM   #2433
Jeff Brown's Avatar
SRC79182 is the dogbones and SRC79189 is the steel blades.
i wouldn't worry too much about the side to side play on the layshaft as it pretty much self centers. I probably have like 1mm or so. I haven't checked it recently though.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 06-11-2005, 09:25 AM   #2434
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
hey Jeff... i think i saw a pic of your car a while back, and noticed that you had the upper tensioner mounted farther back.... does that free the drivetrain up more? just curious....
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 06-11-2005, 09:31 AM   #2435
Jeff Brown's Avatar
I don't even use a belt tensioner..... so it probably wasn't mine. But, yeah that would free it up. A brand new belt should not need a tensioner. You can put the layshaft all the way up or a tick lower and you should be fine.
Jeff
Old 06-11-2005, 09:34 AM   #2436
Turbonium's Avatar
makes sense... i have been using the same belts since i got it back in Feb., running stock and 19t every weekend. i have the upper tensioner all the way up, and the lower almost all the way up as well. i probably ought to get some extra belts, just in case... maybe next order.
Wes
Team Novak
Old 06-11-2005, 10:42 AM   #2437
JayBee's Avatar
Jeff
Thanks Jeff. What about the side-to-side play in the front and rear pulleys? -JB
Old 06-11-2005, 10:50 AM   #2438
syndr0me's Avatar
JayBee,
I'm by no means an expert, but this is what I've done to my RDX (originally the US version with the one-way) to optimize it for carpet.
Silver Springs (forget the part number)
Front Diff
75% Hard Arms
COR79357: 3.4mm RDX Graphite Topdeck
SRC100: 3.9mm RDX Milled Graphite Chassis
COR79363A "RDX" Battery Strap
8 x COR79121 Low Hingepin Block
I've probably missed something, but those are what I've heard are the essentials for carpet.
Old 06-11-2005, 11:16 AM   #2439
Jeff Brown's Avatar
Well, the diffs themselves shouldn't move. The pulleys will go back and forth a bit, say 1mm. They self center like the center pulley so i wouldn't worry.
Jeff
Old 06-11-2005, 11:24 AM   #2440
JayBee's Avatar
Thumbs up
I think there's some shimming I need to do ... thanks Jeff
How long before we can order the steel blades and doggie bones? -JB
Old 06-11-2005, 03:05 PM   #2441
Jeff Brown's Avatar
If your credit card has room on it call Monday. haha.
Steel Bones won't be available for several weeks as we don't have them yet.
Jeff
Old 06-11-2005, 03:22 PM   #2442
JayBee's Avatar
Jeff
If you're serious, Monday is not a problem. Who do I call, you? -JB
Old 06-11-2005, 05:22 PM   #2443
koabich's Avatar
Send a message via Yahoo to koabich
Originally Posted by syndr0me
JayBee,
Front Diff
75% Hard Arms
Well that's a pretty good start. Nothing more is really needed but I would buy the xtra heavy spring set.
Do you like sway bars? I like a car that turns flatter so i use the heavy ones on both the front and back.
I usually switch between 4 and 6 degree castor blocks as well. But the car should be great as you have it now, maybe just stiffen up the suspension a little (use the RDX Snowbirds,Cleveland and Carpet Nat's setups from the Corally website...those are perfect starting blocks). Heck, you might not want to adjust your car from the posted set-ups.
The one thing some are doing for carpet is lowering the front shock tower to help slam the front body down a little more. This will also alter the roll center.
koabich is offline   Reply With Quote
Old 06-11-2005, 08:45 PM   #2444
Jeff Brown's Avatar
Yeah, you can call CorallyUSA directly if you want and place an order. Just remember we only have the aluminum bones available right now.
Jeff
Old 06-11-2005, 09:22 PM   #2445
JayBee's Avatar
Are these new alum. bones the same strength/material as the origs? -JB
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
