Old 05-30-2005, 07:41 AM   #2251
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
the # on my invoice was...
79363
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 05-30-2005, 11:58 AM   #2252
RDX_Charade's Avatar
It is also possible to run 3700 cells in the old chassis, I fixed it. You can file away something of the Battery Plate Posts (where the cells hit them) with a Dremel. Then you also need to lift up the Battery Strap a bit with some rings under the battery strap posts, otherwise the cells will fit to tight.
But indeed the latest chassis looks even better with that RDX battery strap.
RDX_Charade is offline   Reply With Quote
Old 05-30-2005, 05:37 PM   #2253
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Being a newbie in the Corally brand, whats the lifespan before a new model comes out. Xrays & Tamiya normal have a new TC after 12 months. Just wanting to see if I should wait for the new RDX replacement or get another one.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 05-30-2005, 11:26 PM   #2254
STLNLST's Avatar
Trader Rating: 21 (100%+)
that's 6mo or less on the Tamiya
REMEMBER THE GOOD OLE DAYS..........THEY'RE NEVER COMING BACK SO WE'RE STUCK WITH THE MESS IN FRONT OF US!!!!
STLNLST is offline   Reply With Quote
Old 05-31-2005, 06:19 AM   #2255
cannon's Avatar
Trader Rating: 35 (100%+)
Dan
The older RDX chassis will fit the IB3800 cells between the posts, just. However the battery doesn't totally sit flat in the cahssis but very close
cannon is offline   Reply With Quote
Old 05-31-2005, 07:51 AM   #2256
Big "Thank You" to Rob Michaels from Corally for all his support this weekend at the Reedy Race. A great weekend for Corally and the RDX we took 6 of 10 "A" main spots in the spec class.
Mike Dobbs
barnacle is offline   Reply With Quote
Old 05-31-2005, 08:12 AM   #2257
ground-round's Avatar
Trader Rating: 18 (100%+)
Jeff, Nice showing at the Reedy Race. I saw that you had your car in the A-main after a round or two. Did you change your setup at all, or did you run what is posted on your setup sheet on the corallyusa website? What was the deal with Toso all week?
ground-round is online now   Reply With Quote
Old 05-31-2005, 08:20 AM   #2258
dawgmeat's Avatar
Default 3.9 chassis
Hey I', picking up the carpet chassis from my LHS, will traction be better or suspension more dailed in?
dawgmeat is offline   Reply With Quote
Old 05-31-2005, 08:25 AM   #2259
John Fontaine's Avatar
Send a message via AIM to John Fontaine
Mike - Great job this weekend. I look forward to meeting you at the eXpress PORC. I'll be running my RDX in 19 turn
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 05-31-2005, 08:40 AM   #2260
TJ Bradley's Avatar
dobbs- good job at reedy.
TJ Bradley is offline   Reply With Quote
Old 05-31-2005, 09:15 AM   #2261
gibbous's Avatar
Welp, I'm in the club. It's weird after running a TC3 for so long (BIG ups to my wife for the early Father's Day present! ). My last belt car was the original MR4-TC. Anyway, does anyone have any other build tips to add to the ones below? I'll be getting my one-way kit by Wednesday or Thursday! I'll be racing indoor high traction asphalt and an occasional parking lot. Oh the anticipation...I can't wait!
Originally Posted by rayhuang
Build tips:
1) if your going to run the sway bar-put the hardware on the arms before putting the arms on the car.
2) Agaiin on sway bar-mount the hardware on the top deck before mounting on car. The inserts are friction fit-so take your time getting them in. I got them in as deep as I could and as stright as I could by pressing them in-then I pulled them flush with the screw.
3) buy the diff rebuild kits just in case as they have the very good thrust washer assy in them (copper race).
4) Pull out the thrust washer regardless and heavily grease with AE black grease and reinstall. if its got a silver cage on the thrust washer-keep it as a spare and put the copper one in.
5)Do not overtighten diff-do final tightening in the car. With a blade screw driver-you can adjust diffs on the RDX with the wheels on!!! JUst tight enough that they dont slip-no more.
6)Dont be stupid like me and try and outsmart the intruction manual. I built mine without the spacers on the hingepins and guess what?? I broke three steering blocks and bent two CVD's in less than 20 laps on the track in incidental contact!!
7)to achieve the short camber link position on the front-you will need an extra set of 28mm turnbuckles (79271)
8)Do put on the BRP TC3 bumper and/or the Rubberneck bumper. The stock bumper is junk-unless you run on a track with no boards.
gibbous is offline   Reply With Quote
Old 05-31-2005, 09:19 AM   #2262
imprsme's Avatar
Trader Rating: 74 (99%+)
If you are running indoor HIGH bite traction asphalt got www.corallyusa.com and download the set up of Mark Unrath. That set up will be so close you want know what to do. LOL
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 05-31-2005, 09:46 AM   #2263
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
I am assembling the spur gear/ center pulley and i have 1 extra bearing. Should that be in the assembly? Or should the assembly have just 2 bearings?
wallstreet is offline   Reply With Quote
Old 05-31-2005, 09:56 AM   #2264
Default GOT GAME?
Big shout out to all TEAM CORALLY at the RROC this weekend...six out of ten in the open spec, toso was bringing it hard ....
Bobby J is offline   Reply With Quote
Old 05-31-2005, 09:58 AM   #2265
Send a message via AIM to munrath
Congrats Mike!!!
Tekno RC (RTM) / RadioPost / Tekin / Pro-Match Racing / AKA / PT Racing Oils/Diff Lube
Races for 2015:
PNB, AMS, E-Nats Warm-up, E-Nats, LCRC North East Challenge, RAC, LCRC Halloween, Badlands, ROAR Region 2 Series, and Local Club Racing
munrath is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
