Old 05-26-2005, 07:56 AM   #2221
lazyboy's Avatar
Send a message via AIM to lazyboy
alright thanks,
lazy
Random Guy
FT B4
Sponsored by Axiom Motors
Trackside hobbies
lazyboy is offline   Reply With Quote
Old 05-26-2005, 08:53 AM   #2222
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Originally Posted by Cookie
I just got the motor/battery case and it's very trick, well worth while!
It holds 6 batteries, 4 motors and two armatures, plus it has a small plastic container built in for brushes/springs/washers etc
Awesome!
1 correction, it holds four armatures. It is very nice looking and the foam inside is a better foam than any other I have seen. It works nicely because with two cases it allows me to have a case for my 19T stuff and a case for my mod stuff, and the packs for that class are in the same box as the motors. Also an important factor, is the BLING.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 05-26-2005, 08:56 AM   #2223
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
Yeah there like $40-50 here .
Roberto Falcon is offline   Reply With Quote
Old 05-26-2005, 04:40 PM   #2224
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Are they Corally springs on Toso's car?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 05-26-2005, 04:50 PM   #2225
rcfiend's Avatar
Trader Rating: 30 (100%+)
Originally Quoted by danjoy25
http://rctech.net/forum/attachment....achmentid=72003
I just left the Reedy 1st Day of practice and I believe Rob said those were HPI springs. I had to leave before they went out to try the spring combination, but I will see him tomorrow and see if they worked.
Keith
rcfiend is offline   Reply With Quote
Old 05-26-2005, 05:09 PM   #2226
edseb's Avatar
The rear ones are HPI, but the front are Corally. Don't hold your breath, those guys are trying all sorts of spring combos.
RC Car Action Editor and Photographer
Carl Hyndman
edseb is offline   Reply With Quote
Old 05-26-2005, 11:53 PM   #2227
JayBee's Avatar
Trader Rating: 31 (100%+)
Talking
The RDX is on the way!!!... thanx for all the help fellas -JB
R C 3 G R A F I X _ F U S I O N . G R A P H I X _ S E A T T L E - R/C - R A C E R S _ E M E R A L D C I T Y R C . C O M
A E - 12R5.2 _ S M - REV8 PRO
JayBee is offline   Reply With Quote
Old 05-27-2005, 06:13 AM   #2228
Default RDX vs. Assassin Suspenion Design? are they that different? or identical??????
hello all.....
I wanted to know if there is a huge difference or if any,
the suspension design on the RDX is same as the Assassin????
I had the Assassin last year and got rid of it.....
I know the drivetrain is different, but what about the
suspension geometry/design????? they appear to look
exactly the same........
please provide input......thank you
rclab1 is offline   Reply With Quote
Old 05-27-2005, 06:47 AM   #2229
Default Assassin's Direct Drive more efficient than RDX's?????
also, it seems that the Assassins' Direct Drive set up would be a lot more efficient than the RDX's Drive Train.....
since the belt has LESS gears to go through????
.....if i'm wrong, please explain.....
Old 05-27-2005, 07:08 AM   #2230
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
The RDX has larger pulleys and there for has a more effecient drivetrain. More belt wrap around the pulleys.
tc3stocker is offline   Reply With Quote
Old 05-27-2005, 08:02 AM   #2231
Default more friction?
doesn't that mean more friction? since the pulleys' are bigger and more belt is wrapped around it?????
Old 05-27-2005, 08:18 AM   #2232
The Rear Dif in the RDX is verry light, compered to the assassin But I think the assassin drirect drive is verry effiecient. Because you only have one belt. But the rdx drives so much better, and is verry easy to handle.
Bartwubben is offline   Reply With Quote
Old 05-27-2005, 08:19 AM   #2233
koabich's Avatar
Send a message via Yahoo to koabich
WellI am no expert but I'll try to answer this. With the pulley's being larger, there is more belt wrap and that would notmally lead to more friction. But since the larger pulley's allow for more belt wrap, you can run the belts much looser than you would normally be able too.
Plus with larger pulley's, the belt does not have as sharp of a bend as if the pulley's were smaller in diameter.
The question I have is are the pulley's smaller on the Assassign? I never had one so i don't know. But I can see the direct drive Assissagn being slightly more effecient than the RDX because of the single belt. I just don't think the weight distribution with the motor so far back was too good.
koabich is offline   Reply With Quote
Old 05-27-2005, 09:08 AM   #2234
PizzaDude's Avatar
In its base design the Assissin DD IS definate more efficient, but as mentioned before there is the lighte diff for the RDX.
But the major difference is that the RDX's handling is better and easier to drive (consistent that is) at a lot of tracks, as opposed to the Assassins DD design with its motor at the left rear which CAN (doesn't have to) create a car which is slightly harder to drive.
So If you've to make an easily made mistake it's efficincy just can't bring you the result you need.
Wel just keep in mind that all depends on the track, setup and the quality of a driver.
Especially for mod the RDX is AWESOME.
For spec or stock it depends, the fastest lap would probably go to the Assassin DD, but if the overall result would....
PizzaDude is offline   Reply With Quote
Old 05-27-2005, 01:48 PM   #2235
does anyone know how to take out a bearing outer cover thats stuck on my rear hub ??? ive tried everything but it wont come out or anything..
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
