Old 05-13-2005, 09:03 PM   #2086
Originally posted by tc3stocker
So is there any way you can tell me what those part #'s are?
Also, I don't want to use the body posts it comes with, what are my alternatives?
HPI makes the bomb ones homie
lickrim is offline   Reply With Quote
Old 05-13-2005, 09:06 PM   #2087
You're forgetting the most (well maybe not the most) important part to a good asphalt car: a good setup sheet (and its free!)
Sam Forbes is offline   Reply With Quote
Old 05-13-2005, 09:12 PM   #2088
Jeff Brown's Avatar
I copied them all of off www.corallyusa.com so you can check them out. You can click on "CARS" and "PARTS LIST" and see them all.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 05-13-2005, 09:52 PM   #2089
Just wanted to know what the difference between the US carpet version, one-diff version and the front diff version was. I assume that the latter 2 only have the diffs as the changes?
Rockape is offline   Reply With Quote
Old 05-13-2005, 09:58 PM   #2090
Jeff Brown's Avatar
Originally posted by CorallyUSA
They are all High Performance Kits.........
00166 Standard One-way Kit: one-way, 2 deg caster blocks
00166UK Double Diff Kit: double diffs, 4 deg caster blocks
00167 US Carpet Spec: stiffer topdeck, silver spring set, 4 deg caster blocks
There is only ONE US Spec kit and that is the 00167 which is for Carpet Racing. The Standard kit contains the one-way.
Just choose depending on what you run the most, weather it is asphalt or carpet and then what you like to drive with. If you won't use the one-way ever, then get the UK kit. If you mainly race carpet then get the US Carpet Spec.
Old 05-13-2005, 09:58 PM   #2091
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Go back one page, everything is explained there.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 05-13-2005, 10:01 PM   #2092
tc3stocker's Avatar
Send a message via AIM to tc3stocker Send a message via Yahoo to tc3stocker
can I use Tamiya TB02 kingpins on my RDX
tc3stocker is offline   Reply With Quote
Old 05-13-2005, 10:07 PM   #2093
Jeff Brown's Avatar
king pins? I highly doubt it........... unless you mean hinge pins.
Jeff
Old 05-13-2005, 10:12 PM   #2094
tc3stocker's Avatar
these
http://www.speedtechrc.com/store/ebp...nid=330&id=417
Old 05-13-2005, 10:17 PM   #2095
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
nope... the RDX uses a unique kingpin setup. it threads into the c-hub, with a smooth portion that goes into the steering block.
i highly recommend the aluminum steering blocks, as they are stronger, plus they have bearings in them where the kingpins ride, makes for the smoothest, effortless steering action, i think...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 05-14-2005, 04:10 AM   #2096
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
I second that. It gives a more balance look as the rear hubs are alloy (bling bling bling)
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 05-14-2005, 09:47 AM   #2097
I'm looking at getting the rdx. my questions are:
1. what parts will i need to go racing with? (consumables and options)
2. do other springs fit on the shocks? (what do most people use?)
3. what version should i get if i race only outdoors on larg open tracks with some tight technical turns (asphalt with foams, concrete with rubbers)
4. any issues with the car? (common breakages, problems)
Sorry, have been out of rc racing for over 3 years and just out of touch with everything.
Old 05-14-2005, 09:58 AM   #2098
Jeff Brown's Avatar
1) Typical things........ spare arms, spare steering blocks, spare shock tower, extra 1.0mm shims, black spring set, optional caster blocks, 28mm camber links, optional 1.3mm pistons.
2) The corally ones work fine. Most springs aren't a large enough diameter.
3) 00166 if you like a one-way, 00166UK if you prefer double diffs
4) no major problems
Jeff
Old 05-14-2005, 11:19 AM   #2099
syndr0me's Avatar
Trader Rating: 32 (100%+)
Pick up an extra set of kingpins and shock ball ends while you're at it. The kingpins will work their way out sometimes. Loctite pretty much solves that, but it's nice to have them on hand just in case, since they're a very unique part.
syndr0me is offline   Reply With Quote
Old 05-14-2005, 02:02 PM   #2100
Default Bearing carriers, bearings for spool
Can someone please post the part numbers for the bearings and carriers you need when running a spool? Thanks!
coolrcdad is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
