Old 05-06-2005, 10:10 AM   #1981
I thought this would help UK people. To fit the one way you need holders and bearings. I also note that the one way comes supplied with plastic gear, but the spool does not. - thanks Andy
Andyg01 is offline   Reply With Quote
Old 05-06-2005, 02:00 PM   #1982
ground-round's Avatar
Trader Rating: 18 (100%+)
Any of the Orlando RDX crew going to Speedline this Sunday?
ground-round is offline   Reply With Quote
Old 05-06-2005, 03:41 PM   #1983
Jeff Brown's Avatar
I'll only be practicing on Saturday.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 05-07-2005, 02:55 AM   #1984
What makes of springs are everybody using. I use Losi, with losi cups. On the front I reduce the height of the cup AND link on the bottom of the shock shaft. I have bought one set of Black and silver springs, but really you need to buy a second set, if you want to run same springs front and rear, unless this is not appropriate for the RDX. Also I am intrested to hear what people run in the front ,Diff/Spool/One way. I have used the spool for shiny wood floor and outside tarmac and I thought it worked really well. Thanks Andy
Old 05-07-2005, 06:13 AM   #1985
rcgen's Avatar
I bought the spring kit for the car. There is like 8 different spring rates. As far as the oneway/spool/diff, it all depends on the track. I've been using an oneway since I can get away with it on most of the track I race on. My local track's configuration was changed this week and I tried the oneway and it wouldn't work. I put a spool and I was able to drive a decent line.
rcgen is offline   Reply With Quote
Old 05-07-2005, 06:23 AM   #1986
rcgen's Avatar
I ran with a spool last night for the first time with car and like the last minute of racing my front belt would come off. I raised the spur and place the belt tension like half way. We have a couple on 180s and I think that is where the belt is coming off. Do you want the front belt tight or looser than the rear?
Old 05-07-2005, 07:04 PM   #1987
Jeff Brown's Avatar
Where do you have your layshaft positioned? I run it all the way up and have NEVER used a belt tensioner, and never flipped a belt. Same belts since November last year.
A brand new belt should not require a tensioner. I think people might feel the tensioner is needed as it is mentioned in the instructions. Raising the layshaft up will tighten the front belt.
The rear belt is fine as my 7 turns dont' seem to lack anything. I have only run a spool on the asphalt also.
Jeff
Old 05-08-2005, 07:03 AM   #1988
rcgen's Avatar
The layshaft if halfway with the tensioner half also. I'll move the lay shaft all the way up. It was just weird that it just started coming off at the same spot after I put the spool in.
TJ told me the say thing about the belt and mine was probably just getting broken into.
I'll try give that a try.
Thanks again
Old 05-08-2005, 12:12 PM   #1989
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
Hey Jeff... is the CorallyUSA id Robs? i need to ask him a few q's, and a pm might be easier...
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 05-08-2005, 03:03 PM   #1990
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Wes, Jeff usually = CorallyUSA on here.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-08-2005, 03:08 PM   #1991
Turbonium's Avatar
gotcha... ill probably just call Rob on monday. thanks!
Wes
Team Novak
Old 05-08-2005, 04:01 PM   #1992
Glowster21's Avatar
Trader Rating: 116 (100%+)
Default Duraluminum Arms
Has anyone used the Duraluminum arms yet? Any responses to their performance?
Glowster21 is offline   Reply With Quote
Old 05-08-2005, 07:11 PM   #1993
Korey Harbke's Avatar
I haven't, to me aluminum/duraluminum arms have always been just a eye candy thing to add weight. No real benefit from them really. They are alot stiffer, but they can also bend. It wouldn't be so fun to have a bent arm messing with suspension geometry.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-08-2005, 07:56 PM   #1994
danjoy25's Avatar
Trader Rating: 37 (100%+)
I 2nd that.
Has anyone tried replacing the battery holder with tape system?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 05-08-2005, 08:14 PM   #1995
No, I would think it might throw the weight balance off. you'd have to add a bit more weight on that side of the car to balance it out.
-Korey
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
