Team Corally RDX Touring Car
#1951
Originally posted by BadBoyRC
if you get stuck for a thrust bearing.. the losi one fits.
#1952
Originally posted by litespeed-dom
I copied Toso's car from regionals. He use XRAY front posts, works really well. Plus, XRAY posts comes with nice pivoting body support mounts and foam pads.
Dom
Dom
But i bought my RDX couple weeks ago.. and not driven it at all yet
Hey. Is it good starting point to use Simo`s last year Kissimmee set-up for asphalt, because our rules allow only Take-off cs27 tires.?
#1953
Originally posted by Trinity2
What about new T1 fk one?
#1954
I`m thinking that same, to change them "regulary" ones
BODY: Mazda 6
FRONT:
60wt, 1.3mm piston, -1 camber, 4 deg caster, standard roll blocks, 17lb spring, 3rd hole out on arm, 3rd hole in on tower, 2nd hole top row camber link, 5mm ride height, Spool, 2mm uptravel
REAR:
40wt, 1.3mm pistons, -1 camber, standard roll blocks, 14.5lb springs, shock extentions on arm, 3rd hole on tower, 2nd hole bottom row camber link, 2 deg toe in, middle hole on upright, 5mm ride height, 2mm uptravel
#1955
Jeff
#1956
1.How important is the Belt tensioner on the RDX, is there anyway to tighten or loosen the belts without using belt tensioner.
I know you can slide the spur gear up and down, is that how you loosen the belts.
2.When I slide the gear higher the front belt got tighter, when I slide the gear lower the rear belt got tighter. what is the intention on the spur sliding up and down.
3. I would rather run without the belt tensioner is this poosible.
#1958
Originally posted by Jeff Brown
Depends if you like using a one-way......... which is never fun. Here is my setup for a spool.
BODY: Mazda 6
FRONT:
REAR:
BODY: Mazda 6
FRONT:
REAR:
#1961
1 all the way around.
Steve, did you run that setup? Or just put it into a sheet?
Jeff
Jeff
#1962
I haven't had a problem with the rear belt tension in this position either, and all I pretty much run is 7 turns.
Jeff
#1964
Cool Steve......
I also threw up a quick setup sheet onto the website.
Jeff
Jeff
#1965
