Old 04-30-2005, 05:35 PM   #1891
kartermdb's Avatar
Trader Rating: 15 (100%+)
go up on rear springs or change camber link positions
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 04-30-2005, 07:37 PM   #1892
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
Glowster,
Run Toso's exact setup from the nats first. Fine tune it from there. Your setup seems...strange to say the least. First off, run the right tire setup...cyan/magenta. The softer sidewall of the magenta folds over and has less side bite. Second, NEVER run positive camber, always negative (tires leaning in). Everything else seems ok, but I would try 26 lb rear springs instead of 22 for club racing. Sauce the rear tires, too. My club racing setup is nearly identical to Toso's nats setup but with less rear toe (1.5) and the 26 lb rear springs.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 04-30-2005, 08:31 PM   #1893
litespeed-dom's Avatar
Originally posted by Brian McGreevy
Modeltech,
You can only do that with certain servos. With most servos, including the one syndrome has, the rear of the case will hit the belt if you put the servo behind the posts.
Yup! I run a KO servo and ended up using XRAY servo mounts, it's a tad thinner than the stock ones.... it really doesn't make THAT much different, but heck... I just happen to have an extra pair.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 04-30-2005, 08:53 PM   #1894
Jeff Brown's Avatar
Default Re: Setup Help
Originally posted by Glowster21
Hey out there! i need some setup help if anyone can...I run my RDX at the track where the carpet nats were help, Hobby Chamber, and the rear is too planted. I run with Magenta's in the front and Purples in the rear, No sway bars, 2 degrees positive camber front and rear, zero front toe in, and 4.5mm ride height front and back. 60wt front and 40 wt rear with Toso's spring setup from the nats. 4 degree hub carriers. The back end grips so much I am scrubbing infield speed. I only use paragon compound on the fronts...Any suggestions? Running 19 turn....
Well if the wheels are actually tilted out then I would put in 2 deg of negative camber like Brian mentioned. That change alone will fix your problems. The other stuff seems close enough.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 04-30-2005, 08:55 PM   #1895
Jeff Brown's Avatar
Originally posted by modeltech
Can I suggest that if it will fit (i.e. not foul the belt), move your servo to behind the posts instead of in front how you have it now, the way you have it will result in steering variation in throw rates left and right due to the steering link angle.
I ran my link angled for about 4 months and never had a problem. EPA was only about 4% different which is common. If you want to fix it and you can't swap your servo position, then get an extra pair of the camber link standoffs that are used on the shock tower. It will push it out to a 90 deg angle.
Jeff
Old 04-30-2005, 08:56 PM   #1896
T1Raycer's Avatar
i just build the uk version (my first kit hehe!!) and i wondering what the weigth of the spring that i got whit the kit???? and also whats the gearbox ratio of the RDX??
Later!!
T1Raycer is offline   Reply With Quote
Old 04-30-2005, 08:57 PM   #1897
kartermdb's Avatar
they are 17 lbs springs and the internal is 2:1
Mark Burt
Thanks to:
Old 04-30-2005, 09:06 PM   #1898
T1Raycer's Avatar
thanks for the quick reply!! cant wait to try this badass!!
Old 04-30-2005, 09:11 PM   #1899
Korey Harbke's Avatar
To my knowledge the internal is a 2.0...... unless I've been gearing my car wrong all the time
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-30-2005, 09:27 PM   #1900
Jeff Brown's Avatar
Pay attention Sushi........ 2:1 means 2 to 1 ratio, which means 2.0 drivetrain.
Old 04-30-2005, 09:31 PM   #1901
C'mon, Korey, you're in Calculus like me and you don't know what ":" means???
USVTA Member #211
Old 04-30-2005, 09:35 PM   #1902
oh doooooooood, I feel so dumb lol. *banging head on comp monitor* anyways..... attention should be drawn away from me..... because...... yeah.....
-Korey
Old 04-30-2005, 09:38 PM   #1903
Jeff Brown's Avatar
I took Calc 1 and Calc 2.... I think we went over that far before those classes. haha.
Jeff
Old 04-30-2005, 09:47 PM   #1904
-Korey
Here you go dood!
Old 04-30-2005, 10:52 PM   #1905
T1Raycer's Avatar
whats the thickness of the 2 swaybar i had in the kit???
Later!!
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
