Old 04-26-2005, 09:46 PM   #1846
Korey Harbke's Avatar
Yeah, I'm probably going to start with Jeff's setup. We'll see what happens!!!!
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-26-2005, 11:10 PM   #1847
syndr0me's Avatar
Trader Rating: 32 (100%+)
Help me out with the track width stuff here.
The best I can tell, by default (on a US Spec kit) the rear is 190mm and the front is 180mm. Is that correct? Are you guys using the toe shims to space out the front? If so, how many (and what size) does it take to get the front out to 190mm? Why would a car come different between the front and the rear, when having these two even is supposedly one of the key tuning parameters on a car. Is it okay to use the narrow wheel hexes in the rear to shorten the width so it's even with the front while waiting for front spacers?
syndr0me is offline   Reply With Quote
Old 04-27-2005, 07:20 AM   #1848
Cookie's Avatar
Hi guys,
Just made an update the downloadable SetupMaster program which automatically saves the setup data to a text .dat file in the /data directory under the install location, and this file can be reloaded later to pre-default all the settings, so if you only made a small change to your setup, you don't have to re-key everything!!
Can be downloaded by following SetupMaster link in my signature as before.
Cheers
Andy
Cookie is offline   Reply With Quote
Old 04-27-2005, 07:43 AM   #1849
RCknight's Avatar
Default Can you use AE springs on the RXD?
What are some of the design corks on this car? Just interested.
RCknight is offline   Reply With Quote
Old 04-27-2005, 08:57 AM   #1850
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
from looking at it personaly i dont think so .
Roberto Falcon is offline   Reply With Quote
Old 04-27-2005, 09:02 AM   #1851
Jeff Brown's Avatar
Default Re: Driveshaft Rebuild??
Originally posted by danjoy25
Would you normally just replace the driveshaft bones when rebuilding a driveshaft or must you also replace the couplings and pins? I have notice the holes for the pins are bigger than norm due to wear and is also abit bent due to crashes.
Should be able to just replace the dogbones only.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 04-27-2005, 09:07 AM   #1852
litespeed-dom's Avatar
Default Hex Adapters
Guys,
What other wheel hex adapters can I use (as at temporary solution) besides the stock Corally ones? My fronts broke, guess I might have tigthened them a bit too much...
TIA
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 04-27-2005, 09:14 AM   #1853
Jeff Brown's Avatar
Track width from the factory is 188mm front and rear. Now 10 of our Carpet Spec Kits included the OPTIONAL narrow hexes. Which would narrow the car up to 186mm. The Narrow hexes are each 1mm narrower than standard.
You should be able to put just 2mm shims in the rear to get toe in and be fine. Especially if you have the narrow hexes. You should safely be able to put 2mm of shims in the front end and make width.
For foam tires the offsets are different between JACO and other brands such as PARMA. You will have to double check it.
Jeff
Old 04-27-2005, 09:15 AM   #1854
Jeff Brown's Avatar
Default Re: Can you use AE springs on the RXD?
I think they are too narrow of inner diameter to fit.
Jeff
Old 04-27-2005, 12:38 PM   #1855
ground-round's Avatar
Default Diff Help
I'm having a hard time with my diffs in the car. After a rebuild, I only get about 4 runs out of the diff before it starts getting gritty and nasty. I have ceramic balls, I sand to drive rings with 400 grit to get 'em smooth and I've been using some associated diff lube. What's the deal? I'm assuming its the diff lube. Help.
ground-round is offline   Reply With Quote
Old 04-27-2005, 01:08 PM   #1856
Jeff Brown's Avatar
Default Re: Diff Help
Check the thrust bearings in there and make sure they are copper colored. If not let us know and we can replace them. I would recommend pulling out that snap ring anyways and coating the thrust with BLACK GREASE.
Reassemble slowly..... DO NOT overtighten like other diffs and back off half a turn. Doesn't work that way. I would also recommend having 6 of the beveled washers in there for finer increments on adjustment.
All else fails bring them in and I'll build them. haha.
Jeff
Old 04-28-2005, 07:00 AM   #1857
well the day is finally here for me to get to run my rdx.i cant wait till i get off work to go play...........
bear is offline   Reply With Quote
Old 04-28-2005, 07:47 AM   #1858
new92's Avatar
$5 says you break it at least once....or someone does lol
jk
Grats again man cant wait till another weekend like the last.
new92 is offline   Reply With Quote
Old 04-28-2005, 09:03 AM   #1859
is that all true being serious that the rdx breaks alot and it breaks easiley?
Me and my brother are planning on buying one and hes buying his this weekend so Jeff do you guys have the Uk Spec in stock?
Old 04-28-2005, 09:32 AM   #1860
new92's Avatar
I think they are pretty durable. I was just giving Bear a hard time.
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
