Old 04-26-2005, 06:18 PM   #1831
kartermdb's Avatar
Trader Rating: 15 (100%+)
see im the exact opposite of you guys, i cant run the rear extension, i just hate how it feels, i got the car to work great without them
Mark Burt
Thanks to:
TRINITY - Revtech - Awesomatix USA - Side Piece Racing - Roche RC USA - Darkside Motorsports - Genesis R/C Raceway
kartermdb is offline   Reply With Quote
Old 04-26-2005, 06:51 PM   #1832
Jeff Brown's Avatar
Yeah, but your just weird Mark.......... haha.
I think you can get the car to work without the extentions. Probably not on Carpet, more likely on Asphalt like Mark does. Should balance the car better to start with. I might have to play with that.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 04-26-2005, 07:00 PM   #1833
ALL APPROVED's Avatar
Send a message via AIM to ALL APPROVED
Originally posted by Jeff Brown
BODY: Mazda 6
FRONT:
60wt, 1.3mm piston, -1 camber, 4 deg caster, standard roll blocks, 17lb spring, 3rd hole out on arm, 3rd hole in on tower, 2nd hole top row camber link, 5mm ride height, Spool, 2mm uptravel
REAR:
40wt, 1.3mm pistons, -1 camber, standard roll blocks, 14.5lb springs, shock extentions on arm, 3rd hole on tower, 2nd hole bottom row camber link, 2 deg toe in, middle hole on upright, 5mm ride height, 2mm uptravel
HEY THATS NOT WHAT YOU GAVE ME...... AND YES MARK YOU ARE DIFFERENT...HEHEHE
For all of your Florida mortgage needs.
www.allapprovedmortgage.com
ALL APPROVED is offline   Reply With Quote
Old 04-26-2005, 07:00 PM   #1834
kartermdb's Avatar
Jeff, Rob has my set up if ud like to try it, it prolly wont work well in mod cause i run a diff in the front, but its very basic
and yes i know im weird, but weird is good sometimes, right???
Mark Burt
Thanks to:
Old 04-26-2005, 07:05 PM   #1835
I HAVE HIS SET UP ALSO JEFF HERE IT IS.. GET TO THE TRACK TAKE OUT THE CAR CHARGE A BATTERY AND DRIVE THE HECK OUT OF IT.. THE AFTER 15 OR SO RACES CHECK IT OUT. LOL JUST KIDDING MARK
Old 04-26-2005, 07:19 PM   #1836
kartermdb's Avatar
actually Tim, that sounds about right LOL
Mark Burt
Thanks to:
Old 04-26-2005, 07:51 PM   #1837
ITS ONLY FUNNY BECAUSE YOUR SO DAM FAST..... AND ITS ALMOST HAVE TRUE...HEHEHEHE
Old 04-26-2005, 07:55 PM   #1838
kartermdb's Avatar
im not fast, ur just slower than normal JK
Mark Burt
Thanks to:
Old 04-26-2005, 07:58 PM   #1839
MAYBE ONE DAY I WILL BE LIKE YOU...
Old 04-26-2005, 07:59 PM   #1840
kartermdb's Avatar
no, when i grow up i wanna be just like you
Mark Burt
Thanks to:
Old 04-26-2005, 08:02 PM   #1841
WE ALL CAN DREAM............................
Old 04-26-2005, 08:55 PM   #1842
corallyman's Avatar
Trader Rating: 99 (100%+)
Default Set up info
Jeff,
On your setup info you just listed for Sushi Boy(Korey), what tires were you running? Also could you describe the track a little bit, like was it smooth, or high/medium grip, was it a prepped track? sprayed with anything? Lastly have you thought about anything you might change? I know I'm asking a lot but our outdoor season is just getting started with our recent nice weather.
Thanks,
Steve
corallyman is offline   Reply With Quote
Old 04-26-2005, 08:58 PM   #1843
Jeff Brown's Avatar
Steve,
It was the parking lot out front of Superior. It was sprayed with VHT but it definately wasn't there for the main. The state series uses SPEC tires of CS-27's. Track was definately medium to low in the main. It varied throughout qualifying. I didn't really change much on the setup. I just drove smoother as you never knew what you were getting. Tough to make changes with that.
Jeff
Old 04-26-2005, 09:06 PM   #1844
corallyman's Avatar
Default Info
Thanks Jeff, we have a similar track in our area that your setup might work well at.
Steve
Old 04-26-2005, 09:32 PM   #1845
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Driveshaft Rebuild??
Would you normally just replace the driveshaft bones when rebuilding a driveshaft or must you also replace the couplings and pins? I have notice the holes for the pins are bigger than norm due to wear and is also abit bent due to crashes.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
