Old 04-25-2005, 12:56 PM   #1816
imprsme's Avatar
Trader Rating: 74 (99%+)
Originally posted by Trinity2
Hey there. Any good set-up for rubber tires? For asphalt
Goto www.Corallyusa.com Click on cars then RDX set-ups the South Carolina set up is a GOOD ONE!
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 04-26-2005, 10:28 AM   #1817
Jeff Brown's Avatar
Originally posted by Sushi Boy
So Jeff,
What did you end up running at the recent state race?
-Korey
BODY: Mazda 6
FRONT:
60wt, 1.3mm piston, -1 camber, 4 deg caster, standard roll blocks, 17lb spring, 3rd hole out on arm, 3rd hole in on tower, 2nd hole top row camber link, 5mm ride height, Spool, 2mm uptravel
REAR:
40wt, 1.3mm pistons, -1 camber, standard roll blocks, 14.5lb springs, shock extentions on arm, 3rd hole on tower, 2nd hole bottom row camber link, 2 deg toe in, middle hole on upright, 5mm ride height, 2mm uptravel
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 04-26-2005, 12:59 PM   #1818
Jeff;
or anyone;
How do you measure uptravel (droop?).
Jim D.
ukeejim is offline   Reply With Quote
Old 04-26-2005, 01:10 PM   #1819
syndr0me's Avatar
Trader Rating: 32 (100%+)
I seem to have trouble with my wheel hexes binding if they're pushed in too far. It's easy enough to keep a little bit of play in there so they don't bind, but once I tighten the wheels to the point where they won't wobble, it pushes the hexes in. It's possible to get them all to a point where they don't bind, but it's damn near voodoo, and the balance is easily upset during a wreck, and sometimes under normal running conditions.
Is there some trick to keeping this from happening?
syndr0me is offline   Reply With Quote
Old 04-26-2005, 01:16 PM   #1820
litespeed-dom's Avatar
I put a .2mm shim between the bearing and the hex pin, so the hex have no chance of rubbing on anything.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 04-26-2005, 01:45 PM   #1821
imprsme's Avatar
Originally posted by ukeejim
Jeff;
or anyone;
Jim D.
The way I have been doing it is...
I back the droop screws off of the chassis
Set ride height
Then lift up on the shock tower until the tires just start to unload
Slide the ride height gauge under the chassis and screw the droop screws down until you get 1mm, 1.5mm or even 2mm up travel above your ride height
Ex. if you set ride height at 5mm and you want 1mm of uptravel when you lift up and slide the gauge under you should read 6mm
Hope this helps
AwesomatixUSA
eXpress Motorsports
Old 04-26-2005, 02:34 PM   #1822
Regional Moderator
kansasracer's Avatar
Dom
Syn--
I did this too; I have some shims you can use for tomorrow night!!
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 04-26-2005, 03:08 PM   #1823
syndr0me's Avatar
I guess that means you're back to running carpet tomorrow then? Sounds good, I'll take you up on the offer for the shims, thanks.
One of these days, I'm going to make a "Life with Corally" post about all the quirks I've learned about so far.
Old 04-26-2005, 03:13 PM   #1824
This car is awesome, but does have its quirky stuff.... especially the 4/40-like ball stud with the metric thread!
Dom
Old 04-26-2005, 03:53 PM   #1825
rcgen's Avatar
I've noticed most setups have a thicker shock weight up and stiffer springs up front. What does this accomplish? I am currently running 40wt all the way around with stiffer springs up front. I am assuming it has to do with weight transfer and the reaction of the car as it enters the turns. Am I missing something here?
rcgen is offline   Reply With Quote
Old 04-26-2005, 04:00 PM   #1826
Korey Harbke's Avatar
Set ride height
Hope this helps
Yup, thats the way I do it. If your really picky abotu droop David Jun had a real cool way of measuring droop in the 415 thread. He measure it from the top of the axle to the setup board with some calipers, and it's uber accurate. You can fine tune to make up for the difference between tire diameter in rubber tires and stuff. I usually do this to make sure the downstops are the same on both sides, and then use the way imprsme descirbed to get the actual droop.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-26-2005, 04:05 PM   #1827
Thats what I was thinking. I did try a setup with the same oil and spring all around, but I had problems with the front end wanting to dump over. My guess is because the RDX has the batteries pretty far forward and can make the front end a bit heavy. In order to prevent the front end from dumping over we generally run a slightly heavier setup in the front. Right now on carpet with rubber tires I'm running 22lb springs up front and 17lb in the rear with a 50/30 oil setup. 1.3mm pistons.
-Korey
Old 04-26-2005, 04:12 PM   #1828
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
-Korey
I also think that the rear shock extensions makes the rear suspension harder even with softer oil/spring in the back. I will be trying next race without them and see the difference.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-26-2005, 04:14 PM   #1829
It is true, the further you move your shock out on the arm, the more leverage it requires to compress that shock.
Dom
Old 04-26-2005, 05:02 PM   #1830
I always run the extensions. I did try it without and didn't like it. To me it made the car feel inconsistant.
-Korey
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
