Old 04-21-2005, 11:38 PM   #1801
Trader Rating: 15 (100%+)
Default get the screws
the ti screws from speed tech are killer ...for the price...
car will only be about 5 grams lighter but you can put it where you want it...
AARON YOUNG is offline   Reply With Quote
Old 04-22-2005, 07:26 AM   #1802
koabich's Avatar
Send a message via Yahoo to koabich
Originally posted by BadBoyRC
Here's what you gonna lose..
4 - 5 grams BFD! and the hexes strip out and shear strength is no advantage.
plus you'll lose in the wallet too, I like the torx head they don't strip out as easily as hexes especially if you use locktite
If you strip the hexes on Ti screws, you are either using the wrong size allen wrench or you just should be allowed around any kind of screws at all.
koabich is offline   Reply With Quote
Old 04-22-2005, 09:21 AM   #1803
syndr0me's Avatar
Trader Rating: 32 (100%+)
On your cars, does your diff pulley "wiggle" between the diff halves? Mine does (I've used many pulleys) and I'm wondering if it's normal, or if I've done something wrong. The diffs seem to work okay, but it does seem like the wiggle affects the action of the diff a little bit.
syndr0me is offline   Reply With Quote
Old 04-22-2005, 09:57 AM   #1804
Regional Moderator
kansasracer's Avatar
Syndr0me,
Just give me those white diff pulleys...their no good...
I am watching.....always watching....
kansasracer is offline   Reply With Quote
Old 04-22-2005, 10:57 AM   #1805
Regional Moderator
Hey guys,
What effects does lowering or raising the diffs? I have looked everywhere (including the Xray tuning guide online) and can't seem to find any info.
Old 04-22-2005, 11:00 AM   #1806
Trader Rating: 18 (100%+)
Send a message via AIM to Roberto Falcon
isnt that for loosning and making the belt tighter?
Roberto Falcon is offline   Reply With Quote
Old 04-22-2005, 12:29 PM   #1807
Regional Moderator
On the RDX, you can move the diffs up and down. They don't appear to be there for belt tension. I was thinking they would be there for more roll center adjustment....
Old 04-22-2005, 12:34 PM   #1808
Jack Smash's Avatar
Trader Rating: 29 (100%+)
I'm guessing it has more to do with the height that the torque is applied to the wheel. Take for example a higher rear diff in realtion to CG height, under acceleration you would see less of a tendancy to raise the front of the car, but under breaking it would have more leverage to pitch the nose down. Just my thoughts, not sure if these are the most dominant physics that this change will see.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Old 04-22-2005, 03:51 PM   #1809
koabich's Avatar
Lowering or raising the diffs is not to effect belt tension. The raising and lowering of the layshaft and the front belt tensioner are the 2 ways corally means you to adjust the tension of the belts.
like many here, i am not sure on the physics of raising or lowering the ddiff but from personal experimentation and experience from others:
-Raising the diff offers less traction at that end
-Lowering the diff offers more traction at that end
Hope this helps!
Old 04-23-2005, 02:37 AM   #1810
litespeed-dom's Avatar
Straight from XRAY site regarding Diff height. Now, not 100% sure if this would translate to the RDX, but I would imagine it'll be close. Keep in mind XRAY can only raise or lower the rear diff.
The height of the diff influences the amount of weight that is transferred during deceleration (rear to front) and acceleration (front to rear). When the rear diff is in the high position the torque applied to the diff works on the car at a greater height too. As a result more weight will be transferred between front and rear.
The different settings have the following effects:
- High diff = generally more steering
- Low diff = less steering, more stable
- Middle diff = steering and stability in between High and Low
This setting is best used after you've already achieved a good base setup to fine tune steering and stability.
Dom
Team Kyosho America - Team Br00d Racing - Team R/C Plus - GQ Racing Tyres - Slapmaster Tools - FSX Racing
litespeed-dom is offline   Reply With Quote
Old 04-23-2005, 02:27 PM   #1811
Regional Moderator
Dom,
Thanks for the info....
Old 04-23-2005, 04:42 PM   #1812
Send a message via MSN to Bigger Brother
Hi Guys
I'm about to get a new car, and the RDX is very tempting. Basically I want to know which version of the car would be best for me;
I'm from the UK, and normally race Foams on carpet (not as high traction as you have in the US) as well as outdoors with rubber. I realise to get one car for all conditions will be a bit of a compromise, what do you suggest?
Oli
Oli Meggitt | London, UK
.:. Essex Winter Series .:. CML Racing .:. ToniSport .:. Zen Racing .:. Moorespeed RC .:. OTM Racing .:. RC Racing TV .:. RIDE R/C Scoreboards
Bigger Brother is offline   Reply With Quote
Old 04-23-2005, 04:52 PM   #1813
Korey Harbke's Avatar
Honestly, I think the Dual diff Uk edition would be perfect. It seems to be the most versitile kit of the 3 different versions. Since front one ways are really scary to drive with on foams, and a diff can still work pretty well in most condiditons on asphalt and carpet.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-25-2005, 12:07 AM   #1814
So Jeff,
What did you end up running at the recent state race?
-Korey
Old 04-25-2005, 12:45 PM   #1815
Trinity2's Avatar
Post
Hey there. Any good set-up for rubber tires? For asphalt
Trinity2 is offline   Reply With Quote
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
