Old 04-14-2005, 09:01 PM   #1741
syndr0me's Avatar
Trader Rating: 32 (100%+)
The guys in Okie City run on concrete with rubber I believe. I think it used to by Skidmore's home track. At least one RDX guy in this thread runs there.
syndr0me is offline   Reply With Quote
Old 04-14-2005, 09:48 PM   #1742
Turbonium's Avatar
Trader Rating: 27 (100%+)
Send a message via Yahoo to Turbonium
well, i run at a track in Tulsa, and it was indoor concrete, sprayed with VHT. recently switched to a coating called Skid Not, kinda like asphalt. my oneway setup before the switch was:
1.3 pistons front and rear
50wt front, 40 rear (i think)
20# front springs, 14# rear
front shocks were in 1 hole, rear all out
f camber links 2nd in on bottom, rear 3rd in on bottom row
1 degree camber all around
2 degree rear toe,
2 degree caster blocks
stock hingepin mounts, in the lowest position all around
5mm ride height, 2.5mm uptravel front, 3mm rear
i was using RP Tires, in 24R compound
most of this was from memory, cause we switched about a month ago. took a while to finally get it where i wanted it, but it was good... right after that, surface changed... figures!
Wes
Team Novak
Turbonium is offline   Reply With Quote
Old 04-15-2005, 01:00 PM   #1743
Korey Harbke's Avatar
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 04-15-2005, 01:35 PM   #1744
does anyone know where i can get some blades for the rdx. Nobody seems to have them in stock.
SCOTT HOWARD is offline   Reply With Quote
Old 04-15-2005, 01:47 PM   #1745
Brownie, did you get my e-mail
Currently taking a break from R/C, running 1/1 scale cars, they are cheaper then running Modified TC!!!
retired from RC in 2007, running 1:1 scale now
[email protected]
Greg Anthony is offline   Reply With Quote
Old 04-15-2005, 01:59 PM   #1746
FreqETag's Avatar
Default Blades for the RDX
Excel R/C Hobbies
Chris Jones is great guy to deal with and I know they have what you need.
FreqETag is offline   Reply With Quote
Old 04-15-2005, 05:24 PM   #1747
Does anyone try the front sway bar on the car? It seems to be in the way of steering blocks. Any ideas apart from put an Xray bar up front.
mindrev is offline   Reply With Quote
Old 04-15-2005, 05:47 PM   #1748
imprsme's Avatar
Trader Rating: 74 (99%+)
I have ran the Sway-bar a few times and not had any problems hit anything.
Double check and make sure you have everything installed correctly!
The only problem I can see with it maybe hitting the steering knuckles but you should not have to have that much Dual Rate or EPA in the car.
AwesomatixUSA
eXpress Motorsports
imprsme is offline   Reply With Quote
Old 04-15-2005, 09:06 PM   #1749
I shimmed up the mounts on the arm. No problems with clearance after that.
Mike Dobbs
barnacle is offline   Reply With Quote
Old 04-16-2005, 10:00 AM   #1750
SpeedTech's Avatar
Hi Guys,
Just want to post a quick note that we received more Corally spare and hop-up parts back in stock yesterday and the website has been updated
Steve Wang
>>>www.SpeedtechHobbies.com<<<
SpeedTech is offline   Reply With Quote
Old 04-16-2005, 11:52 AM   #1751
you can run the rear bar and turn the mounts on the arm around and the bar will go over the dog bone and run in the front of it.
Chris Tosolini is offline   Reply With Quote
Old 04-17-2005, 06:53 PM   #1752
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Wishbones ????
Anyway you can tell what lower suspension wishbones you have? I got a 2nd hand car with a few spares but not sure if they are the soft ,hard or X graphite ones.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 04-17-2005, 06:55 PM   #1753
Jeff Brown's Avatar
X hard = 75% graphite
Hard = 50% graphite
Med = 20% graphite
I think there is a softer one, which is basically machined delrin. But I haven't seen that one for a while.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 04-17-2005, 07:14 PM   #1754
danjoy25's Avatar
Hard = 50% graphite
Med = 20% graphite
Jeff
Is there a mark that says what they are or is it done by feel. Got an arms with no packet and can't tell if its med or hard.
Old 04-17-2005, 07:21 PM   #1755
My 75% arms have 75 molded right into them...... I dunno abotu the others though.
-Korey
Corally CCT Pan-touring car biker R/C Items: For Sale/Trade 4 03-02-2010 09:21 PM
Corally CCT Pan touring car biker R/C Items: For Sale/Trade 3 11-05-2003 07:24 AM
Corally F1 w/touring car setup froghead R/C Items: For Sale/Trade 6 10-29-2003 08:10 PM
New Corally Touring Car At Nurnberg JANTLE Electric On-Road 117 04-30-2003 05:23 AM
Brand New Corally C4.1 Touring Car HauntedMyst R/C Items: For Sale/Trade 5 10-25-2002 08:40 PM
