Team Corally RDX Touring Car >
Old 03-27-2005, 08:14 AM
  #1531
BadBoyRC's Avatar
Trader Rating: 2 (75%+)
104t is the biggest if you use rear sway bar or els it will hit
BadBoyRC is offline
Old 03-27-2005, 10:48 AM
  #1532
Originally posted by syndr0me
Are there tricks to building the RDX's diffs to help keep them consistent? It seems like I have to clean/re-lube them after each race day (they get "crunchy"), and they never seem to be consistent between cleanings. I'm not exactly a n00b, I've built many different diffs in many different cars, and have never needed to pay so much attention to the diffs as these. I've checked all the bearings, and they seem fine.
i built my diffs like any other cars diff and they are perfect. No re-lubing or cleaning and they are perfectly smooth and spin like a 1/12 diff and are locked up.
I found if you clean the diff rings and make sure there is plenty of diff lube in the rings and balls and black grease in the thrust bearing is the key for me. Tighten the assembly till you get a small amout of diff action and "work" in the diff by pushing the rings into the balls, then tighten it a 1/8 turn and keep doing that till the pulley can't spin. Hope this helps
DH
Dhartman03 is offline
Old 03-27-2005, 11:35 AM
  #1533
Default Prices
What is the cheapest price I can expect to pay for an RDX in the US?
Also can anyone recommend a Hobby store in the Manhattan area that may stock them please?
(I'm from the UK but my brothers is going to NY in a couple of weeks)
Rich_p is offline
Old 03-27-2005, 03:00 PM
  #1534
Originally posted by Brian McGreevy
Korey...I got solutions
An interesting thing I played with today was the layshaft height. If you raise it all the way up, the car frees up significantly.
Another thing, does anyone know what is the biggest 64P gear that can go in the car? I'm thinking around 112...
Be care full not to over tighten the rear belt causes it to a lil enefficient small note
drmellking is offline
Old 03-27-2005, 04:29 PM
  #1535
FreqETag's Avatar
Default RDX in the US
I got mine from Excel RC hobbies for $399.
Nice guy, perfect product, reputable dealer.
Excel R/C Hobbies
Not in the Manhattan area but online...
FreqETag is offline
Old 03-27-2005, 05:03 PM
  #1536
i run my pulley right in the middle of the slot. keep an eye on the rear belt you dont want that to tight. i put the ceramic balls from corally in my diff and i havent rebuilt it in months. Its due tho. When the diffs starts to get gritty most of the time its the thrust bearing going bad.
Jeff Cuffs is offline
Old 03-27-2005, 07:12 PM
  #1537
Brandon Melton's Avatar
Default New Products
Jeff Brown- I was looking through the 2005 product update brochure. Is that stuff available now, and if not, when do you guys expect it. RP tires, Hauler bag, motor cases, etc..
Brandon Melton is offline
Old 03-27-2005, 07:23 PM
  #1538
Jeff Brown's Avatar
Brandon...... we won't see those products until Mid-April probably. I'll have to double check with Rob.
Jeff
Jeff Brown is offline
Old 03-27-2005, 07:57 PM
  #1539
Korey Harbke's Avatar
Yeah, I'd have to say that hauler, the little assortment boxes, and battery/motor cases look real trick.
-Korey
Korey Harbke is offline
Old 03-27-2005, 08:17 PM
  #1540
Jeff Brown's Avatar
Well, I know we got a few of the little boxes in. Not sure if we got the Cases in. Like I said, I'll talk to Rob to see exactly what we have.
Jeff
Old 03-27-2005, 09:03 PM
  #1541
Turbonium's Avatar
Trader Rating: 27 (100%+)
amen to that! i like the new hauler bag and battery cases... i was hoping to get the new catalog in the mail. not yet, tho. i need to get another order ready anyway...
Turbonium is offline
Old 03-27-2005, 09:19 PM
  #1542
Brian McGreevy's Avatar
Badboy,
I'm not using a rear bar...never have, and probably won't for foam tire.
drmellking,
Raising the layshaft will make the rear belt looser.
The car was really, really fast last night, best laptimes, TQ and win, and never faded off.
Brian McGreevy is offline
Old 03-27-2005, 10:05 PM
  #1543
Jeff Brown's Avatar
My layshaft is all the way up and has never moved. Plus I don't have a belt tensioner. I know....... i must be odd.
Jeff
Old 03-28-2005, 05:41 AM
  #1544
Rob Phillips's Avatar
Any word on the carpet spec version yet. I can't wait much longer.
Rob Phillips is offline
Old 03-28-2005, 07:01 AM
  #1545
Badboy,
drmellking,
Nice job on your TQ and win.raise it higher then
