Old 07-27-2004, 12:41 PM   #1
IH
IH's Avatar
Default Sorex 28R on low-grip asphalt
Hi guys!
What inserts do you recommend for Sorex 28R tyres on low-grip asphalt (outdoors)? Will Yokomo precision wheels work?( TW-1012-2)
Thanks in advance!
IH
IH is offline   Reply With Quote
Old 07-27-2004, 01:04 PM   #2
Qwiglee's Avatar
Are you using those just because you are outdoors on low-grip asphalt or are you using those because they are the correct tire for the track surface temp?
Either way, with 28R I would just use a medium insert. I think a good rule of thumb is to increase the hardness of the insert as the hardness of the tire goes up. So I use firm inserts on my 36R Sorex tires.
Brian Aldridge
Qwiglee is offline   Reply With Quote
Old 07-27-2004, 01:57 PM   #3
dontfeelcold's Avatar
Trader Rating: 21 (100%+)
i use sorex type b mediums with 28R sorexs in cold conditions on brushed concrete, plenty of grip
dontfeelcold is offline   Reply With Quote
Old 07-27-2004, 02:01 PM   #4
Charlie O's Avatar
We use28r's on asphalt & concrete, yokomo or hpi med insert, pro line axis wheels, yeh they work great!.
Charlie O is offline   Reply With Quote
Old 07-27-2004, 02:12 PM   #5
IH
IH's Avatar
Thank you for your answers!
Qwiglee: I use them because they are the only tires that we are allowed to use.
Will Yokomo -037F inserts work or are they too hard?!
Old 07-27-2004, 02:22 PM   #6
Charlie O's Avatar
037-f, will work depends on how much traction you need, softer for low bite harder for high bite.
Old 07-27-2004, 08:34 PM   #7
Rod M's Avatar
get two sets of team sorex inserts MA24M and MA24F
TOPRACING.NET.AU Australian Importer of:
T.O.P. Tokyo Hobbies Optional Parts,
Team Trinity , BL Motors and Tyre compound
Team Tekin , ESC's, motors,
Elangears, Chargers,
Rod M is offline   Reply With Quote
Old 07-27-2004, 08:56 PM   #8
Joel Lagace's Avatar
Key statement.
Peoples definition of "COLD" and "HOT" are vastly different. Low grip pavement would have me grabbing for the 20s or 24s. But if your running in 30C track temps then your best to run the 28s.
"Without Rules its just Backyard Bashing!"
www.rcottawa.com
Joel Lagace is offline   Reply With Quote
Old 07-28-2004, 01:24 AM   #9
Wency_TA03R-PRO's Avatar
Exclamation
I got same set-up with you guys . Im running my FT TC3 in a tropical country... Nice clarification there joel lagace. . .
Wency_TA03R-PRO is offline   Reply With Quote
Old 07-28-2004, 01:48 AM   #10
Super Moderator
Grizzbob's Avatar
They may not be too hard, but they may not completely fill the tire up, from what I've seen. That's one reason why HPI & Echo inserts are pretty popular, because they do a better job of filling the tire, no gaps between the insert & tire. I'd also reccomend something like HPI reds for those, I've used them myself & were quite pleased with the results....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Hi Grip RP tire RC MARKET Australian Racing 13 02-15-2007 10:27 AM
Hi Grip RP tire RC MARKET Malaysian R/C Racers 0 02-14-2007 01:55 PM
High Grip Asphalt Setup for TC4 RCpurplecow Electric On-Road 2 11-14-2006 10:33 PM
Mechanical grip rc_square24 Electric On-Road 7 01-30-2004 10:02 AM
FS: Asphalt rubber Pit/Sorex+ Yok rims all NIB rainblows R/C Items: For Sale/Trade 0 07-22-2002 01:13 PM
