Lipo - Turnigy
Old 12-14-2010, 07:54 AM
Default Lipo - Turnigy
Any comment on this Lipo ? 2S1P ?
mos-leung is offline
Old 12-14-2010, 08:47 AM
Trader Rating: 14 (100%+)
I have 3 of the 4000mah hard cases and they are flipping awesome...
DuckStang is offline
Old 12-14-2010, 09:02 AM
fordmike65's Avatar
Trader Rating: 28 (97%+)
I run their 5000 20c,5000 30c & 5200 30c hardcase packs(in your pic) on all my onroad & offroad cars/trucks. My first pack puffed right away,first charge,all settings correct. Since then, I've never had an issue. Alot of guys run them without any problems,so don't hesitate to pick one up.
fordmike65 is offline
Old 12-14-2010, 09:28 AM
fordmike65's Avatar
Here are a couple pics of my puffed Turnigy. Like I said,it was the only one I had a problem with. Out of 20 or so that others & I ordered, 1 puffed pack isn't bad.
Old 12-14-2010, 10:41 AM
monkee's Avatar
Trader Rating: 15 (100%+)
ihave some venoms that i bought prior to finding turnigy..
but now, turnigy is all ill buy.
monkee is offline
Old 12-14-2010, 08:18 PM
Regional Moderator
CarbonJoe's Avatar
The batteries work great, but I just wish that they used a reasonable size of wire. The 8 gauge wire is overkill, especially if you want to solder Deans connectors to them.
CarbonJoe is offline
Old 12-14-2010, 08:34 PM
old-man's Avatar
[QUOTE=CarbonJoe;8344596]The batteries work great, but I just wish that they used a reasonable size of wire. The 8 gauge wire is overkill, especially if you want to solder Deans connectors to them.[/QUOTE
You are absolutely right about the wires. It seems like the wires that they are using with most of their packs are way over kill. Which makes installation kind of a PITA.
What makes it even more interesting is that the soldering on the banana plugs on these packs are absolute crap. On few of the packs I had, approx 75% of the strands were actually soldered to the plug.
old-man is offline
Old 12-15-2010, 03:46 PM
JKL1031's Avatar
And youd still be getting about much flow as 14guauge
I have had two of these as well. They never puff, Ive been charging and running them anyway I please besides storing them at partial charge. No babying them like most do with their higher end packs. Someone mentioned their voltage did drop a bit compared to higher end packs,,so if your running on road mod, you prolly wont be getting max performance as you could.
JKL1031 is offline
Old 12-20-2010, 08:28 AM
The wires coming out at the corner of battery, instead of middle?
How did you change this ?
Old 12-20-2010, 09:40 AM
JKL1031's Avatar
thats one of their newer packs that come that way.
JKL1031 is offline
