v2 revolution stock motor? >
Old 07-28-2004, 08:41 AM
  #46
Originally posted by TCRacerPro
i wonder if this motor will out perfrom the binaries and the monster stock if they do exist.
they definetly will.
the main difference would be made to the arm and with the v2 endbell they will be the biz.
rick,is it possible to make a motor that has true high torque and rpm?
or is it all a compramise?
trf racer is offline
Old 07-28-2004, 08:44 AM
  #47
Trader Rating: 31 (100%+)
Are you refering to the diodes they are running between the Lamination stack and the weld tab that holds the wire from the winds?
Another company{SIM} was/is doing this.They sent me a Motor and it was fast. But is it legal?
racenut123 is offline
Old 07-28-2004, 08:52 AM
  #48
yeahn there like square black things but apparently there not diodes.
theres a pic on big jims forum bt i cant get the pic here.
he calls them power trix arms.
ave you seen heard anything of them rick?
they are meant to cut down on arcing and increase effciancy and power output.
i think they are a diode/capacitor unit and smooths out the power being put into the motor from speedo?
Old 07-28-2004, 09:02 AM
  #49
Rick Hohwart's Avatar
This concept has been around for a while. Peak made armatures for the company that does this over 10 years ago. But they have no gained acceptance.
They can reduce arcing but hard to tell if they make a differecne.
Rick Hohwart is offline
Old 07-28-2004, 09:20 AM
  #50
kruthles's Avatar
Originally posted by Rick Hohwart
41510 V2 Endbell Adaptation Kit (EPIC)
41511 V2 Endbell Adaptation Kit (Yokomo, TOP)
We can get you some screws just email Joe Pillars at joe(at)team-orion.com and he will set you up.
Thanks for the help rick
kruthles is offline
