Old 12-09-2010, 01:38 PM   #1
tsais's Avatar
Default A RWD R/C drift car
In the real world, 90+% of those drift cars are rear-wheel drive. So if anyone knows any car maker makes a "real" r/c drift car, please post a link here. Thanks.
Here is a video I found on youtube that makes me even more interested in drifting. http://www.youtube.com/watch?v=W0QeISN0oZU
Having fun without rules and boundries... TSAIS!
http://www.tsais.com
[email protected]
tsais is offline   Reply With Quote
Old 12-09-2010, 01:40 PM   #2
Well the Schumacher Big 6 is 1/6 and RWD but I haven't seen any drift vids.
V0RT3X is offline   Reply With Quote
Old 12-09-2010, 01:48 PM   #3
monkee's Avatar
Trader Rating: 15 (100%+)
get an ff chassis and run the motor in reverse
monkee is offline   Reply With Quote
Old 12-09-2010, 01:52 PM   #4
tsais's Avatar
Yeah, I searched the web and couldn't find any either.
[email protected]
Old 12-09-2010, 01:58 PM   #5
tsais's Avatar
[email protected]
Old 12-09-2010, 01:58 PM   #6
lochness42's Avatar
Well Big6 isn't made for quite a while and I don't think that there are many out there (and much less drifting)
Pavel Balint
| Schumacher racing-cars.com | RCSGraphicWorx.co.uk | Cat K1 | Cougar SV2 & SVR |
Schumacher cars build videos http://www.youtube.com/view_play_list?p=9780E62C20A0EC4F
lochness42 is offline   Reply With Quote
Old 12-09-2010, 02:01 PM   #7
In the real world, the cars are 1000 times heavier, there is a different weight bias, forces are multiplied by larger factor (friction and acceleration especially), you are in the car so can feel it breaking loose, and probably a whole lot of things I hadn't thought about.
At the end of the day, 4wd trumps RC drifting withuot a doubt
Agama A8 Evo | GRP .21 | Spektrum | Savox
My car just hit 88mph. I hope it comes back soon....
JR007 is offline   Reply With Quote
Old 12-09-2010, 02:07 PM   #8
tsais's Avatar
I just searched youtube and found someone is trying to figure out how to drift a RWD TC4. At least, I know I am not along.
[email protected]
Old 12-09-2010, 02:32 PM   #9
tsais's Avatar
I think it's all about the right parts & setup, and driving skills. Here is a good website that talks about Formula Drift: http://driftjapan.com/blog/
How to build a drift car: http://driftjapan.com/blog/car-parts...d-a-drift-car/
My goal is to make scale r/c cars look and drive as close to real cars as possible.
[email protected]
Old 12-09-2010, 09:59 PM   #10
simplechamp's Avatar
Trader Rating: 73 (100%+)
There are a lot of cars that could be converted to RWD by removing the center driveshaft, one of the belts, front CVD/dogbones or any combination thereof depending on the vehicle you are working with. That is probably your best bet, because you can easily convert back and forth. Maybe get the hang of drifting with 4WD then experiment with the RWD. I think it is going to be very difficult with RWD, but I'm sure it's possible with enough practice and finesse (and a properly set up vehicle).
Serpent 811Be - Jammin X2 Carbon e-GT conversion - Axial SCX10 Honcho
simplechamp is offline   Reply With Quote
Old 12-10-2010, 07:55 AM   #11
UK.hardcore's Avatar
if you want "RWD" drifting you should run upto 200% overdrive.
it's the best way for now, it's still 4x4 but the rear wheels have more RPM.
works well, you can find info on www.csjunkies.com
http://www.youtube.com/watch?v=RTx_5YNwpKo
http://www.youtube.com/watch?v=UNe3o75KmjA
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 12-10-2010, 08:06 AM   #12
tsais's Avatar
Thanks for the advice. I actually started my experiment with a 4WD shaft-drive touring car (similiar to the TT01 or TC4), and took out the front gear box, drive shafts and center drive shaft. Wow, it is almost impossible to drive that thing right after I did all that.
[email protected]
Old 12-10-2010, 08:11 AM   #13
pejota's Avatar
Do some research on a RC10DS...
I have one and it's pretty fun to drive in the street. Never thought of drifting with it, since that's not my thing. But, with the right tires it might do the trick.
pejota is offline   Reply With Quote
Old 12-10-2010, 08:13 AM   #14
MikeXray's Avatar
Because if you could calculate the power to weight ratio of an r/c in scale with a real car it'd be like having a V24 with 5000ft/lb of torque. Match that with plastic drift tires and all you'll get are doughnuts. I would suggest if you want to just see it happen, turn your throttle epa down to like 30 and see if you can get some semblance of control.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-10-2010, 08:55 AM   #15
tsais's Avatar
I thought about the power to weight ratio issue, so I replaced the brushless motor with a silver can (540) motor.
I understand totally why those car, ESC, motor, and battery makers want you to buy their products and then educate you to put on some no-traction plastic tires to drift. Huh? Maybe some harder rubber slick tires + 540 motor? I'll let you draw your own conclusion on this.
[email protected]
Professional Drifting with R/C cars! MartinSorlie Electric On-Road 98 11-14-2013 02:39 PM
FS: All my R/C cars and Gear Oz_racing R/C Items: For Sale/Trade 42 03-26-2011 05:21 PM
Drift Guru's:- locked diff??? xray racer Electric On-Road 11 05-07-2005 07:07 AM
