What Temperature For Soldering? >
Old 07-24-2004, 04:27 PM
Nrctc3's Avatar
Default What Temperature For Soldering?
I just got a soldering iron with adjustable temperature. What should I use it at?
Nrctc3 is offline
Old 07-24-2004, 05:32 PM
JusBox's Avatar
unless you're working with delicate circuits, crank it as high as it can go.
JusBox is offline
Old 07-24-2004, 06:16 PM
donoman's Avatar
This is wrong.
If it's too high, you will oxidize the solder on the tip and the iron will fail to melt good solder joints, ie. crappy connections. Then you will need to spend time cleaning the tip to get good conductivity again.
500-700 degrees is ideal, depending on the type of solder you are using.
Donovan
donoman is offline
Old 07-24-2004, 06:28 PM
Tek Nickal's Avatar
Originally posted by donoman
This is wrong.
Donovan
Yeah. You may have to sand it or something for the solder to stick well again. Esp. when you leave it on for a long time.
Tek Nickal is offline
Old 07-24-2004, 06:31 PM
Nrctc3's Avatar
well I leave mine on from 7am til 6pm on race days. But when I'm not using it, I turn it all the way down.
Nrctc3 is offline
Old 07-24-2004, 06:35 PM
60watts is good for heavy gauge wire
kh15 is offline
Old 07-24-2004, 06:41 PM
=MisFitz= NuKe's Avatar
hahaha, um, how about at the nats, leaving it on for like 3 days straight, as in forgetting to turn it off at night. This was a Hakko and we left it turned on high for three days.
=MisFitz= NuKe is offline
Old 07-24-2004, 06:42 PM
hogdaddy77's Avatar
just keep the tip tinned and you should be fine at high temps..just wipe it off prior to use, then when it is going to sit, tin it.
hogdaddy77 is offline
Old 07-24-2004, 07:22 PM
Nrctc3's Avatar
alright, thanks for the help.
Nrctc3 is offline
Old 07-25-2004, 12:27 PM
j240z's Avatar
I usually stick with 675-725 deg. depending on what I'm soldering.
If I'm tinning wire- 675 deg.
If I'm soldering to a cell - 725 deg, to get the job done faster, therfore causing no damage to the cell.
j240z is offline
Old 07-25-2004, 07:55 PM
Nrctc3's Avatar
I've been keeping mine at 835, when I'm not using it I turn it down. Then turn it back-up when I need it.
Nrctc3 is offline
Old 07-26-2004, 07:14 AM
chris_v1s's Avatar
Exclamation
when soldering the batteries don't forget to scuff first teh ares to where you are gonna solder so that it will definitely get you a good joint.. temp 650 - 750 will do just make it as quick as possible, so that you don't burn up or heat the cells too much..
chris_v1s is offline
