HobbyKing Quattro 4x6S >
Old 12-08-2010, 12:01 AM
monkee's Avatar
Trader Rating: 15 (100%+)
Default HobbyKing Quattro 4x6S
is the quattro 4x6s the same charger as the hitec x4 multicharger? sure looks the same.
http://hobbyking.com/hobbyking/store...dProduct=10327
what power supply would be best (ie: inexpensive yet effective) for this quattro?
http://hobbyking.com/hobbyking/store...dProduct=13765
and since im horrid at amps lipo math, how long would this charger take to charge 4x 4cell 5000mah lipos?
monkee is offline
Old 12-08-2010, 04:23 PM
monkee's Avatar
anyone?
monkee is offline
Old 12-08-2010, 04:45 PM
tunerjetta29's Avatar
I dunno if its the same charger but I have been using my quattro for a few months now with no issues. It works excellent. I've been charging 4 lipos at once consistently all day at the track with no issues at all
TQ RC Racing has the Quattro on sale though tower seems a little cheaper
http://www.tqrcracing.com/shop/produ...yword=&pg_no=1
Time to charge your lipos will vary depending on the charge rate they can take.
tunerjetta29 is offline
Old 12-08-2010, 04:48 PM
monkee's Avatar
is yours different than the one i linked? the hobbyking one is $60 less.
also, is that powersupply i linked to good enough for the hobbyking charger?
monkee is offline
Old 12-08-2010, 08:32 PM
Regional Moderator
CarbonJoe's Avatar
The HobbyKing version is limited to 5A per channel, whereas the Hitec goes up to 6A per channel (for 2s), but both are "rated" at 50 watts max per channel. The HK one stops incrementing the charge current at 5.0 amps, so for a 2s LiPo it is only using 42 watts (8.4v x 5a = 42watts) The Hitec, when set for 6A, theoretically can use 50.4 watts (8.4v x 6a = 50.4watts).
However, when using more than 2s LiPo, the charger will limit the output to 50watts, so for 3s LiPo (12.6v max), the current would be limited to ~4A (3.96A). For 4s (16.8v max), you'd be limited to ~3A (2.97A).
I love my iMax version (basically the same as the HK one).
As far as a power supply, one that can supply 25A or more is sufficient.
CarbonJoe is offline
