Old 12-07-2010, 10:49 PM   #1
surby's Avatar
Default cutting the rotor
i was going to put a vxl system in my tt-01 until i tried to put the motor in and the rotor is too long. i was wondering if anyone has ever cut a rotor down to make it fit and how so would i do that. i was thinking of using a mill to cut it?
here are some pics sorry for the poor quality taken on a phone
losi 8ight be with xerun 2250kv with dx3c
slash 4x4 stock
factory team b4 with cc 5700kv system
surby is offline   Reply With Quote
Old 12-07-2010, 10:57 PM   #2
rc_square24's Avatar
Can't you shim the motor forward between the can and mount?
Or maybe remove a bit of material from the cover / chassis
rc_square24 is offline   Reply With Quote
Old 12-07-2010, 10:57 PM   #3
oldguyzrule's Avatar
Trader Rating: 74 (100%+)
room to turn the pinion around?
oldguyzrule is offline   Reply With Quote
Old 12-07-2010, 11:02 PM   #4
surby's Avatar
i thought about cutting a slot in the chassis but before i start cutting that i would rather cut the rotor cause on my b4 it sticks out of the gear cover
slash 4x4 stock
Old 12-08-2010, 06:51 AM   #5
Use a Dremel cut off disk to shorten the shaft up. This is a pretty common issue in 1/8 electric vehicles.
ebruce is offline   Reply With Quote
Old 12-08-2010, 07:52 AM   #6
Craig W's Avatar
Send a message via MSN to Craig W Send a message via Skype™ to Craig W
Thing 3 racing do a spacer cooling plate
Craig W is offline   Reply With Quote
Old 12-08-2010, 08:27 AM   #7
MikeXray's Avatar
Trader Rating: 73 (100%+)
Is the rest of your driveline up to the task of a vxl motor?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-08-2010, 01:15 PM   #8
jake95's Avatar
Trader Rating: 27 (100%+)
just dremel it down
XRAY✯NOSRAM✯SANWA
jake95 is offline   Reply With Quote
Old 12-08-2010, 02:42 PM   #9
Starteur's Avatar
Tamiya makes a spacer plate that acts as a heatsink and spaces your motor out. Just look at option parts under TT01 Drift.
Ride it like you stole it!!!!!!
Tamiya TRF417V5 SEDAN Racer - Tamiya 416X VTA Racer - Tamiya TRF 416X USGT Racer -Tamiya M05 V2 PRO Racer -Tamiya F-104X1 Formula 1 Racer.
Starteur is offline   Reply With Quote
Old 12-08-2010, 03:40 PM   #10
This is an important question, the VXL will blow up the stock TT01 drivetrain pretty fast.
PaintVagrant is offline   Reply With Quote
Old 12-08-2010, 04:21 PM   #11
If you run it on a 2S LIPO you should be fine. I don't know why everyone thinks the VXL is some crazy power house motor and it's going to blow everything up.
Jay
~ Jason Kennedy ~
~ Sweep Racing Tires ~
~ TQ Wire~Wire~
pyro18t is offline   Reply With Quote
Old 12-08-2010, 04:23 PM   #12
Hide's Avatar
Just grind it down with a dremel. Press the shaft through a clear plastic bag and put blu tac around the hole so you don't get metal shavings in the motor.
Losi 8ight-E 2.0, LRP Shark, Xray M18T custom extended, Traxxas VXL Revo
Hide is offline   Reply With Quote
Old 12-08-2010, 08:59 PM   #13
-TC5racer-'s Avatar
Trader Rating: 40 (100%+)
Jay
So true.... It's a decent motor but no powerhouse!!!!
GTPe-RX8-Neu 1515/1D | DM-1Se-RX8-Plettenburg MAXX | Losi GT8e-RX8-Hacker C50-9L |X1 CRT Pro-MMM-CC1717 | SCRT10-RX8-Hacker CMaxx | MHyperSte-RSpro-LMT XL4200 | TC5-RSpro-LRP 4.5 | TC3-RSpro-LRP 10.5 | B44-R1pro-Tekin 268
Just to name a few!!!
-TC5racer- is offline   Reply With Quote
Dyno, Homemade, Using a Novak Sentry Data Logger, Continued, The Experimental Thread. John Stranahan Electric On-Road 344 12-30-2016 05:22 PM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
Around The Table With Paul Lemieux(RC-America/Thunderpower) Paul L Electric On-Road 1384 12-18-2009 09:06 AM
The Official 4300 Brushless/LiPo/Foam Touring Thread FreqETag Electric On-Road 246 03-13-2007 01:10 PM
