Dying Jaco Wheels
Dying Jaco Wheels
I searched for this but didn't come up with anything.
I want to dye my Jaco "Prism" wheels something other than white.
We run Jaco Blues as a spec tire, everyone having the same white wheels looks a little boring after a while.
Some guys give the wheels the Sharpie treatment, but always looks poor.
Thought about painting the wheels but will the paint just chip off?
I was inspecting the Jaco wheels and they look porous enough to be able to take dye. Im concerned that dying the wheels could damage the rubber or the foam inside.
Normally I would boil the parts I wanted dyed but I think the heat would hurt the tire. Im pretty sure a good soak in out of the tap hot water would also do the trick.
Im sure dying the wheels black would be easy, but I want to try and find a fluorescent yellow to match my paint job and off road wheels.
Does any one know of and have experience with using any Flo dyes?
Hope some one out there has tried this.
I have dyed white Parma and Jaco wheels in the past with great results. I use Rit fabric dye and have used black, blue and sun burst orange. I have not found any flouresent colors. I have had no problems with foams coming unglued from the rims. It only takes a few minutes in the water and its not a hard boil. So just pick you colors and boil away!!
Have you actually done this with the hotwater? The only thing that reliably removes the foam is a good soak in acetone. Let sit in the jar for about 24 hours, and the foam will slide right off.
Shawn.
Don't they make jaco blues with a black rim?
Dying the whole wheel/tire doesn't work well lol the tire and insert will get weird
