Old 07-23-2004, 10:24 PM   #1
Default tc3 gear ratios?
on the spec sheet it says the tc3 rtr comes stock with a 3:0:1 GEAR RATIO whats that and what gear is for what number?
kh15 is offline   Reply With Quote
Old 07-23-2004, 10:29 PM   #2
Default Re: tc3 gear ratios?
try this .. www.gearchart.com fill out the info and you gan print out a gear ratio for you car.. the gear ratio for your car is 2.5:1 meaning your final gear ratio for the drive train .. hope this helps..or you can type in 3.0:1 and get a chart .. it will give all pinions and spur sizes your going to use....
Mark Barden .
mb racer is offline   Reply With Quote
Old 07-23-2004, 11:45 PM   #3
That is the Spur/Pinion ratio....The internal ratio of your car (the diffs) is 2.5.... 3 x 2.5 = 7.5
To figure your final drive....Divide your spur # by your pinion #...then multiply by internal drive ratio (2.5 on the TC3)
Letme guess, the gears on your car are 24 pinion & 72 spur...I'm f#@$ing psychic!
The Black Kat is offline   Reply With Quote
Old 07-24-2004, 02:13 AM   #4
Wency_TA03R-PRO's Avatar
Exclamation
Remember the lower the gear ration the faster it will run...
Wency_TA03R-PRO is offline   Reply With Quote
Gear ratios? mrmcphearson Rookie Zone 4 07-03-2008 08:21 AM
Gear Ratios/ Spur Gear Sparky7B Rookie Zone 2 02-26-2008 10:03 PM
Gear ratios N15M0 Rookie Zone 14 10-06-2005 05:36 PM
help with gear ratios! moot Electric On-Road 1 03-15-2005 02:43 AM
Gear Ratios.... Rain Rookie Zone 4 11-14-2003 07:23 PM
