Simple Orion V2 Question >
Old 07-27-2004, 10:47 AM
  #16
Turbonium's Avatar
Trader Rating: 27 (100%+)
I think its the blue one.. the "modified" version? its not in front of me at the moment, but as i remember, blue...
Turbonium is offline
Old 07-27-2004, 10:57 AM
  #17
Tech Legend
Cain's Avatar
Trader Rating: 289 (100%+)
Thanks for the info. So for me 7 over the wind should do it for my SB.
Thanks!
Cain is offline
Old 07-27-2004, 11:45 AM
  #18
Joe Pillars's Avatar
Tamiyaracer- With the modified version you will want to run 18 degrees in touring car and 2wd buggy. There is a small notch on the endbell that you line up the timing mark with on the motor label.
Joe Pillars is offline
Old 07-27-2004, 11:55 AM
  #19
Turbonium's Avatar
thanks, Joe! i have been very impressd with the power and low(er) maintenance of this motor...
im not sure if the stock motor would make much more power with the V2, but it would make for fewer cuts required.
Old 07-27-2004, 12:30 PM
  #20
The new stock motor will be dialed. Just think how much better the Revolution is in modified.
Old 07-28-2004, 11:51 AM
  #21
Turbonium's Avatar
i hate to seem silly, but is that mark right by the screw? thats the only mark i see on it. and it is the blue label. thanks Joe!
Old 07-28-2004, 11:55 AM
  #22
Yes, that is the one.
Old 07-28-2004, 11:56 AM
  #23
Rob Mincey's Avatar
Joe - I'm running a Peak Surikarn 11x1. Would you start at 12 or 18 degrees of timing with Enduro brushes and stock springs?
For what it matters, I'm in an XRay Factory car... Spools up quickly.
Rob
Rob Mincey is offline
Old 07-28-2004, 12:03 PM
  #24
losirob-With the Surikarn motors I would stay around 12 degrees of timing. Two things I would change is to run sprint brushes and switch from medium/hard springs (come in the motor) to hard springs. This will give the motor allot more punch. Also breaking in the brushes is very important when putting new brushes in.
Old 07-28-2004, 01:16 PM
  #25
Trader Rating: 22 (100%+)
Joe whats the ideal setup for a 12-1 touring HT motor. Im running mostly tight tracks.
Bob Barry is offline
Old 07-28-2004, 01:43 PM
  #26
Rob Mincey's Avatar
Joe - thanks for the quick reply, I know you (and the other pro's who take the time to help the rest of us) have lots of things going on. Your input is appreciated.
I'll try your suggestions next time I run.
Thanks again,
Rob
Old 07-28-2004, 02:11 PM
  #27
Bob Barry- Use sprint brushes, hard springs and 12 degrees of timing. We gear our motors 1 to 2 teeth below our old style motors.
losirob- If you have any other questions you can also go to www.team-orion.com and I have a thread under factory drivers.
Old 07-28-2004, 03:00 PM
  #28
Tech Legend
Cain's Avatar
what about 4wd offroad? should I go to harder springs?
Cain is offline
Old 07-28-2004, 03:13 PM
  #29
really i used sprints with the stock springs at 18 timing and the motor had no rpm but would pull a tree stump...i ended up gearing up 4 teeth. whats the part number for the hard springs
Old 07-28-2004, 03:24 PM
  #30
Tech Legend
Cain's Avatar
I would like that problem. Going to low on gearing is an issue! How much torque do you get with the harder springs and enduro brushes?
Cain is offline
