Old 07-23-2004, 02:15 PM   #1
donoman's Avatar
Send a message via Yahoo to donoman
Default Homemade Power Supply
Anyone here made one out of an ATX PS? or AT? I'm looking at doing this myself. I think they can supply up to 10A, which ain't bad, especially if you just have one hanging around...
http://www.marcee.org/Articles/PCPowerSupply.htm
Please let me know if you've tried it, heard of others trying it, or know of any problems with doing this. Thank you.
donoman is offline   Reply With Quote
Old 07-23-2004, 02:43 PM   #2
I did one about 6 months ago. It wasn't too difficult, but I'd probably just buy one of the cosel (sp?) supplies from ebay if I needed another. The only advantage is getting the 5v line for my lathe, etc. the unit used did not have a 3v lead, which I would really like for motor break-in. I installed a project box (Radioshack) with a switch, power light, and output terminals.
This thread has some pretty good information.
Corruptor is offline   Reply With Quote
Old 07-23-2004, 02:45 PM   #3
AlanLim's Avatar
I found this.....
http://www.holmes-ave.freeserve.co.uk/atx-psu-mod.htm
AlanLim is offline   Reply With Quote
Old 07-23-2004, 03:15 PM   #4
Cole Trickle's Avatar
Or try this one: http://www.magicookie.com/prodigy/psupply.htm
I made one almost 2 years ago - still going strong. But I'm considering getting a better supply, when I have the money. Because the resistors I mounted over the 5 volt supply, reach 130 degrees celsius (=266 deg. F). Even though they are mounted close to the fan...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 07-23-2004, 04:57 PM   #5
imjonah's Avatar
I did not do anything with the 5 volt wires I did not attach resitors or anything and it seems to work.
Not reccomending that but I am not sure it is always necessary.
imjonah is offline   Reply With Quote
Old 07-24-2004, 01:34 PM   #6
It depends on how "intelligent" the PC PS are... The newer ones sense the load on the 5V - no load on the 5V and the PS produces less power. Saves power in the long run.
Old 07-24-2004, 04:56 PM   #7
John_S's Avatar
hi i jst built one , it was far easier than what i thought it would be. I jsut used 2 15w resistors as the load and it runs fine
John_S is offline   Reply With Quote
Old 07-26-2004, 06:09 AM   #8
Send a message via ICQ to copter Send a message via Yahoo to copter
Adding load to 5V is needed only when using old AT-type power supply. New ATX-type power supplies don't need anything into there, just cpnnecting PS-ON lead to ground will make them work.
This is because PC power supplies are cheaper than "normal" 12V power supplies (usually) and manufacturers wouldn't want to see people using cheaper PC powers to be used instead of normal power supplies. PC power supply prices have came down because of hard competition that doesn't exist in normal power supply market. This is why they added mandatory 5V load into AT supplies and PS-ON lead for ATX supplies as some kind of protection that they couldn't be used without modification in any non-PC use.
copter is offline   Reply With Quote
Old 07-26-2004, 09:03 AM   #9
Scrad's Avatar
Trader Rating: 15 (100%+)
There is another thread with the cosel elco (sp) PS. This on is by far the easiest to set up. You only need to strip a plug and attach the wires.
http://www.rctech.net/forum/showthre...highlight=cord Here is the thread.
Scrad is offline   Reply With Quote
Old 07-26-2004, 01:09 PM   #10
donoman's Avatar
Just wanted to let you guys know that I did it, with 4 10W 10Ohm resistors in parallel shorting the 5V to gnd and it works pretty well. The resistors get pretty hot so I secured them to the internal heat sink in front of the PS fan.
Easy power supply for about 5$.
Old 07-26-2004, 01:34 PM   #11
Here's a picture from my PC power supply: http://www.teamentisetkuskit.com/alb...0807.sized.jpg.
I soldered all "extra" wires out, connected 2 yellow (+12V) wires and 2 black (ground) wires into connectors. Then connected extra bright LED between "power good" and ground wires. Also I replaced fan with a more silent one that is adjustable (trimmer next on connectors in picture). Lastly I did connect green and grey wires so that power will start when I turn it on from the switch that is located in the back panel.
Next thing is to add +5V and +3.3V connectors into front too. I guess +5V could be good for lathe and probable +3.3V could be used for motor break-in? Any comments about using those for mentioned purposes?
Old 07-27-2004, 02:53 AM   #12
donoman's Avatar
Copter looks great,
Can you give me a closer picture of your PS? I want to see how you mounted stuff. I also have banana plugs in mine and a pushbutton switch in front. But no LED
Old 07-27-2004, 04:00 PM   #13
bballer's Avatar
Im in the process of trying to find a ps, and saw this thread, thanks for the helpful info . When im about to take the computer apart to get at the ps, is there anything i should be worried about concerning electricty and capacitators, like is it dangerous if you don't know what you're doing? What wires do i need to know about. Thanks
bballer is offline   Reply With Quote
Old 07-27-2004, 05:48 PM   #14
donoman's Avatar
Just unplug the computer. It's relatively safe. Try not to touch the capacitors. You should be OK.
Old 07-27-2004, 06:56 PM   #15
bballer, just power off the computer, then unwire and take it off. Before opening the PS case I recommend that you just let it be for couple hours. During that time capacitors should drain empty.
donoman, I'll take some more detailed pictures tomorrow after I get back from work and post them here.
Computer power supply used for charger power supply? 66Racer Radio and Electronics 7 05-25-2008 12:52 AM
RC BLOW OUT !!!! Ice chargers,novak discharger,power supply,power bridge,integy setup shrum1340 R/C Items: For Sale/Trade 20 07-23-2007 05:37 AM
>>> TEAM NOVAK N-POWER POWER SUPPLY GREAT CONDITION $50 <<<< mach51 R/C Items: For Sale/Trade 3 02-06-2007 10:53 PM
turning pc power supply into a rc power supply andy_666 Electric On-Road 20 01-16-2006 05:20 PM
SEC Power Supply vs. Hobbico Power Supply? F1Junkie Electric On-Road 1 06-05-2004 08:52 AM
