Old 07-23-2004, 08:36 AM   #1
jedi's Avatar
Default Can Bad Tramsmitter Batts Cause Glitching?
Can bad transmitter batts cause glitching? I have a Pro4 with a GT7 esc and a JR spcm rx which just started glitching recently. Changed the motor, changed brushes on the motor, changed to a similar JR spcm rx, moved stuff around in the car (capacitor, wires, esc, rx, etc.) and still glitched. Changed to a Novak xxl FM receiver and glitching was gone. Discovered that my transmitter batts were bad. Was using 1000mah nicds in my JR R1 transmitter for about 18 months. Never cycled them. Just charged them when they became weak, sometimes fully and sometimes just partially. Removed then and charged them on a n Integy 16x5v6. Peak voltage reached over 15 volts so I know they were bad.
Would new tranmitter batts cure the glitching problems with my JR pcm receivers? Or are my receivers both broken? I find it hard to believe that one of my pcm rx is broken and almost impossible to believe that both are broken. What other explaination could there be? Hope someone can help me. Thanks
It's better to be lucky than to be good......when it comes to getting a clean run in qualifying!
jedi is offline   Reply With Quote
Old 07-23-2004, 09:14 AM   #2
Claydoh's Avatar
Send a message via AIM to Claydoh
Low transmitter power would certainly cause a problem. Not sure why an xxl would be less prone to glitch than the synth rec's. Maybe they need a stonger signal. At what voltage does the transmitter start beeping? My M8 starts whining at 9.6 volts I think. My old 1300 mah nimh AA's barely get over 10.4 anymore so I have to recharge every race day
Claydoh is offline   Reply With Quote
Old 07-23-2004, 10:08 AM   #3
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Duh ya!! I've had that problem before. On my old transmitter in the main my batteries where low and my car was impossible to handle or drive. ANd my batteries died. lol So i learned my lesson. Change your batteries about every 2-3 months. So you wont have to worry about low batteries.
hope you have fun and change those batteries
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 07-23-2004, 10:36 AM   #4
kufman's Avatar
Have you tried different sets of crystals? Sometimes damaged receiver crystals will work in some receivers and not in others.
Brushes? We don't need no stinking brushes!!!
kufman is offline   Reply With Quote
Old 07-23-2004, 10:38 AM   #5
YES
G's RC Raceway- Best off-road track on the east coast...period!!!
Pitman for Team Dallas Austin...
IMPACTPLAYR is offline   Reply With Quote
Old 07-23-2004, 10:42 AM   #6
Charlie O's Avatar
Absoulutley it will cause glitching!
Charlie O is offline   Reply With Quote
Old 07-23-2004, 05:46 PM   #7
jedi's Avatar
I had the glitches even if the transmitter said the batts still had 10.2 volts and yes I tried switching crystals to no effect. Guess I will change my batts and see what happens.
Old 07-23-2004, 05:57 PM   #8
protc3's Avatar
I use energizer e2 batteries.they are much higher voltage than regargebles which means stronger signal.and yes,low batts will definately cause glitching.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Glitching....please help Cristian Silva Australian Racing 23 06-14-2008 04:49 AM
glitching help! aus jd 2703 Electric On-Road 6 05-24-2007 05:43 PM
glitching tdragon Electric On-Road 10 06-17-2003 11:03 AM
