Old 12-03-2010, 06:06 PM   #1
unsane_chimera's Avatar
Default Sakura Zero S, IFMAR legal?
Hi guys. Is the Sakura zero s IFMAR legal? I'm looking to buy one to race in the local tournament and they say that it pretty much has to be IFMAR legal to race. I saw the chassis requirements listed in the IFMAR rules and it says no "flat-pan" style chassis'. I assume that means none of the carbon fiber board chassis? I'm not too familiar with the term "flat-pan", but I assume that's what it means? The chassis on the sakura is a two level setup, does that change it or am I limited to tub chassis'?
In the past few hours I have learnt these very important things; firstly, read the instructions, secondly, READ THE INSTRUCTIONS!! And check the back of the piece of paper if there are more instructions, thirdly, double check what you have done, then check it again and READ THE INSTRUCTIONS!!!
unsane_chimera is offline   Reply With Quote
Old 12-03-2010, 06:18 PM   #2
SchuMi2's Avatar
Trader Rating: 34 (100%+)
Would be legal for any EP TC racing in Aus...
(Except the new FF class as the 'S' is 4wd)
SchuMi2 is offline   Reply With Quote
Old 12-03-2010, 06:21 PM   #3
yes the car is allowed in the tc class.
flat-pan" style chassis is a chassis like the 1:12 scale. you have them also in 1:10 scalle.
toptek is offline   Reply With Quote
Old 12-03-2010, 06:51 PM   #4
Thanks guys.
Would you recommend the Sakura over a TA05v2 for either 540pro, 17.5t or 10.5t brushless classes?
Old 12-03-2010, 07:15 PM   #5
SchuMi2's Avatar
Thanks guys.
If you are going to run 17.5 or 10.5 you might want to get the Sakura Zero and not the 'S'.
Old 12-03-2010, 07:32 PM   #6
Wouldn't be able to handle the power? Or just not competitive enough?
Old 12-03-2010, 07:43 PM   #7
SchuMi2's Avatar
Reliability would be the big issue once you bolt in more power. I am going to put one together to run in our 21.5 class. I am sure it will be competitive in the lower classes like 540 without too many upgrades.
Old 12-04-2010, 11:07 PM   #8
I would have thought, after looking at the user manual for the zero s, that the gear diff would be stronger. it looks like its based on a traditional diff for a real car.
do you know of anyone putting a 17.5 or faster in a car with a gear diff? did they have major issues?
Old 12-05-2010, 04:44 AM   #9
Wolf's Avatar
Send a message via ICQ to Wolf
I've heard that someone put a 5.5T in it, with a front spool, seems to hold up well (at least for a day).
Wolf is offline   Reply With Quote
Old 12-05-2010, 09:32 AM   #10
RC MARKET's Avatar
why not
RC MARKET is offline   Reply With Quote
Old 12-05-2010, 10:58 AM   #11
Madulla's Avatar
Why wouldn't the Zero S hold up?? The only difference is the alloy bulkheads and frp chassis. The gear diff is what the Zero guys are upgrading too. Can't wait to get mine on the track to test.
Madulla is offline   Reply With Quote
