Kitchen Cutting Board for Pit Board? >
Old 07-22-2004, 09:45 PM
rctoyguy's Avatar
Trader Rating: 21 (100%+)
Default Kitchen Cutting Board for Pit Board?
Has anyone tried using a normal kitchen cutting board as a pit board? All I want is a good flat surface for measuring ride height and camber. (a full set up system is farther down the line for me)
I bought a 12x18 cutting board at Wally World, but I haven't opened it yet - it can go back if this is a bad idea. I would think the only real concern would be about it staying flat, and one of this board's key points is it's resistance to warping.
rctoyguy is offline
Old 07-22-2004, 09:49 PM
speedxl's Avatar
dude if its flat and it works F! it just use it!
speedxl is offline
Old 07-22-2004, 09:52 PM
j240z's Avatar
I'm guessing you're talking about a plastic cutting board and not a wood one, right? Every plastic cutting board I've ever seen is usually warped.
I went to Tap Plastics and got a flat piec os 1/2" thick plexi-glass cut for me. It was less than $15 and works great. I also ended up getting a Hudy board decal for $13 and stuck it on the plexi glass. It works great!
j240z is offline
Old 07-22-2004, 09:56 PM
Paul_Kultcha's Avatar
You could do this but it would probably be a good idea not to return it to the kitchen and let your mom use it for cooking again.....
Paul_Kultcha is offline
Old 07-22-2004, 10:06 PM
Neil Rabara's Avatar
I use to use a glass cutting board for a pit board. That's before I got my mcmoney pit board.
Neil Rabara is offline
Old 07-22-2004, 10:08 PM
I've seen people go to Home Depot and purchase a piece of melomine board aka cabinet board. If you look close at the Hudy Pit Board it's pretty much just a thick piece of Cabinet with siding and a fancy sticker on top.
Old 07-22-2004, 10:10 PM
j240z's Avatar
WORD!
j240z is offline
Old 07-22-2004, 10:13 PM
I might end up going to a thicker board. I know of one guy who has a 1 inch thick plastic clear pit board. No flex!
Old 07-22-2004, 10:15 PM
FW-05RR's Avatar
If it works why not
you can also load it up with "Hudy" stickers
FW-05RR is offline
Old 07-22-2004, 10:48 PM
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
rctoyguy
Iknow this is not the answer to you question
Just go & buy a Mcmoney pitboard & look cool at the same time,you could have Britney spears bum on there if you wanted to
MR JOLLY is offline
Old 07-22-2004, 10:49 PM
Don't stop at Britney Spears' bum. There are numerous others who can easily be considered better.
Old 07-22-2004, 10:52 PM
MR JOLLY's Avatar
It was the first usa singer that pop in to my head at6.50 am,my head not clear .
Is that a bad choice?
MR JOLLY is offline
Old 07-22-2004, 10:56 PM
Rob Hochberg's Avatar
I use a cutting board, just be careful with it, I left it on the kitchen table once and my dad used it to make salad!
Rob Hochberg is offline
Old 07-22-2004, 11:48 PM
JusBox's Avatar
I use a large piece of sparkly carbon fiber that's the same stuff the Cuda R3 chassis is made off. Definately a cool setup board.
JusBox is offline
Old 07-23-2004, 08:09 AM
Claydoh's Avatar
If you want cheap, glass is the bargain if you're sure you won't break it. I paid $9 for a 14" x 22" piece
Claydoh is offline
