Ta05v2 carbon graphite chassis? >
Old 12-03-2010, 02:20 PM
unsane_chimera's Avatar
Default Ta05v2 carbon graphite chassis?
Hi guys. will this chassis for the IFS work with my v2?
http://os.3racing.hk/products.php?products_key=3554
If not, are there any graphite chassis' that work with the v2? Is there much of a difference between the v2 and the IFS? Are most of the parts interchangeable between the two?
unsane_chimera is offline
Old 12-03-2010, 02:40 PM
Exotek makes a carbon chassis for the TA05 V2
bashslash is offline
Old 12-04-2010, 04:04 AM
looks pretty damn sick!
Old 12-06-2010, 01:31 AM
the ifs uses the 49.7mm hinge pins for the arms, the 1 piece toe blocks, a different front bumper, wider chassis, standard ta05 steering linkage, and a different motor mount.
the v2 has those nifty 2 piece toe blocks that make belt changes a snap, the shorter 46mm hinge pins for the arms, a narrower chassis, tb03 steering, and the tb03 front bumper.
i'm probably forgetting some stuff but that is basically it i think.
platypus_s13 is offline
