Old 07-21-2004, 08:25 AM   #1
PinkSlip's Avatar
Default Battery Coolers?
Hi
I've seen a few guys using "battery coolers" when charging there batteries, does this help?
The battery coolers is normally a 8cm fan or 2 blowing on the batt when charging in a home build wind tunnel.
L8er
PinkSlip is offline   Reply With Quote
Old 07-21-2004, 08:59 AM   #2
Claydoh's Avatar
Send a message via AIM to Claydoh
You want the cels to heat up when you charge. Only put a fan on them after the run to cool them off so you can charge them
Claydoh is offline   Reply With Quote
Old 07-21-2004, 09:24 AM   #3
rctoyguy's Avatar
Trader Rating: 21 (100%+)
I have been told (by battery sponsored drivers) to not put a fan on the batteries while charging OR after running - just let them cool on their own.
I'm still pretty new, but that is what they told me, and they have the battery sponsorship to back them up.
Jeff
rctoyguy is offline   Reply With Quote
Old 07-21-2004, 09:25 AM   #4
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
You've gotten the right information my friend.
I do admit that I do have one of those units though, but I use it for placing my xray on it after a heat to cool the motor down so I can work on it. (not with the batteries on it of course, right after the race I discharge it automatically to 5.4 v/pack)
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 07-21-2004, 09:57 AM   #5
Suspended
Send a message via AIM to RcRacerX
Default Battery theory
Here's some things that will explain some stuff about batteries. you want them to be warm, not hot when charging them up. They tend to have a little more capacity when warm. The back draw to warming them up is that they also increase internal resistance.
So it should come ideally that when you are racing, you would want to keep them cool, but not too cold, to lower the resistance for increased battery proformance.
When I was in High school, I was in a class called transportation of the future. The class built two race cars from scratch. They were 3 wheeled machines, built out of titanium, and powered by two car batteries hooked up in series. When we charged them for a race, we would stick them in the pick up truck, and keep the truck running with the floor heaters cranked up full blast while charging the batteries. After we slid them into the race cars, just before the race would start, we would tape on as many ice packs we could to help keep the battery cool. We noticed a huge diffrence of not only increased power, but also longer run times. I did feel sorry for the drivers though, as they had to stratle one battery and use the other one for a pillow/head rest. I wouldn't reccomend going to that extream for RC batteries, since they are more suseptable to temperature variations, but just to show that temperatures can and do make a diffrence.
RcRacerX is offline   Reply With Quote
Old 07-21-2004, 03:02 PM   #6
macnkitty2002's Avatar
i put a fan on the charger to make sure that it doesn't overheat. speeds up charging by about a minute or two. doesn't sound like much but at the races, 1 or 2 minites can make a big difference in charging time!
macnkitty2002 is offline   Reply With Quote
Old 07-21-2004, 04:49 PM   #7
Charlie O's Avatar
Default Warm not hot!
You want your batteries to be warm but not hot, heat kills NIMH batteries, yes when the ambient temperature is high say 90+ keep a little fan on your batteries & charger if it doesn't have one built in to it, ever heard of cell venting from heat? it's where a cell will actually leak and be ruined, & chances are the others in the pack will be bad to, play it safe and keep them from getting hot.
Charlie O is offline   Reply With Quote
Old 07-21-2004, 05:35 PM   #8
i second that
Old 07-21-2004, 11:15 PM   #9
S-T-R-l-K-E-R's Avatar
Send a message via ICQ to S-T-R-l-K-E-R
its more of a question of location. take us for example. we live in the tropics. the weather is usually hot so this would make our batts heat up more in less amount of time. so by the time the charger peaks the batts its alittle bit too toasty for comfort. if you are in a place where its kinda chilly then you wont need a fan for your batts. heck you might not even need one to cool your motor down after a run.
you should get your batts peaked at 122 *F or 50 *C. try setting your charger at a delta peak/fallback where it will detect that peak at this temp. for tropical climates when outdoors we set it at .3mv/cell when we charge indoors normally its at .4mv/cell.
just my .02 cents
S-T-R-l-K-E-R is offline   Reply With Quote
Old 07-22-2004, 01:27 AM   #10
Send a message via AIM to TCRacerPro
they should make a mini fan heatsink battery bar!
TCRacerPro is offline   Reply With Quote
Old 07-22-2004, 02:50 AM   #11
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
I use a Sort of Battery Heat Sink if you want to call it that.. It draws heat away from the Battery while charging.. ATLAS just released it.. works quite well
-Dave
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-22-2004, 06:23 AM   #12
Wency_TA03R-PRO's Avatar
Exclamation
my buddies here just use a regular mini fan. its about a size of the aux fan in your cpu...
Wency_TA03R-PRO is offline   Reply With Quote
Old 07-22-2004, 09:50 AM   #13
interesting
Motor coolers carolinatc R/C Items: For Sale/Trade 2 08-19-2008 04:56 AM
** Motor Coolers ** nordheim R/C Items: For Sale/Trade 72 10-17-2006 08:50 AM
Motor Coolers? aus jd 2703 Australian Racing 9 07-19-2006 01:21 AM
** Motor Coolers ** nordheim R/C Items: For Sale/Trade 26 07-02-2006 10:18 AM
Motor Coolers micros_rock R/C Items: For Sale/Trade 26 06-23-2005 01:29 AM
