-   -   solder gun (https://www.rctech.net/forum/electric-road/45631-solder-gun.html)
kh15 07-20-2004 10:22 PM
solder gun
i have a 30watt will that be good for soldering rc stuff or should i go ahead and get the 60 watt?
Neil Rabara 07-20-2004 10:26 PM
If the 30 watt is good enough, why get the 60 watt? That is the question.
kh15 07-20-2004 10:54 PM
no i said WILL my 30watt produce enough heat to solder rc stuff or should i get the hotter 60 watt
JusBox 07-20-2004 11:37 PM
get the 60. solder guns don't work very well though, i'd go for a standard pencil type iron.
Grizzbob 07-21-2004 01:55 AM
Right, I'd be surprised if even a 60 watt gun did any good, as they just can't produce enough heat at the tip to make that much of a difference(& more importantly, a gun's tip just doesn't have enough surface area to transfer heat quickly to the thigns you;re soldering). I'd just reccomend that you get a 40-60watt pencil-type iron with a decent, broad chisel style tip, those will work just fine....:cool:
Wency_TA03R-PRO 07-21-2004 05:37 AM
:nod: :nod: :nod:
